Go to Post Strive for excellence in everything you do, but also recognize it in others when you see it, rather than try to drag it down. - Joe G. [more]
Unread 01-05-2005, 14:08
Meyerman Meyerman is offline
Meyers #37, Pink Petunia's!
AKA: Meyers
FRC #0056 (RoBBE Xtreme)
Meyerman is a splendid one to beholdMeyerman is a splendid one to beholdMeyerman is a splendid one to beholdMeyerman is a splendid one to beholdMeyerman is a splendid one to beholdMeyerman is a splendid one to beholdMeyerman is a splendid one to behold
Send a message via AIM to Meyerman Send a message via Yahoo to Meyerman
Re: Taking Home Tetras
i thought in 2003 you could take the bins, and last year i know they gave out the popped balls unless the people at the places i went to were just nice and didnt listen to FIRST and 56 accually was able to get a kick ball at nats but it may have been because it ended up stuck in our chain and we had to take it to the pits to get out.
Unread 03-05-2005, 23:43
IronVulture's Avatar
IronVulture IronVulture is offline
Responds to 'Darth Vulture'
AKA: Jake 'Blar' Bleier
FRC #0234 (CyberBlue)
Team Role: Animator
IronVulture will become famous soon enoughIronVulture will become famous soon enough
Send a message via AIM to IronVulture
All I know is that me and a couple guys from other teams played poker and used broken clovers from the practice field as chips... not that anyone went home with said broken clovers...
Tell a man how a robot works and he'll believe you, tell him the paint is wet and he'll have to touch it to be sure.
If you give a man a fire, he will be warm for a day. If you set a man on fire, he will be warm for the rest of his life.
SCAVENGERS OF THE WORLD UNITE!
Unread 03-05-2005, 23:56
CraigHickman
Posts: n/a
Ya, know, if you really want one, just paint a practice tetra with red or blue paint. It'll look the same, and won't be a hassle to get.
Unread 04-05-2005, 00:09
D.J. Fluck
Posts: n/a
I helped clean up and tear down archimedes and newton during the award ceremony and the guy overseeing said to make sure the tetras get packed away with the field and dont take them.
Unread 04-05-2005, 00:14
Team Role: Animator
still, I thought broken tets just went in the garbage anyway
anyone know different?
Unread 04-05-2005, 01:09
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Nope. They're all repaired. A leg would go in the trash if it was cracked in half, or the nut inside stripped.
Otherwise, all the legs are reused.
2001-2004: Team 100
2006-Present: Team 254
Unread 04-05-2005, 01:31
Vu2000 Vu2000 is offline
Midnight Mechanic
None #0812 (Midnight Mechanics)
Vu2000 has a spectacular aura aboutVu2000 has a spectacular aura about
Send a message via AIM to Vu2000 Send a message via MSN to Vu2000
Isn't each tetra something like more then 15 bucks with the 4 clovers and PVC combined? That's some pretty expensive stuff for robots to be breaking so easily.
Peace up; A-Town Down
2006 So Cal Chairman's Award!!!
2005 So Cal Chairman's Award
2005 So Cal Safety Honorable Mention (safety captain)
2004 Championship Engineering Inspiration
2004 So Cal Engineering Inspiration
Unread 04-05-2005, 06:56
Denman's Avatar
Denman Denman is offline
Tie Wrap-Not Cable Tie or Zip tie
AKA: Stephen Denman
FRC #0759 (Systemetric)
Denman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud of
Send a message via ICQ to Denman Send a message via AIM to Denman Send a message via MSN to Denman Send a message via Yahoo to Denman
Originally Posted by dez250
I am wondering for all you who took tetras from the practice field, who you asked if you could have them. All tetras that were damaged were repaired, and if a single leg was damaged beyond repair (the t-nut stripped out) then a replacement leg was put in. FIRST has specific instruction that the tetras are part of the field and do not go home with people. Taking a tetra without proper authorization is the same as stealing.
why doesn't anyone read what a guy who knows the answer says?
Originally Posted by Queen_of_Mascot
The ones we took from reigonals were BROKEN, the plastic rings were destroyed, PVC bits cracked, if any of you were there at NYC reigonals, you saw how some of those robots just spun and threw those tetras about. Actually, that'd make a good game... see how far a robot can launch a tetra.
Dez was there
We have our own tetras and found that a good way to weigh them down is to get some lengths of copper pipe inside some thin walled pipe for the tetras and it is reasonably accurate. now just paint
I am an ex-member of team 759.
759: regional winners with 522 and 233 NYC (2004)
FIRSTWiki.org - Contribute, learn, inspire.
