Go to Post We can't turn off inspiration and recognition, development and learning with a switch. It is an on-going process. If it were not, there would be no need for CD except for 6 weeks out of the year. - JaneYoung [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 01-05-2005, 21:33
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Self-Balancing 2 Wheeled Robot
Since build/official competitions are over I've been working on making my own robot. Currently, the frame is done (I'll try to post pictures later, for a CAD model see bottom of the post) and I'm looking at what electronic parts I should buy. Here's my current list:
Microcontroller $85.95
6 AA Battery Holder $0.75
Solarbotics GM8 Gearmotor (2x) $12.00
Solarbotics Plastic Wheel (2x) $8.00
Shipping: $4.95
12" PWM Cables (2x) $18.94
What I need is a gyroscope, although of all the researching I've done of balancing robots people have used both gyroscopes and accelerometers. Will just a gyroscope be sufficient? Does anyone know a good/cheap gyroscope/accelerometer that I would need?
Thanks in advance.
CAD Model:
*Note: Those aren't the motors I'm using, and it's wood... not metal.*
EDIT: Whoops, this was supposed to go in Technical Discussion, any mod feel free to move it.
http://www.mikesorrenti.com/
Unread 01-05-2005, 23:15
colt527 colt527 is offline
AKA: Ken Colton
FRC #0527
colt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to behold
Send a message via AIM to colt527
Re: Self-Balancing 2 Wheeled Robot
Hmm, I think this is a quite a task to take on, You are basically reproducing a segway and Im pretty sure Human Like movement based on balance is not an easy thing to pull off both programming-wize and mechanical wize. Its going to take a lot of effort to pull it off.
On the hardware side:
Ive seen balancing done with distance sensors as well though. Where they point at the ground and measure the distance difference between the 2 sides and make movement decisions based on that. And, I dont know much about the speed of the microcontroller that you need to accomplish this feat but I imagine that it needs to be pretty fast and update often.
Sorry I couldnt be more help, but good luck! and I hope to see it working
Mentor, Team 527 -- Plainedge Red Dragons
FIRST Volunteer
SUNY Stony Brook Computer Science 2010
kcolton@gmail.com
Unread 01-05-2005, 23:59
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I once tried my hand at a fullsize one with a Parallax BS2 and a Memsic Accelerometer (that parallax sells) but never really got too far with it. I'm not a programmer but even I I was, I'm not sure if the electronics and hardware are capable of balancing.
You may find some useful info at www.tlb.org
Unread 02-05-2005, 15:22
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Let's not forget that Mike was the one who coded a working autonomous code that used the camera and capped the vision tetra.
I think you may find this site very informative:
http://www.geology.smu.edu/~dpa-www/robo/nbot/
Also, people have built a "Legway" balancing robot using Lego Mindstorms:
http://www.generation5.org/content/2004/legway.asp
Art Dutra IV
世上无难事,只怕有心人.
Unread 02-05-2005, 15:40
Paul H's Avatar
Paul H Paul H is offline
Renegade of Funk
AKA: Paul Huston
FRC #0033 (Killer Bees)
Paul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant future
Send a message via AIM to Paul H
I've got a gyro you can have, I got a few from the yardsale last year and I only really need one. It's the gyro that was in the kit from previous years. All I ask is that you pay shipping.
-Paul
Unread 02-05-2005, 16:36
Kevin Watson's Avatar
La Cañada High School
FRC #2429
This is the classic inverted pendulum problem that is given to countless college students each year. You'll need to implement a Kalman filter that'll filter noise, perform sensor fusion and spit out a state estimation. As you've already found out, you'll need a gyro and an accelerometer that's sensitive down to zero Hertz (i.e., gravity). Sparkfun has a gyro/accelerometer board that looks good. The part number is ACL-IMU-203.
