Go to Post GP is best shown and lived and not talked about. - Steve W [more]
Go Back   Chief Delphi > Technical > IT / Communications
Unread 21-05-2005, 10:58
MrToast's Avatar
MrToast MrToast is offline
I named Greg Needel's cat!
AKA: Dave DeLong
no team (Rhode Warriors)
MrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud of
Send a message via AIM to MrToast
AVI and QuickTime question
Hey CD,
I'm having some problems playing AVI files in Quicktime. I've searched around and installed some things like DivX, 3ivX, and AC3, but nothing works. Every time I try to open the movie I get "QuickTime cannot open the file... an unknown error occurred (-50)". Restarting has done nothing to alleviate this problem.
Does anyone here have an idea as to what I could do?
Thanks!
Dave
System specs:
500MHz G3 white iBook (dual USB), 576MB RAM, OS X 10.4, Quicktime 7, DivX 5.2.1, 3ivX D4 4.5.1, AC3 (latest).
(#121, 2004) Archimedes semi-finalists with 237 and 386! I had an awesome time guys, and thanks for the hat!
(#121, 2004) BC5 semi-finalists with 190 and 1027! Awesome time! We went further than I thought we could! Thanks for all your help w/ our transmission!
(#121, 2005) Galileo quarter-finalists with 47 and 203! Thanks for all your support through the stress!
If it moves and it shouldn't, use duct tape.
If it doesn't move and it should, use WD-40
"It'll all work out in the end, and if it doesn't, it's not the end." - Jeff Bullock
Unread 21-05-2005, 12:09
D.J. Fluck
Posts: n/a
Re: AVI and QuickTime question
The file you are trying to watch probably uses one of those stupd rare codecs....I've read that no matter what quicktime avi plugins usually dont work.
I know this might come off as a shock, but if worse comes to worse, you could always try *Gasp* Windows Media Player for OSX
http://www.microsoft.com/windows/win...x/default.aspx
The other alternative ive read about is a program called VLC, that is aparently pretty good. The bad news is that aparently they stopped development of it The only problem so far with that is some of the newer codecs wont be recognized by the program and never will.
Hope this helps.
Unread 21-05-2005, 12:25
MrToast's Avatar
AKA: Dave DeLong
Thanks for the suggestion, D.J. I didn't think of using WMP, but again it unfortunately didn't work. I failed to mention in my original question that I'd also tried VLC and mPlayer, but neither of those worked, either.
Thanks,
Dave
Unread 21-05-2005, 12:57
jdiwnab's Avatar
jdiwnab jdiwnab is offline
Really the Inventor Guy
AKA: Bryan Hartley
FRC #0617
jdiwnab is a jewel in the roughjdiwnab is a jewel in the roughjdiwnab is a jewel in the rough
AVI files are kinda fickle. I can think of a few options:
1) search Version Tracker for AVI players/plugins
2) look at the Apple Discussions Fourms for answers or even ask there
3) use a friends peecee and see if you can use a converter to Quicktime
Proof that Macs will win the platform war: How did Scotty know how to use MacDraft in Star Trek IV?
// random()
I have 100 gmail invites. PM me if you want one.
If they want us to think outside of the box, why do they make us fit in a 38x28x60 inch box?
Beware of Geeks bearing GIFs
Help me test my server software
Unread 21-05-2005, 14:18
Jason Rudolph Jason Rudolph is offline
Alumni of 168
Jason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud of
Send a message via AIM to Jason Rudolph
When you open the file, hit command-i and look at the file info to see what codec it was encoded as. There are a number or codecs out there that simply cannot be played on a mac. Sometimes, your only option is to find a PC and re-encode the video into another codec. Go to version tracker and look up the codec to see if there are plugins available for Mac.
Unread 21-05-2005, 14:23
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
Download the vlc player: www.videolan.org/vlc
Includes nearly every single codec you could need; opensource too.
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 21-05-2005, 21:47
Kyle Fenton Kyle Fenton is offline
GET IT ON!!
FRC #0121 (Rhode Warrior)
Kyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud of
Send a message via AIM to Kyle Fenton
Originally Posted by MrToast
Hey CD,
Thanks!
Dave
System specs:
This error usually results from a corrupt and/or proprietary header in the AVI file.
I don't think there is anyway you can read a movie file with a corrupt header.
If it is proprietary then the only way is to use a player that is compatible with encoder.
Try this. It sometime can re-write the header files in an AVI
http://doctor.3ivx.com/
Rhode Warriors
NAVSEA/Raytheon/URI/Middletown, Portsmouth, Tiverton, Mt. Hope HS
Quality Robots Since 1996
Unread 21-05-2005, 23:37
MrToast's Avatar
AKA: Dave DeLong
Yep, I came across DivX Doctor, too, but it refused to load the AVI file. I eventually just gave up and redownloaded it and all is well. Thanks for all the suggestions!
Dave
QuickTime or .MOV to AVI or MPEG archiver 2001 2 24-06-2002 02:00
