Go to Post You people are weird... Now if you'll excuse me, I have some code to debug and I need to figure out where to get tank tracks. - sciguy125 [more]
Unread 09-05-2005, 03:04
swordfish7 swordfish7 is offline
swordfish7 is an unknown quantity at this point
lego programming
hey, kinda new to lego robotics programming here. I have a competition coming up where we have to make robots that combat one another in an obstacle course. I was wondering if anyone knew any commands that would disable a robot through infrared signals.
Thanks.
Unread 09-05-2005, 03:11
Vu2000 Vu2000 is offline
Midnight Mechanic
None #0812 (Midnight Mechanics)
Vu2000 has a spectacular aura aboutVu2000 has a spectacular aura about
Send a message via AIM to Vu2000 Send a message via MSN to Vu2000
Re: lego programming
Wow you should check with your competition rules to see if that is allowed. I know Botball and FLL strictly prohibit it, but maybe your competition is a free for all.
Peace up; A-Town Down
2006 So Cal Chairman's Award!!!
2005 So Cal Chairman's Award
2005 So Cal Safety Honorable Mention (safety captain)
2004 Championship Engineering Inspiration
2004 So Cal Engineering Inspiration
Unread 09-05-2005, 07:15
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Even if it was legal, I doubt that you could get either the RCX or the Scout to send the command you need, the Stop command. It comes from the remote that you can buy for the RCX and is just like pressing the Run button after the program has been started, it stops the program. Also, from this remote, you can start any program on the robot (1-5) and make it play a test tone. Good luck.
Aren't signatures a bit outdated?
Unread 09-05-2005, 10:12
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
It is possible to do what you want, but you have to go very advanced.
To have direct access to the IR port, you have to use an alternate firmware, such as BrickOS or http://lejos.sourceforge.net/]LeJOS. Installation of either of these (especially BrickOS) is extremely difficult on Windows systems. I've never used either on Linux, but the installation should be (in theory), slightly easier.
BrickOS allows you to program the robot in C or C++, while LeJOS uses Java.
--EDIT--
As warned above, check the legality of sending shutdown commands to the RCX. Also, check if alternate firmware is allowed.
Unread 09-05-2005, 10:58
Alexander McGee's Avatar
Alexander McGee Alexander McGee is offline
Hoonigan
AKA: Alexander S. McGee
no team (no team)
Alexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond repute
Send a message via AIM to Alexander McGee Send a message via Yahoo to Alexander McGee
Yes, I have done just this.
You must use lejOS running some other software package (i used java). You then set up a command which sends out a fury of commands, (such as stop, reverse, etc). The only downfall of this is the limited range of the IR transmitter on the RCX.
It's definitely worth playing with!
-Alexander S. McGee
Intellectual Property Attorney, Mechanical Engineer, Gear-head
Unread 12-05-2005, 01:26
thanks a lot for the help. I might try playing around with that. I'm doing a combat obstacle course. It's pretty much a free-for-all. I think there is a simpler way in this case though. the other robots have to be programmed to recieve a remote signal "message() ==1" to shut them down temporarily so if they don't immediately disable their IR imput I'll be able to broadcast this message and shut them down.
I will try some of the more complicated stuff you talked about though. Thanks a lot!
Unread 12-05-2005, 01:30
One more question:
I'm programming in NQC with Bricx Command Center. Can i broadcast the right signals using this language/compiler?
Otherwise I know the java language and I'll probably try leJOS.
thanks
Unread 12-05-2005, 07:07
Programming User
I don't think so, but I could be wrong. You could send the IR message 1, of course.
Unread 12-05-2005, 08:18
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
we had alot of fun with this...
Programming - Getting Started Mark McLeod Programming 80 16-04-2008 23:37
Lego 1-Day event ideas Andrew Schuetze Fundraising 5 28-07-2004 17:58
LEGO programming 811SmallFry FIRST Lego League 20 27-06-2004 07:35
**IMPORTANT FIRST EMAIL**/Statement about LEGO MINDSTORMS and FIRST LEGO League miketwalker FIRST E-Mail Blast Archive 1 15-01-2004 16:47
LEGO Biped Project rlowerr_1 Robot Showcase 23 07-09-2003 14:21
