Thread Tools |
Rating:
Display Modes |
Re: Victor Burnouts
Hey all!
Been awhile... Just my thoughts: I have seen a couple vics blown out in several ways. The most common I have seen (and yes, I am ABSOLUTELY SURE this is what I saw) is people pushing their robots when they are off. This creates juice from the motors, which goes where? the victor. (I really don't recomend this, but if you backdrive the motors and look at the victors, sometimes the lights will turn on. Again, because of the previous point, I don't recomend this.) Push it hard enough, they can zap themselves. This is what I think happened with the hand-cranking the winch, and also it makes sense that only one set of FETs would blow out if you're only wheeling it one way, so the other direction should still work. Also, check the main capacitor in the middle. Another man I once met inspecting the Vics noticed some sticky stuff on one of his, and said it's electrolyte. I don't know how much truth there was to this, but if your capacitor's top is bulging, then it's gonna blow. Replace it before bad things happen. Hope I am 1)helping, not hindering, and 2)not going over old territory. Sparks Oh, and Bob? That white stuff, I'd bet, is electrolyte. I could be wrong (you're not supposed to see it, so I don't know what color it is) but that seems to be the best guess I have. Last edited by Sparks333 : 05-05-2005 at 20:09. |
Re: Victor Burnouts
I thought we lost you, glad to see you back. We have been back driving Victirs for years with out any ill effects. The motors do act as generators and there is enough leakage current that backs up through the controller to turn the LEDs on but unless you are pushing the robot at highway speeds in is unlikely you can genreate enough current to fry the controllers. The main cap in the middle of the FETs is rated pretty well for the voltage we use but where it is located subjects to very high heat when the robot is working hard, like during practice. The heat causes early failure and the case has a pressure relief that leaks the electrolyte out of the can. This is nasty stuff so don't touch and then put your finger in your mouth. When it has dried for several days, it does turn into a white, crusty almost lime looking (as in hard water deposit) gunk and it eats copper and other metals. The white smudges are really the result of the magic smoke leaving the device at high speed. They are mostly the ashes of the silicon interior that vaporized during the event. If everything looks normal except the white residue, know that a closer look will show a crack in the case. In some of the more spectacular deaths, there has been loud cracks followed by microscopic plastic shrapnel as the cases of the FETs blow apart. |
Re: Victor Burnouts
Al,
That sounds reasonable. My only point here is that some teams really gear their motors down, so it is sorta kinda maybe possible that by backdriving they are spinning the motors much faster than the wheels. I'm drawing at straws here, aren't I. What I saw was a team pushing their robot in a parking lot, then complaining of a burning smell. On closer examination, the victors wouldn't turn on. Since it was another team's, I couldn't get a close look at the vics, but a couple mentors blamed it on backdriving. I have avoided it ever since. Thanks for setting me straight! Sparks |
Re: Victor Burnouts
Thanks, |
Re: Victor Burnouts
If this were the problem, it would be very possible to provide something to sink the current and keep voltage spikes down. A 120mm fan or two would do the job, or maybe some sort of lighting. Just make sure that the load is wired so that it is on when the main breaker is on. Can I say for sure that this is the problem? No. Is it a possibility? yes. Look at the schematic symbol for some FETs and you see a reverse biased diode, with the H-bridge, that would act as a rectifier, and power up the bot. |
Re: Victor Burnouts
I'm with Al here on the backdriving. I've seen some LED's light up, and the fans twitch, but there can't be anywhere near enough current flowing to mess up the fets.
Or is there? Could it be that with dynamic braking on, the current on some victors just ends up as heat as opposed to getting sent onto the rest of the harness? I'm just wondering that maybe if dynamic braking is not on, all that backdriven current gets disapatied through all the victors, RC, etc., causing little if any problems. If braking is on, that current would 'stay' in the victor, right? Or am I just missing something key about how braking works on a victor? Just grasping at some more straws. -Andy A. |
#7
Re: Victor Burnouts
Andy,
I am guessing on this, but I don't think the jumper keeps the brake on when the controller is not powered. If that was the case, you wouldn't be able to push the robot with the wheels on the floor. Also, as I remember, IFI started including a varistor across the output. This was something we previously had to add to the output terminals. The device is designed to eat up spikes from brush noise and back drive so I think it limits the voltage to 40 or 50 volts. I am going to have to look back at the specs on the devices we had to add in the past. |
#8
Re: Victor Burnouts
Al,
I can't remember the team number, but I will see if anyone else does. Sparks PS: Are FETs sensitive to polarization? I think they are, but I don't want to make false assertions. IFI Robotics has a notice on the vics page that says: Quote:
#9
Re: Victor Burnouts
Like I was saying, the body diodes in the FETs rectify the power from the motor and, which then puts it back through the circuit breaker, and makes it available for everything else. There is a diode formed in the process of making the FET, but some diodes may even have an additional diode on the die for extra protection.
