Go to Post You know, sometimes you people get just a little scary.... - JaneYoung [more]
Unread 07-05-2005, 02:32
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: servo range of motion
Originally Posted by tux
I see some sample code in the default code like this ...
Example: The following would generate a 40KHz PWM with a 50% duty cycle on the CCP2 pin (PWM OUT 1):
CCP2CON = 0x3C;
PR2 = 0xF9;
CCPR2L = 0x7F;
T2CON = 0;
T2CONbits.TMR2ON = 1;
Setup_PWM_Output_Type(USER_CCP,IFI_PWM,IFI_PWM,IFI _PWM);
but search as I might, I do not see anything telling what this is all about.
This is from the IR beacon code used in last year's game.
-Kevin
Edit: Actually, it's early beacon code circa November 2003.
Kevin Watson
http://kevin.org
Help with motion detector chantilly_team Programming 13 31-01-2006 22:10
Servo Compact Design Problems!!! Dominator_Legen Electrical 22 07-04-2005 18:15
Servo Help Dominator_Legen Motors 3 11-03-2005 19:50
Camera Range Finding russell Programming 9 31-01-2005 19:54
Anyone received their EDUs already? Manoel Robotics Education and Curriculum 34 21-11-2003 10:28
