Go to Post "I need the adjustable hammer" "You mean that wren-" "No, it's a hammer" - Karibou [more]
Unread 17-05-2005, 12:02
unapiedra unapiedra is offline
FRC #1520
Team Role: Student
Rookie Year: 1990
unapiedra will become famous soon enoughunapiedra will become famous soon enough
Tubing In Autodesk
Hi!
I searched but I couldn't find anything, so here is my question: let's say I draw an outline in Autodesk Inventor (for a bike or such), and I then want to create tubing following this outline. How do I do this?
I saw the "Create Pipe Run" but couldn't figure out how it works, so if anyone could help me it would be very nice.
Thanks
Unread 17-05-2005, 12:41
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: Tubing In Autodesk
Man I really have to jump on this Inventor bandwagon.
Typically though in CAD softwares, you draw your path, or line that you want a shape to follow & then you draw a profile. Link the 2 together by a mate or constraint, normally the center of the profile (circle) to the endpoint of your path, and then do a sweep, command to extrude that profile along that path.
No idea how inventor handles this though, or what the commands are called. (Sorry)
Some CAD systems make you draw the profile first, and some make you draw the path first.
Unread 17-05-2005, 12:51
oljomo's Avatar
oljomo oljomo is offline
Cambridge United Fan
#0759 (Systemetric)
oljomo is on a distinguished road
Hi
As i read this, youve drawn an outline of the frame of a bike from the side view.
If that is the case i think the easiest way to create tubes i would say is to extrude the profile to the width of the tube, then just round the corners off and shell it, not sure whether itll work on inventor as I havent tried it, but it worked on prodesktop when i used that.
The piping wizard seems to be more for linking two points together with a pipe.
oljomo
Cambridge 'til I die
I'm Cambridge 'til I die
I know I am I'm sure I am
Unread 17-05-2005, 14:33
jdiwnab's Avatar
jdiwnab jdiwnab is offline
Really the Inventor Guy
AKA: Bryan Hartley
FRC #0617
jdiwnab is a jewel in the roughjdiwnab is a jewel in the roughjdiwnab is a jewel in the rough
It is possible to "sweep" from one outline to another. I haven't tied it, but I think if you specify a path and the 2 end profiles, that it can work.
Proof that Macs will win the platform war: How did Scotty know how to use MacDraft in Star Trek IV?
// random()
I have 100 gmail invites. PM me if you want one.
If they want us to think outside of the box, why do they make us fit in a 38x28x60 inch box?
Beware of Geeks bearing GIFs
Help me test my server software
Unread 17-05-2005, 16:34
crazykid234's Avatar
crazykid234 crazykid234 is offline
Techincal assist
AKA: Brian Clegg
FRC #1646 (Precision Guessworks), Alumni FRC #234 (Cyber Blue)
crazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to behold
To sweep the bike like you are talking about, draw a circle (make sure you are in the correct plane)somewhere on the line, and click sweep, the sweep feature should create an extrusion of the circle wherever the bike outline goes. You may need to draw your circle on the end point of the bike outline.
Don't see the world as it is and ask why; see the world as it could be and ask, why not? - unknown author
Unread 17-05-2005, 22:50
FRC #1520
Team Role: Student
Rookie Year: 1990
yea I did this, but it only does part of it, since the bike is not just one simple line but rather 5 lines connected and splitting at various points.
It works somewhat, if i do it for every "line" seperatly, but then it doesn't connect...
Thanks for the help!
Unread 17-05-2005, 23:22
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I can't really recall exactly what a bike frame looks like but is this sort of what you are trying to do?
I did the whole perimeter in one shot and then the smaller bar through it in a second sweep.
Unread 17-05-2005, 23:29
Daniel Brim's Avatar
Daniel Brim Daniel Brim is offline
It's hard hat time here in Boston
AKA: DFB
FRC #0125 (NUTRONS)
Daniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond repute
Send a message via AIM to Daniel Brim
The tube and pipe runs in Inventor are strictly for architetural reasons. The runs are bent at 90o or 45o angles. It is used more for plumbing than anything else. I was experimenting with it last year, and after watching a tutorial, I could get it where I wanted, but it had no practical purposes on the robot. A bicycle frame would be the same - the tube and pipe runs just don't work with it.
2003 (2002) - 2006 -- Team 294, Beach Cities Robotics
2007 (2006) - Present -- Team 125, NUTRONS
Unread 18-05-2005, 09:44
FRC #1520
Team Role: Student
Rookie Year: 1990
yes, but in my case it didn't work.
first I started at (1), so then I did (2) then (3) and than (4), but I couldn't get it to work in one sweep and it didn't connect.
Unread 19-05-2005, 01:48
JasJ002's Avatar
JasJ002 JasJ002 is offline
Inventor Freak
AKA: Jay
FRC #0662 (Cybersonics)
JasJ002 is a jewel in the roughJasJ002 is a jewel in the roughJasJ002 is a jewel in the roughJasJ002 is a jewel in the rough
Send a message via AIM to JasJ002
Talking Re: Tubing In Autodesk
You could also use something else as your bas and then build the tubing via 3D sketch. If you wanna know more about that just ask I don't know if it would work well or not. but thats what I used for the tubes and the wires on our robot. once you get the process down it's pretty easy.
2005 2006 2007 Autodesk Inventor Winner
2005 Winning Site & 2006 Winning Site
2007 Winning Site
Unread 19-05-2005, 09:38
Try to start by drawing only the outer perimeter in the sketch. You should be able to sweep that once through. Then make a new sketches for the other lines, and sweep those one at a time.
Unread 19-05-2005, 18:23
FRC #1520
Team Role: Student
Rookie Year: 1990
Thanks, i didn't think about it and I'll give it a try the next time I come near Autodesk (monday).
Ok, I'll give this a try too.
Unread 21-05-2005, 01:12
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
Originally Posted by oljomo
Hi
oljomo
I think this would work the best for this problem, with the least amount of time. In inventor, just extrude the square tubes, then just use the "fillet" tool to round them. You can even make fillets where the bikes tubes meet, creating something looking like fillet welds. Then to hollow the tubes out, just use the "shell" tool, set a tube thickness, and it hollows the whole thing out for you. Very easy this way.
Unread 24-05-2005, 11:59
FRC #1520
Team Role: Student
Rookie Year: 1990
Thanks everyone, it works now. I used a new outline and square tubing instead. I think that made the difference, don't know why. It could also be that the line doesn't split up.
So it works now, and thanks again everyone for the input.
The Autodesk Design Awards 2003 – Call for Entries Brandon Martus 3D Animation and Competition 1 26-12-2003 18:40
FIRST Blast: 2004 Autodesk Software Information! miketwalker FIRST E-Mail Blast Archive 1 03-11-2003 21:21
Autodesk hath taken pity on us... RachelOfMars 3D Animation and Competition 2 05-04-2003 11:12
