Go to Post We win as a team and lose as a team. - Zuhaib Ali [more]
Unread 12-05-2005, 20:28
Morenoh149
Posts: n/a
All FRC sensors
Sorry if a similar thread has been posted before but I need to find out what to do this summer.
I was wondering What were ALL the sensors allowed in this 2005 FRC game?
And any whitepapers on using them or websites with example code.
How compatable are they with the EDU RC?
Thanks =)
Unread 12-05-2005, 22:04
Goldeye Goldeye is offline
AKA: Josh Hecht
FRC #0694 (Stuypulse)
Goldeye has a spectacular aura aboutGoldeye has a spectacular aura aboutGoldeye has a spectacular aura about
Send a message via AIM to Goldeye
Re: All FRC sensors
The robot rules allow you to use any electronics component that costs less than $200 off the shelf. Therefore, I'm sure you can find all kinds of sensors that can legally be used. The common ones used include: The camera (:O), potentiometers, accelerometers, gyros, wheel encoders (optical and magnetic/gear tooth counters.) I've also heard of magnetic proximity sensors.
Almost all sensors (excluding the camera and any other TTL/Serial port device) are compatible with the EDU-RC. In general, if it runs on PWM, it'll work on either.
Both the FRC and EDU-RC use the same processor, and very similar code. With some minor adjustments for how you refer to the pins you're using, code for sensors can easily be transitioned between the two.
When you have a specific type of sensor in mind, you should search the white papers and forums, and ask any questions you have here. There is a lot of code for accelerometers, gyros, and encoders, as well as tutorial code for using interrupts, and for using the serial port to communicate, at Kevin Watson's site, http://kevin.org/frc.
Team 694
2005 Championship - Galileo Semifinalist
2005 New York - Regional Chairmans Award
2005 New York - Semifinalist (Thanks 1257,1340)
**FIRST EMAIL**/2005 FRC Game Design Communication to FRC Teams Goobergunch FIRST E-Mail Blast Archive 1 06-01-2005 09:29
Why not analog sensors?? gnormhurst Programming 16 07-03-2004 16:14
FRC Program State Frozen at Power-up WillyC Control System 4 14-02-2004 18:05
