Go to Post I would like to think that I would be considered smart no matter who I was. - Kelly [more]
Unread 09-05-2005, 11:56
AKA: Dr. Brooks
no team (WRRF)
Re: Concept of PID explained
Originally Posted by billbo911
Curiosity question here.
I noted significant differences between your paper and the IFI documents when it came to variable types and their ranges, primarily "int". Again I'm pleading ignorance here as I'm so new to coding. Why are they different?
There are two tables in the paper. Table 1 is for EiC, the freely available
C interpreter used in the paper as a learning tool. Int is a 32 bit object
in EiC, with the associated signed and unsigned range. Table 2 is for
the C18 compiler used for the robot controller, where int is a 16 bit
type, with the associated signed and unsigned range. The text discusses
the issue. I hope that Table 2 is consistent with the data in IFI documents,
and the MPLAB C18 compiler documentation, it has been checked in
the past.
If you note a difference, please identify the document and page number.
Unread 09-05-2005, 12:17
billbo911's Avatar
billbo911 billbo911 is online now
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
the past.
Sorry for the confusion. I did not look beyond Table 1. I assumed, and there lies the problem, that the first table I came across covered what I was looking for.
Either way, you were correct about the "int" declaration, it would have worked regardless which table I looked at.
Thanks again.
Unread 27-01-2008, 00:11
DarKCroNo's Avatar
DarKCroNo DarKCroNo is offline
FRC #2670
DarKCroNo is an unknown quantity at this point
is there a way to apply this concept onto easy C? Sorry but it's our rookie year and we have no clue what we're in for, but basically we have gone for a design of 3 wheels, 2 being powered by a motor and running on an axle, and 1 in the front being steered by another motor, but the problem that arises is that after steering the motor to the left what I want to do is when the joystick is back at the centre position I would like the wheel to also move back into the centre position. I've been doing alot of research on PID closed loops, but all I've been getting is the theory behind it and I have no clue how to apply the programming for it. We went with easyC and I'm wondering if it works with it. Thanks in advance!
PID cmd_drive can't drive straight? gnormhurst Programming 4 18-02-2005 01:54
Drive Straight C Code using Encoders without PID? Chris_Elston Programming 17 15-02-2005 23:41
All-Time PID Drive with Hall-effects: Coming along very nicely jdong Programming 6 05-02-2005 19:39
Whegs, PID, and climbing phrontist Technical Discussion 9 02-05-2004 00:21
PID control loops - closed loop feedback KenWittlief Technical Discussion 56 26-04-2004 21:27