But if you hook up the victor backwards, on the inputs, the body diodes on the FETs all of a sudden point from the line with +12v on it to the gnd line. So you then have a dead short through 2 diodes. (the top and bottom halves of the H-bridge) The attached schematic is a typical H-bridge with 3 FETs in parallel for each "quadrant" When you power up a victor with the inputs reversed, a massive amount of current can flow, and you could burn up the FETs. That isn't even worrying about the control circuitry. Reverse polarity on that could just kill a chip and the victor would be nuked, simple as that. But the rectification provided by the body diodes, directs the power put in on the output to the correct side on the input. So if you hooked up a victor backwards, (inputs as an output, output as an input) when you turn on the circuit breaker, you would get +12v on the +12v connector, regardless of if the battery was hooked to the m+ or m-. As for braking while powered down. The victors don't even brake when they are powered up, have the jumper set to brake, and they aren't receiving a signal. I know this for a fact. On our bot this year, you can move the arm around with one hand when the bot is off, and when you have no link or it is disabled. But if you have a link and it is on, that arm is not moving (not with one hand anyway...) IFI says that dynamic braking still works while it is not receiving a signal, but not from what Ive seen. Even if it did, most of the power would be dissipated in the motor windings, and not the FETs. Looking at the datasheet for the FET that Mark McLeod linked to, the on resistance is 14 mOhms . With 2 banks of 3 FETs in parallel, in series, that would be 9.33 mOhms. That would be almost insignificant compared to the resistance of the motor windings. So we know that braking can't really hurt the FETs while it is on. Also, looking at the datasheet, the D-S diode has a maximum continuous current of 60A. Remember, there is 3 FETs in parallel. I really don't think you are going to turn your motor fast enough to make 180A for an extended period of time. I seem to remember that the maximum discharge for the ES18 batteries that we use is 230+ A so it would be possible to fry the victor in the manner that I mentioned earlier, reversed polarity in the inputs. But I'm sure the diodes wont exactly share evenly either, making a cascading failure. Sorry to make this so long, but looking at the electronics, I would have to say that backdriving a motor hooked correctly to a victor in any state ( on, off, signal, no signal...) could not fry it. Last edited by ConKbot of Doom : 08-05-2005 at 15:28. |
#10
Re: Victor Burnouts
I agree that the brake will not be applied unless the controller is enabled now that I think about it. All PWM outputs are disabled unless the OI and RC are talking and enabled. The brake should only cut in during a PWM 127 +/- the deadband right? |
#11
Re: Victor Burnouts
I could actually see having a fun time getting freshmen to push the robot in this condition. They push it, it brakes, they stop to see what is up, and by that time, it has turned back off. They continue to push... ![]() |
#12
Re: Victor Burnouts
All,
Okay, I'm convinced. Backdriving doesn't hurt a vic. Unfortuantely, this makes this mystery even harder to solve... Sparks |
#13
dummy load / test load for Victor speed controller
We'd like to build a test setup for the Victors. Anybody have a suggestion for a cheap fixed resistance dummy load? I don't want to use a motor because the motor is not fixed resistance and it's hard to measure motor power output. Would like to have the ability to set the resistance to about 0.32 ohms to get a 40 A max current test, and also to something like 2.5 ohms for a 5 A max current test. Would like to use a fixed resistor that would spread the heat dissapation over a large area so it doesn't get dangerously hot (500+ watts for the 40 A test).
I can put a big resistor in a can of oil like we do in RF power testing. Anybody got a better idea? Bill |
#14
Re: Victor Burnouts
I passed your query on to one of our electrical sub-system mentors.
Our electrical group mostly use the ribbon-style power resistor with a fan blowing on it. The ribbon style are easier to get, cheaper and take a lot of abuse. Between Ebay and online surplus vendors, this can be done on the cheap. http://www.milwaukeeresistor.com/pdf/ribwound.pdf There is a chassis mount style which one of our electrical mentors has used at work as well. These are aluminum cased and can be mounted to a finned or water cooled plate, but are more expensive. Last edited by Mark McLeod : 24-05-2005 at 14:01. |
#15
Re: dummy load / test load for Victor speed controller
