Go to Post I can't believe that I said the CD community could be patient - in December. - JaneYoung [more]
Unread 21-05-2005, 16:41
Spindle Spindle is offline
None #1525
Spindle is an unknown quantity at this point
Matching a Gear to Keyed Shaft of DC Motor
Hey,
I ordered a motor for a personal project as well as some gears. The shaft is keyed on the DC motor. How would I bore out the hole of the gear to fit snugly on the shaft of the DC Motor. Here is a picture. Any help is greatly appreciated as I am stumped on this part of my project.
Thanks,
- Matthew
Unread 21-05-2005, 17:11
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Matching a Gear to Keyed Shaft of DC Motor
your gear barely looks like it has a larger diameter than the OD of the shaft. Are you sure it'll fit when bored out, and not damage the teeth?
2001-2004: Team 100
2006-Present: Team 254
Unread 21-05-2005, 17:28
None #1525
Yup Positive. Here is a more clear picture at a better angle. The gear is made of a nylon material. Is it possible to bore it out, put it on the shaft than fill in the void with a material that will cure/harden? I can't think of any other way to get this gear to fit snugly on the end of the keyed shaft.
Unread 21-05-2005, 17:38
Cory's Avatar
AKA: Cory McBride
How much torque will the gear be transmitting? A lot, or a little?
2001-2004: Team 100
Unread 21-05-2005, 17:59
None #1525
16in-lbs of torque. Maybe I could get the shaft out of the motor and turn that down with a lathe to fit the inside diameter of the gear so I don't have to bore out the gear. I don't know what type of screw head that is though to get the bracket off.
Unread 21-05-2005, 18:12
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
It looks like a hex wrench can get those screws off. Anyways, I believe you're going to need a special broach to cut that shape into the gear.
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
Unread 21-05-2005, 18:50
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
How about boring out the gear to match the OD of the "D" part of the motor shaft and then drill and tap a set screw crossways in the round hub of the gear to press on the flat of the "D"?
Unread 21-05-2005, 23:18
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
What I would do is throw (not literally) the whole motor onto the mill. Then I'd put a couple parallel bars in the vise, set the shaft (large part) on those, then clamp the vise on the shaft. The body of the motor would hang out the side of the vise. Then I'd center it up with an edgefinder going off the insde face of the vise jaws. Then I'd go in with an endmill and mill a keyway in the motor shaft (large part of the shaft). Then I'd bore the gear to fit over the shaft, and then I'd broach a keyway in the gear.
Of course, this would only work if the gear is big enough to be bored out to fit over the big part of the shaft, and the shaft has to be a standard size.
As for your question about filling in the voids, you may be able to use some sort of epoxy but I'm not sure if it would work.
What would probably be the best solution would be to set up the gear in a mill (preferable with dro). You can use an indexing head and a collet to hold it so you clamp on all the teeth so you won't flatten any. You won't need to clamp very tight. Then get the gear centered by the bore. Then get an endmill of diameter that is the distance from flat to flat of the shaft. Then mill in the gear, the shape of the shaft. Of course this only works if the distance from flat to flat on the shaft is a standard size.
May I ask, why are you using a plastic gear as opposed to a metal one?
Unread 21-05-2005, 23:46
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
i personally would use a set screw as deepwater suggested (just make sure the screw doesn't come loose...). but, if you don't want to do that, here's a post from Dr. Joe about attaching gears to the output of the globe motor, which has a similar output shaft:
Originally Posted by Joe Johnson
...As to the Double D on the Globe, I know some teams have modified a standard round broach to put in the flats. I THINK the Globe has a 3/8 round shaft with flats, so if you buy a 3/8 broach and grind in the flats, you should be all set. I have not done this myself, but have heard good reports.
Joe J.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 22-05-2005, 20:23
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
We have used double-D broached holes on metal gears with the Globe motors. It worked just fine. When we modified last year's robot as a practice bot for this year, those gears wound up working a lot harder than they were designed to. They still work just fine. Not sure how the plastic gear will work, but a D shaft will probably work bettter than a key way or set screw.
Christopher H Husmann, PE
"Who is John Galt?"
**FIRST EMAIL**/Important Fisher-Price motor and gearbox information sanddrag FIRST E-Mail Blast Archive 1 11-02-2005 18:19
pic: 571's new gearz loose weight CD47-Bot Robot Showcase 24 16-04-2004 16:35
Chiaphua Gear Box mzitz2k Technical Discussion 15 06-01-2004 10:26
Drivetrain Help Jordan Technical Discussion 16 02-12-2001 12:14
