Go to Post I survived the Great CD Spamming of 2006. - Michelle Celio [more]
Unread 19-05-2005, 10:39
Re: PBASIC operator interface LED problems
Your joysticks are plugged into OI ports 1 & 2?
Your joystick may not be giving you full range and falling into the ranges set in the default code for the OI LEDs.
You can try expanding the ranges to be any forward and any reverse value rather than only the top/bottom of the normal range. You might also like to increase the range where both lights are on.
This is the way the default code is now for OI Port 1:
select (p1_y) 'Check position of Port 1 Joystick
	case 0 to 56 'Joystick is in full reverse position
		Out8 = 0 ' Turn PWM1 green LED - OFF
		Out9 = 1 ' Turn PWM1 red LED - ON
	case 125 to 129 'Joystick is in neutral position
		Out8 = 1 ' Turn PWM1 Green LED - ON
	case 216 to 255 'Joystick is in full forward position
		Out9 = 0 ' Turn PWM1 red LED - OFF
	case else 'In either forward or reverse position
endselect
Try changing the ranges to:
	case 0 to 124 'Joystick is in full reverse position
	case 130 to 255 'Joystick is in full forward position
	case else 'In either forward or reverse position (unused)
endselect
Do the same for OI Port 2.
Making a beacon indicator LED burn its brightest without burning out DanL Electrical 7 26-01-2004 08:05
Help On Coding 2K1 Controller GregTheGreat Programming 9 05-12-2003 18:35
Any problems with PBASIC 2.5 Editor v2.0 Carl Owenby Programming 7 10-02-2003 10:00
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
