Go to Post So, we should have respect for each other regardless of whether we are building our robot with a Waterjet or a Hacksaw. Construction methods will vary widely, but honoring your competitors should be universal. - OZ_341 [more]
  #41   Spotlight this post!
Unread 02-05-2005, 01:08
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Re: SLU-70 Lugs: Post a pic ? What about soldered lugs ?
Originally Posted by Al Skierkiewicz
...As a matter of fact, two robots that I know of in Atlanta had small fires due to wiring errors. It is imperative that teams know that the battery we use is capable of producing extreme heat under the conditions that some teams use them. A simple loose connection on a battery where the drive train is pulling more than 200 amps is capable of several thousand watts in a 1/4 sq. in. area. (I^2*R=200^2*1ohm=4000watts)....
Which is kinda odd, they want us to make good connections but they say use #6 on a 120 amp breaker, #6 will really only properly sustain ~60 amp. But THAT, is another story
-Mike
-Electrician
Anderson Copper 70 Lugs xFlashbacksx Electrical 5 19-02-2005 12:33
Spazing Robot Matthew_H Electrical 15 19-04-2004 07:49