"Teach the way of the GP and the way of the GP shall teach you" - Me
Unread 04-05-2005, 13:05
the_short1's Avatar
the_short1 the_short1 is offline
Head of Electronics
AKA: Kevin F.
FRC #1596 (Twin Saults International Instigators)
Team Role: Electrical
the_short1 is a name known to allthe_short1 is a name known to allthe_short1 is a name known to allthe_short1 is a name known to allthe_short1 is a name known to allthe_short1 is a name known to all
Send a message via MSN to the_short1
they were handing them out at the champs... even for off season.. .they still have aLOT of tetras..
the tetras we got were broken clovers.. but thats no bigge.. we still scored like 4 of them..
2005 GLR: 12th/58 Seed, Aliance: 1596, 910, 1447 (Semi Finalists) Website, Rookie All Star, Highest Rookie Seed, and 2 Peer Awards, my BIG thank you thread, PLEASE READ
2005 GTR: 11th/66 Seed, Aliance: 703, 1596, 1680 (Semi Finalists) Highest Rookie Seed & 1 Peer Awards
2005 Championship (Galileo): 36th/86 Seed Highest Galileo Match Score: 123:7 Thanks 447 and 121
2006 Website (Totally Revamped):Instigators1596.com
2006 GLR: 31st/61 Seed, Aliance: 835, 1213, 1596 (Quarter Finalists) Spirit & 3 peer awards, THX!
2006 Waterloo: 7th/31 Seed, Aliance: 1219, 1596, 912 (Semi Finalists) Spirit & 2 peer awards, THX!
2006 Waterloo: Aliance: 1596, 1680, 1114 Higest Match Score: (Q22) 128|32
Unread 04-05-2005, 14:49
katiyeh07's Avatar
katiyeh07 katiyeh07 is offline
AKA: Kristine
FRC #0125 (NUTRONS)
katiyeh07 has a reputation beyond reputekatiyeh07 has a reputation beyond reputekatiyeh07 has a reputation beyond reputekatiyeh07 has a reputation beyond reputekatiyeh07 has a reputation beyond reputekatiyeh07 has a reputation beyond reputekatiyeh07 has a reputation beyond reputekatiyeh07 has a reputation beyond reputekatiyeh07 has a reputation beyond reputekatiyeh07 has a reputation beyond reputekatiyeh07 has a reputation beyond repute
what would you do with it? i mean i understand floppies from a while ago, we have some here that serve as bed pillows, the black, yellow, and purple balls from last year and 00', and the soccerballs, and the crates (great for storage, they stack nicely), but tetras? what do you plan to do with those?
Unread 04-05-2005, 15:10
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
They'd be momentos to remember this year by.
http://www.mikesorrenti.com/
Unread 04-05-2005, 15:16
Vin211's Avatar
Vin211 Vin211 is offline
FRC #0237 (T.R.I.B.E)
Vin211 will become famous soon enoughVin211 will become famous soon enough
Send a message via AIM to Vin211 Send a message via Yahoo to Vin211
Talking Re: Taking Home Tetras
Lol, I've got a "broken" tetra from the UTC Competition. I've actually got it mounted to my wall. Lol its like a 3D Poster lol! Thanks FIRST!
Vincent Zotto
Sie-H20 Bots (1999 - 2002)
Cyber Knights (2003 - 2005)
Sie-H20 Bots (2007 - Present)
Unread 04-05-2005, 16:49
Vin211's Avatar
Sorry everyone let me clarify. I have a broken tetra because I completely put one together from pieces that were already thrown in the garbage. That's how I made a complete "broken" tetra". I just wanted to clarify it lol.
Vincent Zotto
Unread 04-05-2005, 16:52
geeknerd99's Avatar
geeknerd99 geeknerd99 is offline
Fire Hazard
AKA: Daniel Lin
FRC #0401 (Hokie Guard)
geeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud of
Send a message via AIM to geeknerd99 Send a message via MSN to geeknerd99 Send a message via Yahoo to geeknerd99
What if they were taken at the end of an off-season event? I can't imagine where the fields would go after the season of off-season events.
Unread 04-05-2005, 16:53
Cory's Avatar
AKA: Cory McBride
To another offseason event
2001-2004: Team 100
Running Out of Tetras psquared89 General Forum 28 27-04-2005 12:45
Question: Missing Tetras in Human Loading Zone? tribotec_ca88 Rules/Strategy 7 15-01-2005 15:26
How to Stack Tetras in Inventor petek Inventor 0 13-01-2005 11:47
**FIRST EMAIL**/Advance Material List for the 2005 Competition Now Available! Travis Hoffman General Forum 85 08-01-2005 00:16
Taking the kits from Manchester on planes back to home base Ken Leung General Forum 4 24-09-2001 22:47
