Go to Post just a gentle reminder not to limit yourself to just one viewpoint - every problem can and should be examined from different angles - dlavery [more]
Unread 18-05-2005, 15:51
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Best Joystick ?
Originally Posted by Ted Boucher
We tried to use the new joysticks that we got in 2004 and decided that they were horrible for our use.
I can't stand the new ones. They're incredibly sloppy, feel cheap as heck, break easily, and are right handed only.
There's a second model of the Flightstick (Flightstick Pro, IIRC) that a couple teams use that gives you 3 or 4 more buttons on the top, if you need them.
2001-2004: Team 100
2006-Present: Team 254
Unread 18-05-2005, 16:19
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
Re: Best Joystick ?
This is a good issue to push with FIRST and the 2006 kit. I haven't met anyone yet that likes the new joysticks. Also I can't count how many people have tried in vane to take our flight sticks. I hope there's a good study coming to figure out a comparable product and get rid of the current ones. They nearly lost our second regional for us.
www.179swampthing.org
Unread 27-05-2005, 00:05
Re: Best Joystick ?
Originally Posted by Andrew Blair
Oh baby, if FIRST would only invest in some of these for our kits.....
The easiest way to make sure something you want gets into the kit is to convice the company to donate several thousand to FIRST. It's worked for Dr. Joe Johnson several times.
Change joystick to pwm mapping Joe Lewis Programming 3 30-03-2005 19:27
Changing 1 joystick code to 2 (rookie team) Brawler006 Programming 5 20-02-2004 17:00
robot goes haywire with the one joystick default code Miles Programming 7 24-01-2003 14:58
joystick problem archiver 2000 12 23-06-2002 23:08
switching joystick axis????? team222badbrad Technical Discussion 9 16-01-2002 23:07
