Go to Post FIRST truly isnt about building robots, but allowing yourself to reach higher and farther than you ever could. - Brandon Holley [more]
Unread 21-05-2005, 14:50
Andrew Blair's Avatar
FRC #0306 (CRT)
Question Lines and wires
How do you give thickness to a line? I can't seem to figure it out, and I'm starting to feel awful dumb. Also, once I get my visible line, how would I add decals to it, such as wire gauge?
-Sir Francis Bacon
-Albert Einstein
Unread 24-05-2005, 21:49
Yov's Avatar
Yov Yov is offline
Masterofsquirrelz
#1657
Yov is a jewel in the roughYov is a jewel in the roughYov is a jewel in the roughYov is a jewel in the rough
Send a message via ICQ to Yov Send a message via AIM to Yov Send a message via MSN to Yov
Re: Lines and wires
if you made it as a line, check the renderable box in the modifier panel, also check "display render mesh" or something, there's thickness there too...
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
2005 Israel regional Winner
2005 Radioshack Innovation in Control Winner
A question about current.... Adam Y. Electrical 41 26-11-2004 21:46
pic: Not Having fun on the way home to orlando CD47-Bot Extra Discussion 15 19-07-2004 15:08
Magnets allowed?¿? Speed1130 Technical Discussion 35 30-01-2004 20:11
