Go to Post we learned that's what happens when you start building without even thinking about weight. next year, we'll lighten everything BEFORE we mount it. - greencactus3 [more]
Unread 17-05-2005, 00:18
ChrisCook's Avatar
ChrisCook ChrisCook is offline
We accelerate!
FRC #0670 (Mustang Robotics (HRT))
ChrisCook has a spectacular aura aboutChrisCook has a spectacular aura about
Send a message via AIM to ChrisCook Send a message via MSN to ChrisCook Send a message via Yahoo to ChrisCook
Exclamation How did you control your Robot? 1? 2? Wheel? How?
How did you control your robot?
What did you see that you liked?
670 used a negative feed back loop for its rear wheel diff system this year. This was controlled by a wheel and stick method. The stick to regulate power to the front wheel drive system, and the wheel to have semi-real time steering feedback.
Next year we are going to use the same control unit but the robot will be 6 wheel tank and the steering will be all software controlled. In the past we have used the "tank" method of driving but we found that it always drifted after a while. Team 254 solved that problem, they used the stick and wheel method only now when the wheel turns software sends exact opposite values to each side of the robot, this removes the problem of "human error" in driving.
Tell me how you did your steering or control unit.
HRT Mentor --- We accelerate!
Unread 17-05-2005, 00:43
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: How did you control your Robot? 1? 2? Wheel? How?
We just use two sticks and drive it like a tank because it is built like a tank. I am strongly opposed to a one stick drive for anything that is built like a tank. It would be more suited to an omnidirectional robot.
As far as a steering wheel goes, when I first saw 22 and 254 using a wheel to drive their tank-like machines, I thought they had gone out of their minds. But then I watched how effective 254 was in game play easily maneuvering around obstacles even while driving in reverse.
Then at the JPL open house this past weekend, we got to do a few very high speed runs (in reverse too) with ours and we found that it is not all that easy easy to keep it straight and maneuver around obstacles while going at that kind of speed (14fps) by controlling it with two joysticks.
So now I'm beginning to think a wheel might be worthwhile to try. It seems like it would allow for very smooth arced driving lines if desired.
The key to it's success though is getting feedback from the shaft encoders on the robot.
Unread 17-05-2005, 05:16
Ali Ahmed's Avatar
Ali Ahmed Ali Ahmed is offline
FRC #0004 (Team 4 ELEMENT)
Ali Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to behold
We currently use the wheel stick method. I like it a lot and with a gyro to keep it driving straight it works fine. It gives you a lot of control. In the past we have used both one and two stick configurations. Out of those two, I would have to go with the two sticks for a tank drive.
Student: Team 22
Mentor: Team 4
Unread 17-05-2005, 07:21
Billfred's Avatar
Billfred Billfred is offline
If I were driving, I'd take two sticks.
But this year, 1293 used one stick for drive. We've got a pretty hardcore gamer as a driver this year, so he's pretty used to it.
Unread 17-05-2005, 07:37
Denman's Avatar
Denman Denman is offline
Tie Wrap-Not Cable Tie or Zip tie
AKA: Stephen Denman
FRC #0759 (Systemetric)
Denman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud of
Send a message via ICQ to Denman Send a message via AIM to Denman Send a message via MSN to Denman Send a message via Yahoo to Denman
in a perfect world i would have asked for 2 sticks.
However we used one and it seems to be fine.
Also we were thinking of steered wheels but me and the other guy building them kinda didn't get anywhere near finishing them. Anyone else manage?
I am an ex-member of team 759.
759: regional winners with 522 and 233 NYC (2004)
FIRSTWiki.org - Contribute, learn, inspire.
"Teach the way of the GP and the way of the GP shall teach you" - Me
Unread 17-05-2005, 10:15
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Two sticks here.
Unread 17-05-2005, 11:14
Meyerman Meyerman is offline
Meyers #37, Pink Petunia's!
AKA: Meyers
FRC #0056 (RoBBE Xtreme)
Meyerman is a splendid one to beholdMeyerman is a splendid one to beholdMeyerman is a splendid one to beholdMeyerman is a splendid one to beholdMeyerman is a splendid one to beholdMeyerman is a splendid one to beholdMeyerman is a splendid one to behold
Send a message via AIM to Meyerman Send a message via Yahoo to Meyerman
lol same as everyone that posted before me we have i guess always used 2 joysticks , 2003 we had the robot set up with a steering wheel but that driver liked the 2 joysticks better soo we put the wheel in storage. our operator now that will most likely be driving in 2007 loves the steering wheel sooo i cant wait to get her behind that wheel.
Unread 17-05-2005, 19:31
ConKbot of Doom ConKbot of Doom is offline
Team Alumni
FRC #1184 (Cobra Robotics)
ConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura about
I built a splitter box with a few switches. We had 2 joysticks hooked to the box. The driver could configure it for 2 joystick drive, or 1 joystick drive and even select which stick they wanted to use. I did that in case we had joysticks that weren't ambidextrous (but we ended up with the 2003 flight sticks, so it didn't matter.)
That way the driver couldn't complain they didn't like the control setup, because they could switch it on the fly during a match.
For the arm operator, (me...) I had a project box with a db-15 cable coming out of it. It had a double momentary ( (on)-off-(on) ) switch for up and down of the arm, and a pot to control the speed. Most of the time I left the speed all the way up, but it was easy enough to turn down for when I needed to be gentle. (not that often just putting the arm away)
I also had other switches on the box for our unfolding hook (that didn't work and got replaced with a fixed hook) and our latch to keep the arm for back driving, (which really wasn't needed so it was taken off) and selection of our autonomous mode, (I never got the selection working, so that was never needed either. I just left it on our "good" mode)
The driver drove, and had nothing else to fiddle with, and the arm operator did all the arm stuff, and I would have to say with a good team, we worked fairly well.
2005 Philly #1 seeded team, highest average points, and semi-finalists
Thanks to 103 and 484 for being alliance mates.
Unread 17-05-2005, 21:12
CyberWolf_22's Avatar
CyberWolf_22 CyberWolf_22 is offline
Programming and Electrical Mentor
AKA: Allen Gregory
FRC #2587 (Afrobots)
CyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really nice
Team 647 uses one joystick drive to allow the operator to have complete control of the robot using only two joysticks. The reason for this is because we have never found a team of drivers that can work as well and make decisions on the fly as well as one driver can alone.
Unread 17-05-2005, 21:41
slickguy2007 slickguy2007 is offline
Copioli is the man!!!
FRC #1403 (Cougar Robotics)
slickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond repute
Send a message via AIM to slickguy2007
We go pretty simple. 2 joysticks to drive with, 1 joystick for the up and down motion of the arm. The operator also has a switch box in order to control the pneumatics for the arm. I am gonna push for the steering wheel next year though, sounds fun !!!
GO 1403!!!
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
Robot Weight Limit: Rule Conflict Specialagentjim Rules/Strategy 10 06-08-2005 17:52
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
more control options smokescreen Technical Discussion 17 05-03-2002 15:41
robot control emulator for default or other program CharlieWilken Programming 26 24-02-2002 02:36
