Go to Post Please teams I implore you obey the no saving seats rule. Or at least be very friendly in inviting people to sit with you. - IndySam [more]
View Poll Results: Should FIRST make a rule to limit the angle of the sides of our robots?
No - the rules are fine the way they are. 122 83.56%
Yes - these "ramp bots" are getting out of hand 24 16.44%
Voters: 146. You may not vote on this poll
  #61   Spotlight this post!
Unread 03-05-2005, 22:17
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Re: Should FIRST address "ramp bots"?
Originally Posted by Ken Patton
It was 1998 when FIRST added the rule against tipping devices.
I remember a few matches in 1995 where teams pushed each other off the side of the ramp - which not only caused the loser to tip over, but sometimes they'd actually tumble down the side of the ramp, rolling completely over a few times.
Here's a picture of the ramp in 1995, which incidentally appears to have a tipped over robot next to it. You can't see it well here, but the grey part of the ramp was actually raised up a bit from the red part by a few inches, so it didn't take much to get a robot to roll off the side.
  #62   Spotlight this post!
Unread 04-05-2005, 10:01
Nitroxextreme's Avatar
Nitroxextreme Nitroxextreme is offline
Relation to Mrs. Steve
AKA: Jon
FRC #1626 (Falcon Robotics ; 190 (Gompei and The Herd))
Nitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to behold
Send a message via AIM to Nitroxextreme
i understand everyones ideas about the wedge type robot
but that is just part of the game
im not sure which robot it was but it was the one that had the wedges that flipped down and thats all they had
they were unable to hurt robots with higher ground clearance
if they had 4 wedges (which im not sure) they had 3 later
this may have been our doing when we drove over their robot without any effect on us
ps..sorry if we broke your wedge
"He needed a chuck norris lesson in FIRST"...."I will give him a round house kick to the face...with gracious professionalism"
  #63   Spotlight this post!
Unread 04-05-2005, 14:58
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
As intention flipping is no longer a part of the game, then we should take steps to minimize it. Right now, wedges seem to be the biggest cause of flipping, both intentional and non. I agree that more than 90% of flips are unintentional, but wedges increase the number of flips, and theres no way you can argue that.
Im not saying eliminate wedges as a whole, Im just saying enforce the flipping rules a bit more strictly and ask teams who's wedges become hazardous to do something about it. That could be as simple as adding stops to the wedges to prevent teams from driving too far up them.
  #64   Spotlight this post!
Unread 04-05-2005, 15:06
Software Engineer
Rookie Year: 1995
That's fine, but then the same logic should be applied to any robot with a powerful drivetrain who successfully pushes over another team. I've seen plenty of robots without ramps but with plenty of muscle do this (unintentionally, probably, but the same can be said of the ramp-bots).
If another team is driving up someone's ramps then the robot with ramps and tips then I don't see how it's the ramp-bot's fault. Anyone who is competing in this competition should know what happens to a robot's center of gravity when it drives up an incline
  #65   Spotlight this post!
Unread 04-05-2005, 16:10
Very few tips are intentional. Even with the rules, some teams may decide to do it on the spur of the moment, and are promptly shut down, depriving their partners of a teammate. Regarding proportion of tippings: I saw more robots tip over due to entaglement high up, say in their arm (we were one of them, but we righted ourselves), or just plain having 9+ pounds too high up.
If the wedges are used properly, the flips are kept to a minimum. If someone has a drivetrain and a wedge and that's their robot, that could be and probably is improper use. If a team uses them for stabilization or defense against defenders, that is more likely to be a proper use.
If you add stops to the wedges to keep teams from driving too far up, how does that stop a team with, say, two tetras at the top of their arm from going partway up, tilting just enough to move their CG beyond a point of support, and falling down?
Expect that at least one and probably more robots will have some form of wedge, unless FIRST bans them. Implement a self-righting system if you have weight for it.
  #66   Spotlight this post!
Unread 04-05-2005, 21:33
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
My teams bumpers were mentioned above. It was our teams alternative to what we considered disqualification magnent wedges.
They were parallelograms spring loaded down. When a robot hit us they would dig into the cushioned side and push the bumpers up, pulling their front wheels off the ground and shifting some of their weight onto us. In theory they worked well but they had a couple issues. First was weight, to cover all 4 sides weighed about 12 pounds plus a 5 pound powered lifting mechanism which we removed. The other issue was that they just didn't work as well as wedges. We were rarely pushing other robots and while they didn't have the danger of tipping other robots we just didn't need that.
Team Website
  #67   Spotlight this post!
Unread 05-05-2005, 15:30
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
By adding the stops low down on the wedges. If you have the stop just high enough on the ramp that the front wheels lose contact with the floor, it will acheive the same thing as having no stops at all, but reduce the chance that it will tip. The stops couldnt possibly stop 100% of the tippings, but they would reduce them. There will never be a way that you can eliminate all tipping.
Perhaps I should have worded that differently. What I meant was so that when a wedges gets under another robot, and the robot is travelling up it in some manner (either robot driving) it wont allow the robot to travel up the full incline of the ramp, therefore reducing the angle an which the robot is tilted, which reduces the chance its CG will extend beyond its supported area.
And beyond all that, most of claims to support wedges from a defensive point show them as a defense against "Bricks". Well, if its a brick it probably doesnt have an arm or a high CG, so if it tips, its definately not its own fault. The bots that do tip usually are ones with large arms or very high arms. Well if these bots are on a wedge, either the wedge is trying to force them out of position or a "brick" isnt the problem playing defence against the wedge. If its got a massive tetra carrying arm, its not a pure defensive bot, and if theres interaction between you and it, it is often the wedge bot trying to play last minute defense, not the armed bot. And in that situation it would most definately be the wedged bot's fault.
