Go to Post An Evil Overlord is only as bad as the creatures she/he rules. - MissInformation [more]
Go Back   Chief Delphi > ChiefDelphi.com Website > CD Forum Support
Unread 18-05-2005, 10:01
Denman's Avatar
Denman Denman is offline
Tie Wrap-Not Cable Tie or Zip tie
AKA: Stephen Denman
FRC #0759 (Systemetric)
Denman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud of
Send a message via ICQ to Denman Send a message via AIM to Denman Send a message via MSN to Denman Send a message via Yahoo to Denman
server crashes?
has anyone else except me noticed that the server keeps dying in the mornings (uk time, so very early for you.) EG this morning at9 am uk, it was down , and still down at like 12am.... it was down also yesterday, but came up not that long afterwards.
Is there a problem at the moment, and is there anything we can do if there is?
Stephen
I am an ex-member of team 759.
759: regional winners with 522 and 233 NYC (2004)
FIRSTWiki.org - Contribute, learn, inspire.
"Teach the way of the GP and the way of the GP shall teach you" - Me
Unread 18-05-2005, 10:10
Brandon Martus's Avatar Unsung FIRST Hero
Brandon Martus Brandon Martus is offline
busy.
AKA: B. Slash Kamen
Brandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond repute
Send a message via ICQ to Brandon Martus Send a message via AIM to Brandon Martus Send a message via Yahoo to Brandon Martus
Re: server crashes?
named keeps dying and not restarting like it should. I'm looking into it right now actually.
If you're talking about the nightly backup, I apologize. You're probably seeing it at early morning, and theres nothing we can do about that (for now) since we have a majority of the people in the US on the site we have to do it at that time.
Brandon Martus
e-mail
Unread 18-05-2005, 10:24
busy.
AKA: B. Slash Kamen
Re: server crashes?
So, pretty much we're running out of memory during the database backup, and the kernel starts killing off the processes taking the most memory .. so the machine won't die. named (dns) and mysqldump (backup) are the first two that get axed, causing the backup to fail, and the machine to be floating in Internet la-la land only accessable via IP, and not 'chiefdelphi.com'.
So. Once we get a better server with more memory, we'll be ok.
Until then, I guess I'll write some sort of sanity check script to make sure named is running every 2-3 hours.
Brandon Martus
e-mail
Unread 18-05-2005, 10:29
Denman's Avatar
AKA: Stephen Denman
Re: server crashes?
hmm. if you mean the one at 5:47, i see that every day at 1047... so i don't mind that.
Maybe we should go to the donate to CD area
Unread 18-05-2005, 10:30
Re: server crashes?
Can you add a swap file (I'm assuming it's hard if not impossible to increase the swap partition)? Obviously it will kill performance when it's needed, but if it's only used during the backup, it shouldn't be as bad having the OOM killer active.
Unread 18-05-2005, 13:39
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: server crashes?
I had been wondering about that... every morning at 6-7ish for me.
Maybe you should fire someone to sit there and type "named" <enter> over and over again as fast as they can...
Why can't you just increase the swap?
Unread 18-05-2005, 13:50
Randy Randy is offline
Randy will become famous soon enough
Re: server crashes?
Brandon,
Why not use external DNS? Also, look below for how to add SWAP ... My offer for resources still stands
Joe,
Increasing the size of the SWAP partition really wouldn't be an option, but you could add SWAP space. We had to do this on a client's server that literally blewup (traffic wise).
Create the file that we're going to turn into SWAP space
Replace xxxxxx with the size of the SWAP space you'd like to add.
# dd if=/dev/zero of=/dev/SwapFile bs=1024 count=xxxxxx
chmod the SWAP file for security purposes
# chmod 600 /dev/SwapFile
Make is SWAP
# mkswap /dev/SwapFile
Turn it on
# swapon /dev/SwapFile
Check amount of SWAP
# free -m
And ... if you want it to mount on boot, add this to /etc/fstab
/dev/SwapFile swap swap defaults 0 0
FREE WEB HOSTING for FIRST teams and related organizations.
  • Team sites
  • Image Hosting
  • Video Hosting
Email promo@sevaa.com or click here for details.
Unread 19-05-2005, 01:13
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Re: server crashes?
Originally Posted by Randy
Brandon,
... My offer for resources still stands ...
so does mine
-Mike
E-Mail Server Venkatesh IT / Communications 15 27-06-2005 01:47
Server Load Brandon Martus Announcements 10 27-04-2005 20:25
Home DNS Server? sanddrag IT / Communications 14 08-03-2005 02:09
projectpoint server problems MSBlaster Inventor 1 11-01-2005 13:37
free chat server archiver 2000 2 23-06-2002 22:08
