Go to Post They truncated our conference title. We are not showing the movie "Finding NEMO" - RoboMom [more]
Unread 19-05-2005, 20:09
MattK's Avatar
MattK MattK is offline
Tap it.
MattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to behold
Send a message via AIM to MattK
CALLING ALL GEEKS! HELP!
alright so i just went to turn on my PC... and my monitor indicates no signal... I switch monitors... same thing. I have a graphics card in my machine so I pulled that out and tried the build in graphics chip- same issue. Pulled the battery- same thing... NO SIGNAL going out to my monitor..
any idea? I am fearing it might be my mobo...
The views expressed in my posts are Mine and mine only.
my myspace!
Unread 19-05-2005, 20:12
scitobor 617's Avatar
scitobor 617 scitobor 617 is offline
More nerd than you can handle!
AKA: Alan Meekins
FRC #0617 (HSHS 617 "DUKE")
scitobor 617 will become famous soon enoughscitobor 617 will become famous soon enough
Send a message via AIM to scitobor 617
Re: CALLING ALL GEEKS! HELP!
Does your computer beep(POST) when you turn it on? Also, does it beep more than once?
P.S. I pesonally prefer the term nerd.
Beta testers needed!
http://www.nullagent.no-ip.com
Your kidding, there are other operating systems besides Linux?!
Unread 19-05-2005, 20:15
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
what were you doing before you experinenced the problem? And was there any static around the computer, thats lethal for a lot of compenents.
pss. for this subject i perfer the term Techie, but all 3 for for me.
Unread 19-05-2005, 20:16
MattK's Avatar
Tap it.
Nope I am not getting any beeps from my hardware... I also do not think its booting into windows. My reason for this is because after I let it sit for a min, then I go to hit the power button (to turn the machine off)... and it just hangs
my myspace!
Unread 19-05-2005, 20:17
temujin's Avatar
temujin temujin is offline
Senior Technical Officer
AKA: Donnell Williams
FRC #0116 (Epsilon Delta)
temujin is an unknown quantity at this point
As you're booting, press the key that takes you into setup. Make sure the onboard graphics is not disabled. If it is, enable it - if you now have video, then your graphics card is shot. Usually the onboard is disabled when you have another graphics card inserted....
"A little pain never hurt" - Temujin
Unread 19-05-2005, 20:21
MattK's Avatar
Tap it.
How am I suppose to check if my onboard graphics is not disabled? I cant see anything.
my myspace!
Unread 19-05-2005, 20:23
AKA: Alan Meekins
Sounds like a hardware problem if it is not booting or posting. Have you installed any new hardware recently?
Unread 19-05-2005, 20:24
MattK's Avatar
Tap it.
Originally Posted by scitobor 617
Sounds like a hardware problem if it is not booting or posting. Have installed any new hardware recently?
Nope, non... seems fairly random... I had shut my machine down... went to turn it back on... and *BAM* its not working. I have TONS of work stuff on my mahcine, not to mention school and personal stuff. I am praying that there is no issue with my drives.
my myspace!
Unread 19-05-2005, 22:49
i'm also saying a hardware problem, particularly a motherboard or video card problem. I'd start checking my warranties
Unread 20-05-2005, 05:29
Denman's Avatar
Denman Denman is offline
Tie Wrap-Not Cable Tie or Zip tie
AKA: Stephen Denman
FRC #0759 (Systemetric)
Denman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud of
Send a message via ICQ to Denman Send a message via AIM to Denman Send a message via MSN to Denman Send a message via Yahoo to Denman
remove hard drive, backup everything on another computer before carrying on.
Check for anything loose inside.... i lost graphics when the fan fell off the graphics card and it shut itself down for overheating....
and on a semi funny note.... according to
http://www.cs.wisc.edu/~ballard/bofh/bofhserver.pl
The cause of the problem is:
Quantum dynamics are affecting the transistors
I am an ex-member of team 759.
759: regional winners with 522 and 233 NYC (2004)
FIRSTWiki.org - Contribute, learn, inspire.
"Teach the way of the GP and the way of the GP shall teach you" - Me
Unread 20-05-2005, 09:46
KyleGilbert45's Avatar
KyleGilbert45 KyleGilbert45 is offline
KyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant future
DJ Fluck had this exact same problem early in the year when he was building a new computer. I know we tried new ram and a couple new graphics cards to no avail. I I think he ended up returning the processor, saying it was defective. I'm not sure if the new processor ever fixed it, but maybe if you contacted him, he'd be able to tell you what he did.
Unread 20-05-2005, 13:09
Mike8519's Avatar
Mike8519 Mike8519 is offline
FRC #0303 (TEST Team)
Mike8519 is just really niceMike8519 is just really niceMike8519 is just really niceMike8519 is just really niceMike8519 is just really nice
This just happened to a friend of mine, not sure exactly how I fixed it but here's what I did.
I took out the battery (It sit out for 2 days) and took out the processor and reseated EVERYTHING. RAM, Vid Card, Cables, etc. Then it magically booted, but gave a CMOS Checksum error on the first boot.
Unread 22-05-2005, 16:36
MattK's Avatar
Tap it.
This new mobo should be here mid-week Anyone out there ever use this mobo?
my myspace!
Unread 22-05-2005, 22:33
I seriously considered that, but eventually i opted for my, Asus A7N8X-E Deluxe. But i'm upgrading to a 64 bit system soon.
Calling Everyone In Atlanta! Tom Bottiglieri Championship Event 2 15-04-2004 21:15
Freaks and Geeks MattK Chit-Chat 2 27-12-2002 15:41
Calling Team Montreal. Vin211 General Forum 1 26-11-2002 09:32
Calling all Quidditch players!! asher Chit-Chat 43 12-05-2002 20:44
Calling all Lawyers... ...Define "all parts" Joe Johnson General Forum 10 13-03-2002 15:12