  #68   Spotlight this post!
Unread 05-05-2005, 21:22
Is the "brick" attempting to block a robot that is attempting to cap? that capper is concentrating on capping, and if the "brick" drives up a wedge, particularly a side wedge, and falls over, how is that "not its own fault"?
Most wedges are used for defense or stabilization. If it has a tetra-carrying arm, but is NOT using it, and has been playing defense the whole time, and it climbs up a wedge and gets stuck, whose fault is that?
Yes, the brickbot is not a problem if it is on a wedge --Match 70, Newton, was a good example-- but what if the wedge is on the SIDE of the wedgebot, and the wedgebot cannot move side to side, even under normal conditions? Whose fault is that if the brickbot tips over?
  #69   Spotlight this post!
Unread 06-05-2005, 15:29
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Because of the "brick's" low CG, it should very very rarely tip unless something else forces it to do so.
If the armed bot is playing defense, fault would be assossiated depending on the situation.
If the wedge can drive backwards, then in most (not quite all) situations its the wedges fault. Especially in an open field layout like this year. If the wedge can drive backwards, it can turn then avoid the "brick". If the brick keeps driving at you, eventually you'll hit a wall, and the brick will be called for pinning. If you dont have the time for a pinning situation, this year you could enter a loading zone, and if they follow you there, they will most likely be assessed the 30 pt penalty. In other years it would be different, but then again in other years tipping has been part of the game as well.
But if the wedge truly had NO OTHER option, it would be a refs call. If it had another option and it chose to tip the brick anyway, it would be the wedges fault. The brick was there to play defense, dont be upset when it does it sucessfully.
  #70   Spotlight this post!
Unread 06-05-2005, 19:16
Did I say anything about the wedge bot moving BACKWARDS? Let us suppose (as one possible situation) that there are two brick bots defending the same wedge bot, which, for all intents and purposes, and for reasons unknown, only has side wedges. One brick bot gets behind it so it can't move backward (and we are supposing that this whole scenario takes less than 10 seconds) as the other charges from the side. The brick bot coming from the side hits the wedges hard enough to go up, hits the top, and falls over. Whose fault is that?
Brick bots should know enough to stay away from inclined planes that are not shallow enough to climb without tipping. Yes, a brick bot should have a low CG, and most, if not all, do. But if the slope that it is driving up is too steep for it, it will most likely fall over.
  #71   Spotlight this post!
Unread 07-05-2005, 23:01
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Well that situation it wouldnt be the wedges fault. But that is one of the few situations I said it wouldnt be. Note how I said if it truly had no other option, it wouldnt always be the wedges fault.
  #72   Spotlight this post!
Unread 08-05-2005, 21:35
DarkJedi613's Avatar
DarkJedi613 DarkJedi613 is offline
Running Riot
AKA: Patrick Cloke
FRC #0358 (Hauppauge Robotic Eagles) FRC #1493 (RPI/Albany High School)
DarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to behold
Send a message via AIM to DarkJedi613 Send a message via MSN to DarkJedi613 Send a message via Yahoo to DarkJedi613
I think you're all looking at this on too general of a level and with way, way, waaayyy too many "What if" situations. Obviously there are advantages and to disadvantages. FIRST can ban them, or they cannot. In the latter case teams should be aware that when driving a robot with it - they must be careful, teams going against a 'wedgebot' should know better than to drive themselves up it. Overall it must be handled in a case by case situation, no two situations in a FIRST match are going to be the same - the rules need to be written to guide the inspectors and referees who are the ones who must make the final decision.
2003 - 2006 President, Coach, Webmaster Team358.org
2008 Mentor, Team 1493
Team Search | (Updated: 1-16-08)
FIRSTsearch
  #73   Spotlight this post!
Unread 08-05-2005, 23:10
Sample "guide" rule: If a robot drives up a wedge or other traction-reducing device and tips over, flips, or otherwise becomes inoperable, that is not the fault of the robot with said wedge. If, on the other hand, the robot with said wedge or traction-reducing device drives into the other robot, and the other robot becomes inoperable, that is (a penalty--FIRST's decision what) on the robot with the wedge. If both robots are judged at fault, that is a referee's call as to who gets penalized or not."
OK, it's a bit legalistic and all that, but it gets the point across (I hope) as to who is at fault in a general sense.
  #74   Spotlight this post!
Unread 11-05-2005, 18:44
Ctrl Alt Delete's Avatar
Ctrl Alt Delete Ctrl Alt Delete is offline
Code Monkey
AKA: David Weitz
FRC #0177 (Bobcats)
Ctrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to behold
Send a message via AIM to Ctrl Alt Delete Send a message via MSN to Ctrl Alt Delete
I don't think this should be against the rules. If the team has high angles on it's robot and it flips another robot, it gets a penalty. I don't think any teams intent is to play dirty. Ramps really are for only helping the team, not so much as a defense.
Life lessons learned at robot:
1.) Never take apart power strips
2.) Sleep is required, but not essential to survival
Failure to abide by these lessons will result in headaches...and flaming pants.
"Here at Bobcat Robotics, we pride ourselves in having 60-table MySQL databases, girlfriend cookies, and a vinyl cutter." -Chris Jelly
Mailing Address for Team 271 BobC General Forum 5 21-03-2005 20:35
Governor Granholm's address (GLR) Psycho Penguin Regional Competitions 13 16-03-2004 15:48
E-mail address shows Pat Fairbank CD Forum Support 1 23-12-2003 18:46
Webservers Raven_Writer Website Design/Showcase 36 31-05-2003 05:43
Phoenix incorrect shipping address Redhead Jokes Regional Competitions 2 20-02-2003 13:01
