Go to Post Simply. Minimize. Reduce. It's a good engineering rule, and an even better management one. - Tom Line [more]
Unread 25-03-2005, 19:35
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Unhappy CIM-MOTOR source
I was just preparing a Purchase order via the IFIrobotics site for a summer project to make a running plateform using the kitbot chassis/tranmissions/CIM motors.
Alas, they are out of stock on the motors and won't be restocking. Anybody know of a source for these motors?
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 25-03-2005, 21:24
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: CIM-MOTOR source
IFI is the only source for those and you are correct in saying they will not be stocking any more. Try trading with another team like through the CD swap system.
Unread 25-03-2005, 22:42
Question Re: CIM-MOTOR source
Can somebody refresh my memory as the current bot is waiting for us in Houston? Does this year's CIM motor have the same output shaft as either or both of the last two year's? If so then I can get by with gutting old machines. I've sent a request into the CIM folks via their website. I'll post here if I get any response.
APS
Founder FRC 499
Unread 25-03-2005, 22:55
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
I remember this years KEYWAY was slightly different in that it wasn't cut the entire length of the shaft, I think it stopped about 1/2" short of the end of the shaft. You could tell it was cut with an end mill, where as 2003 and 2004 CIMs keyway was cut with a keyway cutter. However, they both use the same size metric 2mm keystock. Other than that the rest of the shaft seems unchanged.
Unread 27-03-2005, 13:51
David Guzman's Avatar
David Guzman David Guzman is offline
AKA: Dave
FRC #1251 (The Techtigers)
David Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant future
The keyway shouldn't be a problem. Our practice bot is using old CIMs with the kit transmission. just make sure you put the 3 nilon washers before you put the key in, and get the right set screws (dont stick out of the hub) and put some red locktide on them and you should be set.
Dave
Unread 17-05-2005, 22:18
Nitroxextreme's Avatar
Nitroxextreme Nitroxextreme is offline
Relation to Mrs. Steve
AKA: Jon
FRC #1626 (Falcon Robotics ; 190 (Gompei and The Herd))
Nitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to behold
Send a message via AIM to Nitroxextreme
if anyone can find a source for cim motors before the summer that would be awesome
please pm me
"He needed a chuck norris lesson in FIRST"...."I will give him a round house kick to the face...with gracious professionalism"
Unread 18-05-2005, 11:57
BillCloyes's Avatar
BillCloyes BillCloyes is offline
#0677 (The WireStrippers)
BillCloyes has a spectacular aura aboutBillCloyes has a spectacular aura aboutBillCloyes has a spectacular aura about
please pm me
or you could post it here so that everyone could benefit
No CIM Motor in 2006? Sscamatt Rumor Mill 21 22-03-2005 22:47
Allowed to use CIM motors from last year? lphan Motors 7 26-02-2005 16:49
CIM speed in reverse? colt527 Motors 41 06-12-2004 19:09
CIM Motors to pull up Robot Joe P Motors 7 11-01-2004 22:27
CIM vs. Drill motor duckshepherd Motors 3 15-02-2003 18:36
