Go to Post I guess this means we have to work on becoming super-flexible and always be ready for our close-ups at robotics from now on? - Beth Sweet [more]
Unread 20-05-2005, 09:51
Kram Kram is offline
Kram is an unknown quantity at this point
Talking CMUcam2 interfacing
yo bros, I have a problem with interfacing my CMUcam2 (http://www-2.cs.cmu.edu/~cmucam/cmucam2/index.html). For my project, we were give a biped robot assembly kit from lynxmotion, the CMUcam2 and a 32 servo controller. From the manual, i understand that the ttl ports on the cam is supposed to go to the micro controller which we dun have. Is it possible to connect to the 32 servo controller? The serial port is already used for the servo controller. All our programming is done in visual basic. We have thought of splitting the serial cable into 2, 1 to go to the servo controller and the other to the cam as the instruction sent will be different eg, the servo will accept inputs like #1 p1500 t1000 ,eg while the cam will accept command like tw, tc ,etc. The final product of the robot will be that, it must walk, climb stairs, detect obsticles, track color etc, autonomusly. As we are quite new to the world of robotics, is there any good reference site to recommand? Or any source code in visual basic that we can use? Thanks in advance.
Mark
Unread 26-05-2005, 21:42
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: CMUcam2 interfacing
This is a forum about the FIRST Robotics Competition, which in 2005 included the CMUCam in the Kit of parts.
We do not do general support for the CMUCam (or Delphi, or anything else people stumble on here about).
Unread 27-05-2005, 07:17
Originally Posted by Kram
As we are quite new to the world of robotics, is there any good reference site to recommand? Or any source code in visual basic that we can use? Thanks in advance. Mark
Mark,
There are several sites that discuss the CMU but you are the better judge of which ones will fill your needs. Just search through Google. The camera was a project of Carnegie Mellon University, hence the CMU designation. The CMU site has some excellent articles. Since our controller is obviously different from yours, I don't think you will find much help on interfacing, here. Our controller does not use VB for programming either. Generally, splitting serial cables to different locations is a bad idea as device contention becomes a problem as the two devices fight over the control. Sorry, we can't be of more help.
CMUCam2 code (FRC and EDU?) Amber Programming 0 15-02-2005 22:23
CMUCam2 Vision Sensor Testing/Problems cbolin Programming 18 02-02-2005 18:03
Random Tranformer and What do the CMUCam2 LED's do? swarm32 Technical Discussion 9 15-01-2005 23:51
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
PC Interfacing lkeller Programming 4 06-08-2003 09:51
