Go to Post ...some of our robots could use a proctologist - Scott Ritchie [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
  #46   Spotlight this post!
Unread 11-05-2005, 18:36
Ctrl Alt Delete's Avatar
Ctrl Alt Delete Ctrl Alt Delete is offline
Code Monkey
AKA: David Weitz
FRC #0177 (Bobcats)
Ctrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to behold
Send a message via AIM to Ctrl Alt Delete Send a message via MSN to Ctrl Alt Delete
Re: aluminum or steel????
aluminum is fun to weld.... It is a good building material and light-weight. I really don't care because I'm not the one on my team that welds.
Life lessons learned at robot:
1.) Never take apart power strips
2.) Sleep is required, but not essential to survival
Failure to abide by these lessons will result in headaches...and flaming pants.
"Here at Bobcat Robotics, we pride ourselves in having 60-table MySQL databases, girlfriend cookies, and a vinyl cutter." -Chris Jelly
  #47   Spotlight this post!
Unread 12-05-2005, 05:23
suneel112 suneel112 is offline
AKA: the angry designer on 461
#0461 (Westside Boiler Invasion)
Team Role: Student
suneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud of
Send a message via AIM to suneel112
Re: which is better aluminum or steel????
Originally posted by: JVN I recommend checking out:
http://www.matweb.com
Lots of cool information there. You can plug in values to your heart's content.
I definitely agree with that one. Now to mention Matweb, there are some pretty cool aircraft aluminum alloys that would be pretty useful to building a frame and other robot components. By pretty cool, I mean pretty hard, with an ultimate tensile strength of 83,000 psi. Check out the Aluminum 2400s and Al 7475 if you want the high-strength stuff. Most of the 2400s have ultimate tensile strengths in the 60,000's, are moderately weldable, and fairly machineable.
I'm back like the greatest, from a four year hiatus,
Haters cry later, I'm just getting my paper.
  #48   Spotlight this post!
Unread 12-05-2005, 10:50
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
In general, in material science, you want to maximize one property while minimizing another; in the case of the chassis of a FIRST robot, the two important properties are weight and stiffness. Because of this, it is often meaningless to compare just the tensile strength, or just the density of two materials. Rather, it is more useful to compare the ratios of these two properties for a given material. In the case aluminum and steel, the ratio of stiffness/density is actually comparable in high strength alloys of both (though by no means insignificant). Because most FIRST robot designs are hardly very well optimized with respect to stiffness/density, other considerations become more important in deciding what material to use. Several important differences between steel and aluminum that make aluminum usually the better choice are
  1. it comes in much thinner walled tubing than steel (more efficient shape)
  2. easier to machine
  3. lower density (makes simple, inefficient designs made from solid stock less costly in weight)
I sort of explained all this in another post and gave some ratios for certain materials (http://www.chiefdelphi.com/forums/sh...647#post307647). I realized now that I used ultimate tensile strength while Young's modulus would be the correct measure for stiffness, but the comparison is still somewhat valid.
Team 1257
  #49   Spotlight this post!
Unread 22-11-2005, 15:40
Alex Burman's Avatar
Alex Burman Alex Burman is offline
∆o□
AKA: The Burmanator
FRC #0075 (Roboraiders)
Alex Burman has much to be proud ofAlex Burman has much to be proud ofAlex Burman has much to be proud ofAlex Burman has much to be proud ofAlex Burman has much to be proud ofAlex Burman has much to be proud ofAlex Burman has much to be proud ofAlex Burman has much to be proud of
Send a message via AIM to Alex Burman Send a message via MSN to Alex Burman Send a message via Yahoo to Alex Burman
is it limited to just Al and Steel because i used to play lacrosse and some of the shafts were made from some weird yet very light and strong alloys like a Zinc alloy Shamrock r705
Scandium Brine Sc21
various carbon composites
and countless aluminum alloys
The Burmanator
www.Roboraiders.com
http://www.myspace.com/burmanator
  #50   Spotlight this post!
Unread 22-11-2005, 16:42
Wayne C.'s Avatar Unsung FIRST Hero
Wayne C. Wayne C. is offline
hey- I think we did pretty good?
FRC #0025 (Raider Robotix)
Wayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond repute
Originally Posted by team222badbrad
Not sure what you mean by "angled outside"? We have used aluminum for our frames since we started building robots. Yes It bends every now and then, infact we bent team 25's steel diamond plate in 2003.
Actually Brad- the diamond plate we used is aluminum. Steel is too heavy.
Man- I didn't know we were that much of a target..... ; )
WC
you want that robot to do what?
Raider Robotix- www.raiderrobotix.org
  #51   Spotlight this post!
Unread 24-11-2005, 13:35
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
For those who say welding steel is harder than aluminum - are you crazy? Maybe I'm doing something wrong? Aluminum conducts the heat far quicker than steel, which makes it tricky to get that TIG weld just right. When I TIG steel material, the puddle stays put and you don't have to constantly play with the pedal as much.
Also, plan your weight carefully so you don't have to deal with lightening holes. I know some teams have resources to mill several hundred holes in their frame, but spending hours and maybe days drilling and milling holes is probably not a good use of time. We made a change last year from a two level frame to a single level frame and instead of just using 1x1 box aluminum everywhere, we switched to using C-channel for the internal struts of the frame and just kept the box material around the perimeter. We also better planned our use of 1/16" thick aluminum for the non-stressed parts of the robot. Also we switched to nylon hubbed sprockets where possible. How nice it was to have our robot done days ahead of the deadline and 9 pounds underweight.
Welding stainless steel to mild steel... can it be done? Travis Covington Technical Discussion 3 27-01-2004 19:11
Mini extruded aluminum Ravi U Technical Discussion 7 17-01-2004 02:12
Difference in aluminum archiver 2001 1 23-06-2002 23:49
Let's get some aluminum extrusions archiver 1999 3 23-06-2002 23:12
Legality of steel tubing. newy Rules/Strategy 3 01-02-2002 09:16
