Go to Post Doesn't matter what you use if you can't drive it. - efoote868 [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
  #31   Spotlight this post!
Unread 14-01-2005, 10:43
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: aluminum or steel????
Originally Posted by robolemur1236
Aluminum ... [is] easier to weld and not as messy as steel.
Isn't aluminum significantly harder to weld then steel? Steel can be welded with a torch while aluminum requires TIG/MIG because of its corrosiveness.
Team 1257
  #32   Spotlight this post!
Unread 14-01-2005, 11:48
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Aluminum "cleans up" very well and looks professional and in my opinion, its easier to weld and not as messy as steel.
This statement is just wrong. Aluminum is not easier to weld than steel, and I think anyone who has ever welded in their life would agree with me. Maybe if you're welding stainless or something
2001-2004: Team 100
2006-Present: Team 254
  #33   Spotlight this post!
Unread 17-01-2005, 22:15
dvd_hawk dvd_hawk is offline
dvd_hawk is an unknown quantity at this point
Re: which is better aluminum or steel????
Originally Posted by SCYTE16
which is better aluminum or steel for making an outside of a robot????
aluminum is sturdy and lite but is easly warped or damaged
steel isn't light but is stronger
so it's kinda up to your prefrences and ideas
  #34   Spotlight this post!
Unread 05-05-2005, 16:44
i_am_Doug i_am_Doug is offline
Currently foraging for food..
AKA: Doug
i_am_Doug has a spectacular aura abouti_am_Doug has a spectacular aura abouti_am_Doug has a spectacular aura about
Send a message via AIM to i_am_Doug Send a message via MSN to i_am_Doug Send a message via Yahoo to i_am_Doug
dude yeah aluminum is sooo hard to wield and just get right.
  #35   Spotlight this post!
Unread 05-05-2005, 19:01
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Actually it depends on the alloys being used. Some top grade aluminum alloys, such as 7075, are close in strength to low carbon steels such as 1018. However the steels will be stiffer, that is they will deflect less under a given load, than any aluminum. So you can use a stiff heavy material or a lighter not so stiff material for the same job. How much deflection you can tolerate is the descrimating factor. Many times determining the proper material for a job is pretty difficult. That's why we have Materials Engineers!
Christopher H Husmann, PE
"Who is John Galt?"
  #36   Spotlight this post!
Unread 05-05-2005, 22:46
Not2B's Avatar
Not2B Not2B is offline
AKA: Brian Graham
Originally Posted by Andrew
How come no one talks about riveting? Yet another alternative to welding (permanent) and bolting (removable but heavy).
We riveted this year, and we loved it.
Go to home depot, and for $15 you can get a rivet gun, and for about $5 dollars you can rivet an entire frame. You just have to think a little bit before you rivet. Do it with reckless abandon, and you'll suffer. Do it well, and I think you'll come to love it.
And for that extra bit of permanence - braze. Brazing aluminum is within the financial means and skills of almost every team as long as you follow safe work practices. For the low budget team, Burnz-o-matic makes a cheap kit that works (but the O2 gets pricey if you do too much.) I would encourage you to look up info on welding, brazing, and soldering - find out the difference.
Rivets and Braze - what a good mix IMHO. Low cost and does the job.
Brian Graham
  #37   Spotlight this post!
Unread 05-05-2005, 22:55
Hunter's Avatar
Hunter Hunter is offline
Wood is Good
AKA: Todd Willick
FRC #5184 (Titanics)
Hunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond repute
This year we used very few bolts on our frame, only the side plates were bolted on to allow access to our tracks. We don't have welding capabilites, and our frame is made out of boxtube. Very hard to bolt 2 x 4 tubing without using really long bolts, and risking crushing it. Instead we used 1/4" STEEL pop rivets. They are great, almost as strong as a bolt and easier to put in, and you can do it anywhere easily. The only catch is you need a really big rivet gun. Ours was about 2 feet long and looked more like bolt cutters than a rivet gun.
  #38   Spotlight this post!
Unread 05-05-2005, 23:03
Not2B's Avatar
AKA: Brian Graham
Oh oh... here's how to get around that. We used the 3/16" rivets. Almost 1/4" And you can use a tiny, cheap rivet gun (about the size of an average hammer.)
We did 1/4" rivets last year - that was hard. The rivet gun was actually called the "Big Daddy Rivet Gun". And you can get (2) 3/16" into a 1" X 1" spot.
Sorry - I love rivets!
Arrow's website, the rivets we use
Brian Graham
  #39   Spotlight this post!
