Go to Post I am the person I am because I have come to accept the mistakes I have made, not because I try to change them. - IronicDeadBird [more]
Unread 06-05-2005, 09:23
pagemauck pagemauck is offline
pagemauck is an unknown quantity at this point
internal demons?
We're at our wits end! Two of my C++ students and I are programming with the banner sensors to control wheel rpms. The program will run correctly for a few runs and then inexplicably decide to switch motor outputs ( from pwm01 to pwm02 or whatever we have them set to) and inputs from the light sensors . This has been happening for several weeks. I have redownloaded the master control program, swapped controllers, used different digital inputs ( 6 and 7 or 1 and 2) to no avail. Has anyone had this happen to them before?
Thanks!!
Team 539 programming group
Unread 06-05-2005, 10:42
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
Re: internal demons?
Runtime errors are seldom, if ever, inexplicable.
Usually occur when memory gets hammered. Check to see if a string or array is getting written to past its declared end.
This message is hidden because Jack Jones is on your ignore list.
Unread 06-05-2005, 10:51
kc8nod's Avatar
kc8nod kc8nod is offline
AKA: Ted Hansen
FRC #1216 (Knights)
kc8nod is on a distinguished road
It's very difficult to help you without any specifics. Please post the section of code where you think the problem is. Or better yet, zip up all the .c and .h files and attach them to your post.
The limited description you have given really sounds like a software problem. But you won't get any real help without posting the code.
Originally Posted by pagemauck
We're at our wits end!...
Unread 07-05-2005, 23:30
Goldeye Goldeye is offline
AKA: Josh Hecht
FRC #0694 (Stuypulse)
Goldeye has a spectacular aura aboutGoldeye has a spectacular aura aboutGoldeye has a spectacular aura about
Send a message via AIM to Goldeye
First impulse is that you're using a high priority interrupt. Anything can go wrong when you do. Post any code related to interrupts, if you use them. This is assuming you're using interrupts with them, of course. I suppose there's no guarantee of this.
Team 694
2005 Championship - Galileo Semifinalist
2005 New York - Regional Chairmans Award
2005 New York - Semifinalist (Thanks 1257,1340)
Unread 09-05-2005, 09:35
Thanks for the replies to my vague question. Specifically what I'm seeing is outputs switched in the printf statements. Does anyone know of a good place to find info on them?
Example :
(We are trying to print motor speed and banner sensor output)
printf ( "%d/n", " pwm01 = ", pwm01 );
printf ( "%d/n", " rc_dig_01 = ", rc_dig_01 );
Output
pwm01 = 1
rc_dig_01 = 145 // these numbers are switched
How do we rewrite the printfs to get what we want?
Thanks!
Unread 09-05-2005, 10:42
That doesn't look right at all. Try this instead:
printf(" pwm01 = %d/n", pwm01);
printf(" rc_dig_01 = %d/n", rc_dig_01);
Also, make sure you're not trying to do printf() inside any of the interrupt service routines.
Unread 09-05-2005, 10:51
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
On top of that you want to use \n instead of /n.
printf(" pwm01 = %d\n", pwm01);
printf(" rc_dig_01 = %d\n", rc_dig_01);
Depending on what you're using to view the output, you may need to substitute a \r for the \n.
Unread 09-05-2005, 10:57
kc8nod's Avatar
AKA: Ted Hansen
FRC #1216 (Knights)
Two things:
First, that doesn't look like proper use of the printf function. I think you meant to write this:
printf ( "pwm01 = %d/n", pwm01 );
printf ( "rc_dig_01 =  %d/n", rc_dig_01 );
Is that really the code you are using? Because I wouldn't think that what you have shown above would even compile.
Secondly, you still haven't given very much information. You'll notice that all the replies so far (including my own) have been guesses and speculation. Please post the whole function at a minimum. However, if you post all the code, I guarantee that someone here will fix your problem for you right away.
Unread 09-05-2005, 11:02
kc8nod's Avatar
AKA: Ted Hansen
FRC #1216 (Knights)
Here is a pretty good explanation of the printf() function.
http://colton.byuh.edu/courses/tut/printf.pdf
Unread 09-05-2005, 15:10
AKA: Dr. Brooks
no team (WRRF)
Originally Posted by kc8nod
Don't forget to cast the "byte sized" arguments to printf,
intended to be formatted with %d, to an int. Byte sized
things get pushed on the stack as bytes, while printf
is expecting an int. This is a vagary of the C18 compiler
environment for the robot controller, and is non-standard.
This addresses bad values printed by printf, but probably
not the trouble you are trying to debug...
Unread 09-05-2005, 16:00
kc8nod's Avatar
AKA: Ted Hansen
FRC #1216 (Knights)
Originally Posted by eugenebrooks
Don't forget to cast the "byte sized" arguments to printf...
Good point!
So then, the proper code would be:
printf ( "pwm01 = %d\r", (int)pwm01 );
printf ( "rc_dig_01 =  %d\r", (int)rc_dig_01 );
Unread 09-05-2005, 17:32
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Actually, it will. The compiler only knows that printf() takes a string as the first argument, and then zero or more arguments of any type. It does not type-check these arguments and the argument list is parsed at runtime. The way it was originally written, after the format string is another string, but the printf() function would try to interpret this as an integer (because of the %d in the format string).
Internal vs. External Gear teeth - same profile? sanddrag Technical Discussion 7 01-03-2005 10:44
Change from External to Internal teeth sanddrag Inventor 10 27-02-2005 23:59
Where to purchase internal gears? sanddrag Technical Discussion 3 27-02-2005 05:22
Fisher Price Internal Fan Blades sanddrag Motors 8 06-02-2005 14:27
Speed loss due to internal friction patrickrd Technical Discussion 1 23-01-2002 22:12
