Go to Post My first instinct was inflatable clowns and 5 of them beating on the robots at all times, but then I thought, thats probably not right. - Dan Richardson [more]
Unread 09-05-2005, 23:31
Re: One Joystick Drive
Originally Posted by mattsavela
(For example: When we turn left, the right motor spins a bit faster than the left motor, and when we turn right, the left motor spins a bit faster than the right motor, which I may have worded incorrectly in the original post)
What you're describing sounds like it's working properly. If you think it's a problem, there's obviously something you're not getting across to us.
Unread 10-05-2005, 15:16
mattsavela mattsavela is offline
FRC #0255
mattsavela is an unknown quantity at this point
Thats what we want the motors to do. At the moment, it looks like they are both moving at the same speed when we turn
Unread 10-05-2005, 16:05
At the moment, it looks like [the motors] are both moving at the same speed when we turn
Sorry, I'm still not getting it. What makes you think the motors are at the same speed? Unless you're doing something you haven't mentioned, it wouldn't be turning if the motors aren't running at different speeds.
Unread 10-05-2005, 18:00
FRC #0255
Im not positive about that. I'll let you guys know more on Thursday when I get a chance to test it in the pool with new code you guys helped with.
Also, the first code the Mark posted, when I put it in MPLab, it won't compile. I think I may be doing something wrong considering that I am new to programming, but when I take it out, it compiles fine. Any ideas?
Unread 11-05-2005, 08:31
Let's narrow the problem down.
What "baseline" code are you starting with? The IFI 2005 v2.2 default code (http://www.ifirobotics.com/docs/frc-...2-2005v2.2.zip) or something else, such as your team's 2005 modified code?
The code in my first post was quoted verbatim from the v2.2 default code and wouldn't have to be added. The default code already does what you want. The MPLAB problem you're encountering can be caused by lots of simple mistakes, especially if you've never used it before. It might be misplaced code, or if you aren't starting with the default code then the function Limit_Mix might be missing. Whenever you get an error you want to ask the forum about, post (copy and paste) the actual error message. That usually tells us all we need to know to solve the problem.
As an aside, you'll need to be sure the correct motor pwms are being used.
If you are starting with your team's customized 2005 code then post a zip of the user_routines.c file, so we can see what's been modified and how. Then we'll be able to describe the easiest may to add the one joystick lines if they aren't already there.
Unread 11-05-2005, 15:06
FRC #0255
I attached my userroutines.c file
Unread 11-05-2005, 16:01
A couple of simple issues.
  • The code for joystick control is in the Default_Routine() a few lines below the Process_Data_From_Master_uP routine(). The 1-Joystick code starts there on line 226 (in the version I attached). (In MPLAB look under Edit -> Properties and check "line numbers" if you don't already see them.)
  • There was a ". . ." in my example above that isn't code and needs to be removed (sorry about that).
  • Set both the MOTOR_CORRECTION's to zero to begin with. You'll only need to adjust those values if the operator cannot manually correct for the robot pulling to one side or the other. I don't know how hard it will be for your operator to see the robot underwater.
  • Make sure your drive motor pwms are connected to pwm 13 (right motor) and pwm 15 (left motor).
I've attached a modified version, so you can see what I meant.
the new code is at lines 204-205 and 239-255.
What you wrote originally will actually work, but would be confusing to anyone reading the code, because it does all the joystick work in Default_Routine() then overrides it all in Process_Data_From_Master_uP().
Anyone else have comments to add?
Unread 11-05-2005, 23:25
FRC #0255
We have cameras attached to our robot, so we can't actually see our robot, but we can see from certain perspectives.
Thank you guys so much for helping me with this.
Unread 12-05-2005, 08:36
We'd like to see photos and hear about your progress, so don't forget about us here on the ChiefDelphi forums.
Good Luck!
Unread 12-05-2005, 17:37
FRC #0255
We have an online album of pictures. I'll check with our coach to make sure that I can give the link out.
Unread 13-05-2005, 16:20
FRC #0255
http://photobucket.com/albums/v660/lhsrobotics/
http://photobucket.com/albums/y205/lhsrobotics1/
Those are the two links to our photo albums.
Unread 13-05-2005, 23:35
N7UJJ N7UJJ is offline
Teacher
AKA: Allan Cameron
FRC #5465 (BinaryBots)
N7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond repute
I assume you are going to the MATE championship in Houston.
If so be sure to look for us. We also use the FRIST controller equipment on our ROV except we put the robot controller and the battery on the ROV. It allows us to use a small diameter tether which really helps the maneuverability.
Looking forward to meeting y'all
Allan
If you could change one thing.... Koko Ed General Forum 48 31-03-2005 19:23
1 Joystick Drive or yaniv Programming 3 19-01-2005 14:18
Changing 1 joystick code to 2 (rookie team) Brawler006 Programming 5 20-02-2004 17:00
question about one joystick drive programing james700 Programming 13 29-01-2003 14:49
1 joystick drive Rickertsen2 Robotics Education and Curriculum 9 20-12-2002 20:00
