Go to Post Pro safety tip: put a string through coil springs that is tied off securely on the robot frame. This will help prevent the spring from jumping out and killing an inspector if it snaps. - Ninja_Bait [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
  #42   Spotlight this post!
Unread 12-05-2005, 05:23
suneel112 suneel112 is offline
AKA: the angry designer on 461
#0461 (Westside Boiler Invasion)
Team Role: Student
suneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud of
Send a message via AIM to suneel112
Re: which is better aluminum or steel????
Originally posted by: JVN I recommend checking out:
http://www.matweb.com
Lots of cool information there. You can plug in values to your heart's content.
I definitely agree with that one. Now to mention Matweb, there are some pretty cool aircraft aluminum alloys that would be pretty useful to building a frame and other robot components. By pretty cool, I mean pretty hard, with an ultimate tensile strength of 83,000 psi. Check out the Aluminum 2400s and Al 7475 if you want the high-strength stuff. Most of the 2400s have ultimate tensile strengths in the 60,000's, are moderately weldable, and fairly machineable.
I'm back like the greatest, from a four year hiatus,
Haters cry later, I'm just getting my paper.
Welding stainless steel to mild steel... can it be done? Travis Covington Technical Discussion 3 27-01-2004 19:11
Mini extruded aluminum Ravi U Technical Discussion 7 17-01-2004 02:12
Difference in aluminum archiver 2001 1 23-06-2002 23:49
Let's get some aluminum extrusions archiver 1999 3 23-06-2002 23:12
Legality of steel tubing. newy Rules/Strategy 3 01-02-2002 09:16
