Go to Post It's rather simple: you start with a block of solid and remove material until you just have the robot left. Kind of like making a sandcastle. Only harder. - petek [more]
Unread 01-05-2005, 19:54
Paul H's Avatar
Paul H Paul H is offline
Renegade of Funk
AKA: Paul Huston
FRC #0033 (Killer Bees)
Paul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant future
Send a message via AIM to Paul H
pic: Yeah Its Got A Hemi Too!
-Paul
Unread 01-05-2005, 19:55
BoyWithCape195 BoyWithCape195 is offline
AKA: Ben Gagne
FRC #0195
BoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant future
Send a message via AIM to BoyWithCape195
Re: pic: Yeah Its Got A Hemi Too!
I really liked your labels on everything in your robot. When i saw a few of them (the small white ones) it gave me a laugh. I especially liked the one for your "finger".
2007 UTC New England Regional Champions (1124 and 558)
2007 UTC GM Industrial Design
2006 International Championship Finalist (25 and 968)
2006 Newton Division Champions (25 and 968)
2006 Championship Innovation in Control Award
2006 UTC Quarterfinalist (236 and 230)
2006 UTC Innovation in Control Award
2005 Curie Division Quarterfinalists (703 and 234)
2005 UTC Semifinalist (228 and 236)
2004 UTC Entrepreneurship Award
2004 New Jersey Semifinalists (173 and 11)
2004 New Jersey Sportsmanship Award
Unread 01-05-2005, 20:01
Mike33's Avatar
Mike33 Mike33 is offline
NOOOOOOOOOO! MY LAST YEAR IS OVER!
AKA: Keebler (Elf)
Mike33 will become famous soon enough
Send a message via AIM to Mike33
yeah, we have just a 'little' fun with the label maker...ok so lied, we have alot of fun. such as one located on the bumpers. "Fragile! Do not hit"
--"Always bear in mind that your own resolution to succeed is more important than any other one thing." --Abe Lincoln
Final Four in 2005 National Championship
2005 National Team Imagery Award
2005 West Michigan Imagery Award
2005 Detroit General Motors Industrial Design Award
2nd Place in Detroit and West Michigan
"Its a jeep thing, you wouldn't understand"
---copy the jeep and pass it around---
o_o_o_o
./| ,[_____],
|ŻŻŻL--O|||||||O
()_)Ż()_) ŻŻŻ )_)
(originaly made by my friend david)
Unread 01-05-2005, 20:34
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Is that two fisher prices linked back to front running into one Dewalt?
Unread 01-05-2005, 21:04
Eric Yahrmatter's Avatar
Eric Yahrmatter Eric Yahrmatter is offline
Eric Yahrmatter has a spectacular aura aboutEric Yahrmatter has a spectacular aura about
Yes sir! They are linked together by a small shaft collar.
Unread 01-05-2005, 21:11
Paul H's Avatar
Renegade of Funk
AKA: Paul Huston
Yep, the pinion gear on the back one is pressed out a little, then pressed on
to the little part of the pinion that sticks out the back of the front one...both going into one DeWalt. They have a spare that uses a little shaft collar, which would be easier than pressing it on. There used to be two dewalts there, as you can see the mount for the other one, but one was taken out and this configuration was used...not positive why, maybe someone that was on the team this year can answer.
Here's the best pic I could get of it....
-Paul
Unread 01-05-2005, 21:31
I thought that on the FP shaft it is the splined portion (slightly larger diameter) that actually makes the good press, so if it is pressing onto the smooth portion on the back of the other one then does it still get a good press fit? (I know that was probably horrible grammar) Anyway, I'm sure whatever you did it worked great. I have always thought doing that was kind of cool ever since I read about it in a Technokat whitepaper. I don't recall so I ask: exactly how much shaft does stick out the back of the motor?
TCP/IP on a PIC Venkatesh Electrical 1 18-11-2003 21:00
Sing me a SONG! Biggs717 Chit-Chat 78 09-05-2003 07:59