-Kevin
Kevin Watson
http://kevin.org
Unread 02-05-2005, 20:56
Mike's Avatar
AKA: Mike Sorrenti
Wow, didn't realize it'd be this expensive/complicated.
I'm gonna think about maybe a lower cost/simpler alternative to a gyro, maybe a feeler attached to a pot? If you have any suggestions feel free to post =)
EDIT: Or anyone know how I can build something similar to http://www.sparkfun.com/shop/index.p...s=ACL-IMU-203& for cheaper?
Unread 02-05-2005, 21:30
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
The sparkfun IMU is neat in that it is all on one board, but you can get evaluation board versions of the same things from Analog Devices (www.analog.com). You can probably save $30-$50 by buying separate EB's instead, but you aren't going to get comparable performance for much less. Make sure you buy EB's or something with the devices mounted. The gyro's are all ballgrid and aren't worth the trouble of mounting yourself, you can solder the accelerometers as they are a small surface mount pitch but its still easier to buy EB's that have all the resistors and caps installed that you need.
As far as something simplier/cheaper, I've seen people attempt the same design using two IR distance sensors on each side.
Unread 04-05-2005, 15:25
Mike's Avatar
AKA: Mike Sorrenti
I've decided to use a potentiometer connected to a "feeler" to sense the angle that the bot is at. Once I get that working, I'll buy some IR sensors and use those.
Unread 04-05-2005, 15:46
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
You could use the pot as the pivot point for a small pendulum mounted inside the frame. It might have to be heavy to overcome the static friction of the pot, but it would be doable. The value of the pot would be proportional to the tilt angle.
Unread 04-05-2005, 19:18
Mike's Avatar
AKA: Mike Sorrenti
Good idea, probably will try it after the feeler idea. Right now I'm kinda limited to my space/weight, but I'll be sure to check it out later.
Unread 04-05-2005, 23:26
A feeler will work as long as the surface is flat and level. Without a true sense of "down", a Segway clone will want to accelerate downhill.
Unread 05-05-2005, 19:21
Mike's Avatar
AKA: Mike Sorrenti
Yeah, I was thinking about that. So I might make a feeler design just to experience with using a pot as an angle measurement.
There's also a problem with the pendulum idea. If I am making constant adjustments to control the angle, then the pendulum will start swinging. The swinging will cause harder adjustments, which will just feed this repetition harder until the robot tips. I'm thinking of something along the classic pendulum lines, I'll try to make up a CAD drawing and post it later.
Unread 06-05-2005, 11:47
There's also a problem with the pendulum idea. If I am making constant adjustments to control the angle, then the pendulum will start swinging...
If you mount the pendulum to hang from the point of rotation of the platform (i.e. the axle), you'll have a lot less to worry about. You can account for the approximately known linear acceleration and compute something very close to the actual tilt. Modeling the dynamics of the pendulum might still be necessary, but you won't have to deal with the chaotic "double pendulum" system that would arise if the pivot point were somewhere above the axle.
Unread 06-05-2005, 14:38
Mike's Avatar
AKA: Mike Sorrenti
I can see how that would stop the pendulum from swinging wildly, but for the pot to take readings, it has to be mounted on the pot, right?
The way I'm thinking of designing a pendulum is for it to be less of a circular motion of swinging and more of a linear one. Think of a box with beads in it, when it's tilted the beads fall to one end of the box instead of swinging like a classic pendulum would. Of course, I wouldn't use beads.
Robot Weight Limit: Rule Conflict Specialagentjim Rules/Strategy 10 06-08-2005 17:52
Is allowing a practice robot good for FIRST? Matt Adams General Forum 38 19-01-2005 11:35
THIS TIME TEAM 438 BALANCING ROBOT archiver 2001 1 24-06-2002 01:01
Kamikaze Robot Strategy... Joe Johnson Rules/Strategy 30 07-04-2002 21:42
Calling all Lawyers... ...Define "all parts" Joe Johnson General Forum 10 13-03-2002 15:12
