Thread Tools |
Rating:
Display Modes |
Re: Victor Burnouts
Andy,
I am guessing on this, but I don't think the jumper keeps the brake on when the controller is not powered. If that was the case, you wouldn't be able to push the robot with the wheels on the floor. Also, as I remember, IFI started including a varistor across the output. This was something we previously had to add to the output terminals. The device is designed to eat up spikes from brush noise and back drive so I think it limits the voltage to 40 or 50 volts. I am going to have to look back at the specs on the devices we had to add in the past. |
Re: Victor Burnouts
Al,
I can't remember the team number, but I will see if anyone else does. Sparks PS: Are FETs sensitive to polarization? I think they are, but I don't want to make false assertions. IFI Robotics has a notice on the vics page that says: Quote:
Re: Victor Burnouts
Like I was saying, the body diodes in the FETs rectify the power from the motor and, which then puts it back through the circuit breaker, and makes it available for everything else. There is a diode formed in the process of making the FET, but some diodes may even have an additional diode on the die for extra protection.
But if you hook up the victor backwards, on the inputs, the body diodes on the FETs all of a sudden point from the line with +12v on it to the gnd line. So you then have a dead short through 2 diodes. (the top and bottom halves of the H-bridge) The attached schematic is a typical H-bridge with 3 FETs in parallel for each "quadrant" When you power up a victor with the inputs reversed, a massive amount of current can flow, and you could burn up the FETs. That isn't even worrying about the control circuitry. Reverse polarity on that could just kill a chip and the victor would be nuked, simple as that. But the rectification provided by the body diodes, directs the power put in on the output to the correct side on the input. So if you hooked up a victor backwards, (inputs as an output, output as an input) when you turn on the circuit breaker, you would get +12v on the +12v connector, regardless of if the battery was hooked to the m+ or m-. As for braking while powered down. The victors don't even brake when they are powered up, have the jumper set to brake, and they aren't receiving a signal. I know this for a fact. On our bot this year, you can move the arm around with one hand when the bot is off, and when you have no link or it is disabled. But if you have a link and it is on, that arm is not moving (not with one hand anyway...) IFI says that dynamic braking still works while it is not receiving a signal, but not from what Ive seen. Even if it did, most of the power would be dissipated in the motor windings, and not the FETs. Looking at the datasheet for the FET that Mark McLeod linked to, the on resistance is 14 mOhms . With 2 banks of 3 FETs in parallel, in series, that would be 9.33 mOhms. That would be almost insignificant compared to the resistance of the motor windings. So we know that braking can't really hurt the FETs while it is on. Also, looking at the datasheet, the D-S diode has a maximum continuous current of 60A. Remember, there is 3 FETs in parallel. I really don't think you are going to turn your motor fast enough to make 180A for an extended period of time. I seem to remember that the maximum discharge for the ES18 batteries that we use is 230+ A so it would be possible to fry the victor in the manner that I mentioned earlier, reversed polarity in the inputs. But I'm sure the diodes wont exactly share evenly either, making a cascading failure. Sorry to make this so long, but looking at the electronics, I would have to say that backdriving a motor hooked correctly to a victor in any state ( on, off, signal, no signal...) could not fry it. Last edited by ConKbot of Doom : 08-05-2005 at 15:28. |
Re: Victor Burnouts
I agree that the brake will not be applied unless the controller is enabled now that I think about it. All PWM outputs are disabled unless the OI and RC are talking and enabled. The brake should only cut in during a PWM 127 +/- the deadband right? |
Re: Victor Burnouts
I could actually see having a fun time getting freshmen to push the robot in this condition. They push it, it brakes, they stop to see what is up, and by that time, it has turned back off. They continue to push... ![]() |
Re: Victor Burnouts
All,
Okay, I'm convinced. Backdriving doesn't hurt a vic. Unfortuantely, this makes this mystery even harder to solve... Sparks |
#7
dummy load / test load for Victor speed controller
We'd like to build a test setup for the Victors. Anybody have a suggestion for a cheap fixed resistance dummy load? I don't want to use a motor because the motor is not fixed resistance and it's hard to measure motor power output. Would like to have the ability to set the resistance to about 0.32 ohms to get a 40 A max current test, and also to something like 2.5 ohms for a 5 A max current test. Would like to use a fixed resistor that would spread the heat dissapation over a large area so it doesn't get dangerously hot (500+ watts for the 40 A test).
I can put a big resistor in a can of oil like we do in RF power testing. Anybody got a better idea? Bill |
#8
Re: Victor Burnouts
I passed your query on to one of our electrical sub-system mentors.
Our electrical group mostly use the ribbon-style power resistor with a fan blowing on it. The ribbon style are easier to get, cheaper and take a lot of abuse. Between Ebay and online surplus vendors, this can be done on the cheap. http://www.milwaukeeresistor.com/pdf/ribwound.pdf There is a chassis mount style which one of our electrical mentors has used at work as well. These are aluminum cased and can be mounted to a finned or water cooled plate, but are more expensive. Last edited by Mark McLeod : 24-05-2005 at 14:01. |
#9
Re: dummy load / test load for Victor speed controller
Re: Victor Burnouts
A long time ago, we tested fuel cells by placing two electrical plates into a small swimming pool filled with water and then added rock salt until the resistance was what we wanted. I'm sure that a small garbage can could be used in this case. Some experimentation is required and must be done in a ventilated area (possibility of electrolysis).
Mike |
#12
Victor load testing
This sure provoked some interesting suggestions! My favorite is the salt water swimming pool...
At lunch I went over to the electronics store and bought 10 3.6 ohm 25 watt resistors. We'll wire them in parallel, in two banks of 5 each, so we can test with either (approx) 450 or 225 watts load at full power (12.8 volts). This should give a max current through the Victor of about 36A, a reasonably safe 10% below max rating for it. These are rectangular concrete resistors, so we can cool them with a slab of steel laid across all of them that will have pretty good surface contact, and keep the full power tests reasonably brief, since at max the resistors will be dissipating about 46 watts of heat each, substantially over their 25 watt rated limit. The steel will also protect from the shrapnel if they blow up.... Thanks again for the ideas. Bill |
#13
Re: Victor load testing
I remember seeing a DIY battery tester that used steel banding for the load. A suitable length of steel banding that is used to secure crates was attached to a piece of plywood in a zigzag pattern. The resistance might ba a little low for this project though.
#14
I would add a fan to your setup blowing under the steel plate. 25 watt resistors are conservative rating in an enclosed space so with the plate and fan you should be OK for the dissipation. Of course, if you wanted to go the "swimming pool" route, a trip to the store for a couple of gallons of distilled water should add some margin of safety. Pure distilled water does not conduct and is easier to dispose of than mineral oil. When you are done, just add some coffee or tea, sugar and cream to taste, donuts optional. |
#15
Check out this link. http://www.harborfreight.com/cpi/cta...emnumber=90636 This is an auto battery/charging system analyzer but cheap enough to modify for your purposes. You might even rescale the meter and get some sort of go/nogo test rig setup. Enjoy, Larry U. |
