Go to Post It's not about the numbers, it's what you can do with them. - AlecMataloni [more]
Unread 02-05-2005, 20:38
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Functions of '?', ':', and '&' in the C programming language
What are the functions of the ? and the : in the following C statement?
TX_OUTPUT_PIN = Tx_Buffer & 0x01 ? SERIAL_1 : SERIAL_0;
Another question, can someone please clearly explain the purpose (And usage) of the bitwise AND operator?
Thank you very much,
Unread 02-05-2005, 20:49
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Re: Functions of '?', ':', and '&' in the C programming language
The ?: is called the ternary operator because it takes three operands. It's shorthand for "If the first operand is true, return the value of the second operand, otherwise, return the value of the third."
The & is a bitwise AND. The value returned has a 1 in each bit that is set in both operands. All other bits are zero.
In this example, the low order bit of Tx_Buffer is tested, and if it is set, TX_OUTPUT_PIN is assigned the value SERIAL_1, otherwise SERIAL_0.
BTW, I generally steer away from using the ternary operator. The following is much clearer:
if (Tx_Buffer & 0x01 == 1)
  TX_OUTPUT_PIN = SERIAL_1;
else
  TX_OUTPUT_PIN = SERIAL_0;
Unread 02-05-2005, 21:42
DanDon's Avatar
ohhh MY god
AKA: Dan Hoizner
Please pardon my ignorance, but what does the 0x01 do when the bitwise AND is used on it and Tx_Buffer?
Thank you so much for your reply,
Unread 02-05-2005, 22:16
Matt Leese Matt Leese is offline
Been-In-FIRST-Too-Long
FRC #1438 (The Aztechs)
Matt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond repute
Send a message via AIM to Matt Leese
The bitwise operators work at the bit level. It will do a bitwise AND on each and every bit. So, if the low-bit of Tx_Buffer is 1, the output will be 1. Otherwise it will be 0.
Assuming Tx_Buffer = 0x41, the comparison would look like:
  0000 0001
& 0100 0001
  0000 0001
Matt
Unread 02-05-2005, 22:46
DanDon's Avatar
ohhh MY god
AKA: Dan Hoizner
0000 0001
& 0100 0001
0000 0001
Matt
Thanks for the reply Matt, that really clarified my understanding of the bitwise AND operator.
Thanks again,
Unread 03-05-2005, 09:37
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
else
As much as I hate "yeah, me too" posts, I'm going to do it here...
I strongly recommend staying away from the ternary operator. I also strongly recommend staying away from any other practice that makes your code less clear than it has to be. Good clear code trumps keystroke efficiency in all cases - don't forget that.
During the FRC Championship conference, myself and a colleagure presented an "Advanced C Programming" lecture. The main focus of the lecture was to show how C programming is done in the real-time embedded industry. We tried to impress as much as possible on "good coding practices". While it wasn't in the presentation, we made mention of staying away from the ternary operator (as well as recursion, compound statements, leaving out the {} from code blocks, etc.).
The following web page: http://www.andromeda.com/people/ddyer/topten.html is a great list of C "gotcha's". 90% of them are avoided by using the good practices we recommend. As a side note, the good coding practices that we recommend are basically part of a coding standard that is typical in industry.
Okay, sorry for getting this thread off topic...
Unread 03-05-2005, 13:43
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
Originally Posted by Chris Hibner
...(as well as recursion, compound statements, leaving out the {} from code blocks, etc.).
Yeah. I know I violated this one. I should have written
if (Tx_Buffer & 0x01 == 1) {
} else {
(Or is it
else
?) There are so many opinions about where to place the braces, I decided to leave them out... just this once! I swear!
Unread 04-05-2005, 21:37
Ben Margolis Ben Margolis is offline
Programmer Boy
Ben Margolis is a glorious beacon of lightBen Margolis is a glorious beacon of lightBen Margolis is a glorious beacon of lightBen Margolis is a glorious beacon of lightBen Margolis is a glorious beacon of lightBen Margolis is a glorious beacon of light
I just want to say that I like the website and I'm really sorry I missed the lecture. Is there anywhere where an overview of it can be found? I'm all for spreading the C knowledge.
Unread 05-05-2005, 09:25
The conference material can be found here:
http://www.usfirst.org/robotics/2005...sentations.htm
