Go to Post It's in the RUMOR MILL section, hence it is a RUMOR. Personally I find it entertaining to see what gets started in this particular forum section and have people go off the deep end. - Gary Dillard [more]
Unread 08-05-2005, 12:01
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
Re: pic: Jester Drive:Mecanum Wheel Drive Train
Originally Posted by Alex357
The one roller vs. two roller difference is indeed significant. Two rollers allow for more controlled motion because of better release of friction. One roller wheels have a 50% higher coefficient of friction causing for more draw and no extra pushing power for the cost.
We haven't done any tests on the two roller model, as we decided that the machining difficulty for the hub was be far too great and supporting the rollers from only the middle would be difficult. I highly doubt that it is a 50% higher coefficient of friction - the only way it would hurt you is if one roller was going to be spinning at a significantly different speeds. I'm no ME (I'm an EE), but doesn't the coefficient of friction deal with the actual force you apply to the ground, meaning you would actually have more pushing power? I agree that the two roller design is better, obviously Airtrax had a reason for using it, but I think you are blowing it out of proportion a bit. The single roller design is much easier to manufacture, although it is more parts. (The hub is simply a piece of square 3x3 aluminum stock with the corners cut off). We had absolutely no issues with pushing power.
pic: Tribotec Brazil - Drive Train tribotec_ca88 Robot Showcase 5 07-02-2005 03:48
pic: Team 870 Front Drive Train CD47-Bot Robot Showcase 4 27-02-2003 15:23
pic: Team 870 Rear Drive Train CD47-Bot Robot Showcase 2 27-02-2003 00:22
pic: Team 980 "Thunder Bot" drive train CD47-Bot Robot Showcase 12 25-02-2003 14:02
pic: 311's Drive Train CD47-Bot Robot Showcase 2 24-02-2003 18:09
