Go to Post Gracious Professionalism does not take a holiday. - JaneYoung [more]
Unread 02-05-2005, 20:22
BaldwinNYRookie's Avatar
BaldwinNYRookie BaldwinNYRookie is offline
Chase's old account
AKA: Chase
FRC #1546 (Chaos inc.)
Team Role: Student
BaldwinNYRookie will become famous soon enoughBaldwinNYRookie will become famous soon enough
Send a message via AIM to BaldwinNYRookie
Vex bot programming Q's
Alright, I'm just the team photographer I don't do too much technical stuff, but I really want to build a robot. So I was thinking about getting myself a VEX Starter kit, I could work on it over the summer. I'm pretty sure I can build it, but I don't know the first thing about programming. So I have a couple of questions for anyone who has built a Vex bot before I start saving up for this thing. Does it involve a lot of programming? If so how would I learn how to program it? I don't want to spend $300 to find I can't do anything with it.
CHAOS INC. TEAM #1546
2004- Brunswick Eruption- Against All Odds Award
2005- Long Island Regionals- Rookie Allstar Award
robot.baldwinschools.net
http://www.e-reincarnation.com/reincarnation_benjamin_franklin.html
Unread 02-05-2005, 20:32
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
Re: Vex bot programming Q's
Out of the box right now, you can't even program it. It's pretty capable with the default code and setting jumpers and changing settings on the controller. You'll have to wait a few months before the programming unit is available to purchase.
Unread 02-05-2005, 20:33
The kit today does not require programming by the user. Actually, it doesn't even support programming by the user yet. It has the equivalent of "default code" loaded, with specific outputs responding to specific joystick and button inputs. The programming tools are to be available "sometime this summer" according to the people who were demonstrating it at Championship.
Unread 02-05-2005, 20:37
REVving up for a new season
FRC #2848 (All-sparks)
just a follow up...no right now you can not program the unit but when the programing module comes out you will be able to program it in c or use a custom vex GUI which will make programing simple just like the Lego mind storms. so don;t be afraid of the programing side of things because right now you don;t need it and when it does come out it is made so people with no programing knowledge (like you and me) can still do cool stuff
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 02-05-2005, 21:12
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
I would buy a robovation controller ($249 new, you can probably get one used)
Imagine the FRC controller, smaller. They're really easy to get started with and can do all tons of advanced stuff too.
http://ifirobotics.com/edu-rc.shtml
http://www.mikesorrenti.com/
Unread 02-05-2005, 21:20
FRC #0190
The vex kit is a far better deal - $300 for the same thing minus rs232 port and solenoid outs, and includes all the robovation metal, better wheels, a reciever and transmitter. (Which would cost you nearly $600 for the robovation kit).
Unread 09-10-2005, 17:45
TheTormented TheTormented is offline
TheTormented is an unknown quantity at this point
yeah Baldwin I have the programming kit myself and its really good from my perspective. If you get it you need to get the programming kit as well cause the programming kit will be C based from what I read on this one website (http://www.radioshack.com/product.as...ct_id=276-2152) and also if your new to programming the programming kit is really good at teaching beginners about programming so i really hope you get the Vex Starter Kit over any other robot.
how to build a VEX programming module bblack7489 FIRST Tech Challenge 78 09-06-2011 16:03
Programming - Getting Started Mark McLeod Programming 80 16-04-2008 23:37
Programming for Vex robots Jeff K. Programming 4 13-11-2005 16:40
Vex Robotics Vex FIRST Tech Challenge 0 14-04-2005 13:48
VEX Robotics vexrobotics FIRST Tech Challenge 8 30-03-2005 23:25
