Go to Post It's often not the code you are focused on that causes problems, but the code you dismiss out of hand as "unrelated". - Mark McLeod [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 17-05-2005, 12:34
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Sortable table for use on webpages
Can anyone point me in the direction of a better sortable table that I can use on a webpage?
I found this one: http://javascriptkit.com/script/script2/sorttable.shtml
While it works for regular text as shown on our website here: http://www.team237.com/members.htm
I would like to use it on my own site but incorporate links in the table, and also images, and sort by the link url, or image name I don't see why this should not work. My thinking is that it should recognize the
The problem I found is that this Java Script based table ignores the sorting of the standard html formatting tags such as:
 <td><a href="http://www.imdb.com/title/tt0098987/" target="_blank"><center>Link</center></a></td>
While it sorts the word "Link" and actually does center it by using the <center> commands, it does not sort the link itself as you click on the top header to sort the columns.. It basically leaves the link in the same place within the table, but moves the word "Link" to Alphabetical order.
This is really irritating.
By the way, the table sort js code depends on an external .js file that came with the table's examples which you have to place in the same root directory as your html file that is using the code.
edit: I'm not to familiar with Javascript, but could my problem be that this external .js file is not defining the html image tags as something to sort??
Just a thought..
Is there any other way to code a sortable table that will recognize the html center and image tags as something to organize as well??
edit: What is used to sort the info on this page?
http://www.chiefdelphi.com/forums/memberlist.php?
Php?? Can that be used with images and links?
This will also be helpful to know for the teams site to link pics to the people's individual names in the future.
Unread 17-05-2005, 13:45
dshidler dshidler is offline
#0999 (CRASH)
Team Role: Driver
dshidler is an unknown quantity at this point
Send a message via AIM to dshidler
Re: Sortable table for use on webpages
Just a thought..
PHP and MySQL is how that page is sorted.. The query to the MySQL database sorts it a certain way then will return it to you in a certain way... for example..
<?php
//Connect to the DB, you can either include a file that connects for widespread use..
include_once("./DB_Connect.php");
$request = mysql_query("SELECT * FROM `members` SORT BY `name` ASC");
echo '<table... blah blah';
while ($info = mysql_fetch_array($request))
  echo '
       <tr>
          <td><a href="./members.php?id=', $info['ID'], '">', $info['name'], '</a></td>
       </tr>'; //echo out member info..
echo '</table>';
mysql_free_result($request); // Not needed, just used to clear out the memory
Of course that isn't a full example, but it gives you the basic idea of how you could do it with PHP. As far as sorting with HTML/JavaScript i'm not sure how to do it. If you find something that does work, check that it works in other browsers too or else not everyone will see it sorted how you want it. Thats the beauty of PHP and doing everything server-side.. Feel free to ask me any questions you may have.
Dan
Team 999
Unread 22-05-2005, 17:09
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Not sure if you fixed it Elgin, but in case you/anyone else needs an answer. Try using CSS to center the text.
.center{
text-align: center;
Then in your HTML
<table>
    <tr>
        <td class="center">
            Mike
       </td>
    </tr>
</table>
http://www.mikesorrenti.com/
full table? Shlomi32 General Forum 2 27-04-2005 10:03
Distro block, maxi fuse box, and ground stem ErichKeane Electrical 25 20-02-2004 07:19
Lookup table generation tool WillyC Programming 12 15-02-2004 21:01
picture of 40 amps fuse holder and fuse rcubes85 Technical Discussion 1 13-02-2003 16:03
how do u hook up things through the fuse panel? chrisw Technical Discussion 9 12-01-2002 19:51
