#9
Re: Chain..... How you do it properly?
This movie shows as far as I got with this problem. The links are actually constrained tangent to a hidden chain path (like J's famous "chainer"). It would lock up with more links and also when the three links got to the end of the straight path and tried to transition to the curve on the left end.
The links are actually "pulled" by a hidden block which is constrained to the path and is moved by the animator dial. Without the chain links holding it up, it would follow the whole path around. This was done in Inventor 6 a couple of years ago, btw. |
| Chain Drive chain | Damelvin | 3D Animation and Competition | 2 | 15-02-2005 00:19 |
| chain ridding up and off sprocket problem... | davidhoare | Technical Discussion | 4 | 04-02-2004 10:13 |
| 25 or 35 chain? | Alan Ing | Technical Discussion | 24 | 02-03-2003 13:56 |
| 1/4" chain and links from small parts | archiver | 2001 | 2 | 24-06-2002 00:18 |
| Chain and chain breaker source? | kmcclary | Off-Season Events | 4 | 22-10-2001 22:51 |