Unread 05-05-2005, 23:07
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
We used tons of rivets on the arm. It was all made from flat .040 sheet metal (aluminum) that was lasercut then bent picture In some (higher stress) areas the rivets worked a little loose over time. While it did come out very nice, I still think extruded aluminum box tubing is the way to go for any frames or arms or anything. With the sheet metal we were able to make a very thin wall box for light weight but with extruded box tubing you could just surface (machine) down the sides to make it thin too and it would be stronger because it is one piece.
As for the issue of cracking welds, if you have a good welds then you will not have a problem. If the welds are not coming out nice, then of course they are likely to crack.
You can see a picture of our frame and the nice welds (lower structure, upper structure was a rush job) here picture For the frame itself, it is only 11 lbs. It is all 1/8" wall tubing. Thinking back, we probably could have gotten it down to about another 1/2 lb by going a little narrower on the tubing on the side rails.
The only steel in our robot besides gears, sprockets, and chain is in shafts. All the shafts are steel but some of the larger ones are bored out through the center for weight savings.
  #40   Spotlight this post!
Unread 06-05-2005, 20:37
Captain Rich's Avatar
Captain Rich Captain Rich is offline
I am 245
FRC #0245
Captain Rich is a jewel in the roughCaptain Rich is a jewel in the roughCaptain Rich is a jewel in the rough
Check out different alloys of aluminium. It makes a difference, but costs more. I think the kit frame was an alloy of sort, although I'm not sure what it was specifically. Anyone know?
Richtopia Prevails Again!
http://richtopia.vzz.net www.adamsrobotics.com
  #41   Spotlight this post!
Unread 06-05-2005, 21:31
Cory's Avatar
AKA: Cory McBride
something in the 7000 series, I think.
2001-2004: Team 100
  #42   Spotlight this post!
Unread 06-05-2005, 21:50
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer & Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
I would go with Aluminum - Its easier to play with ( Weight Wise ) Steel is just too hard to lighten up, If you build the frame the right way and Identify and take care of the weaker parts of the frame then everything will be alright. Depending on what stock you use as well will help a robots strength
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
  #43   Spotlight this post!
Unread 06-05-2005, 22:02
Actually, I view the situation as quite on the contrary. It is much more effective to take more wieght out of steel parts because they have more mass per unit volume. Say you want to take a pound out of 1/4" aluminum plate. You'd have to drill 50 1" holes! But if that was steel you'd take out a lot more than one pound with that many holes.
But all the weight you can take out of steel did come from somewhere. It comes from the fact that a steel part is heavier to begin with. So, you can start light with aluminum and if you are still over than there's not a whole lot you can do. Or you can start heavy with steel and if you are over (which you probably will be) you can probably remove a lot. So, it is a tradeoff.
Now, for "ease" of lightening, I suppose you are correct afterall in saying steel is harder to "lighten up" because it is much harder to cut, drill, mill, turn, etc. But, you do get more lbs off for your increased work time.
It is all about tradeoffs.
  #44   Spotlight this post!
Unread 06-05-2005, 22:33
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
I happen to know ... AND
It is listed in the Chassis documentation found here:
http://www.ifirobotics.com/kitbot.shtml
The chassis is made from 5052, H34 Aluminum.
Great stuff, welds niiiiiice.
  #45   Spotlight this post!
Unread 06-05-2005, 22:42
jonathan lall's Avatar
jonathan lall jonathan lall is offline
FRC #2505 (The Electric Sheep; FRC #0188 alumnus)
jonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond repute
Send a message via MSN to jonathan lall
How do you figure it's a tradeoff? You're saying a steel robot (or component) would get more pounds off in the lightening phase, but wouldn't it be far heavier to start off with anyway?
Let's say the aluminum robot I wanted to make would be 150 pounds before lightening. If I were to make a functionally identical robot with steel, it would weigh 250 pounds (the ratio of aluminum to steel's weight of course varies, but it's generally between two and three times as much). Now, bearing in mind you will be able to put a few more holes in the steel robot or use thinner steel, the strength gain from steel (and don't forget in addition to this the higher cost and machining time) would not be enough to use appreciably less material.
In other words, this is no tradeoff, but is very one-sided in aluminum's favour. Bearing in mind this example is a bit impractical in a robot-building sense, a square-inch hole in a steel plate versus a square-inch hole in an aluminum one will obviously not bring the former's weight below the latter's. Which is probably why most everyone uses aluminum on their frames I would say.
Welding stainless steel to mild steel... can it be done? Travis Covington Technical Discussion 3 27-01-2004 19:11
Mini extruded aluminum Ravi U Technical Discussion 7 17-01-2004 02:12
Difference in aluminum archiver 2001 1 23-06-2002 23:49
Let's get some aluminum extrusions archiver 1999 3 23-06-2002 23:12
Legality of steel tubing. newy Rules/Strategy 3 01-02-2002 09:16
