Go to Post Never underestimate the power of human ingenuity. - Wetzel [more]
Unread 21-05-2005, 12:51
Luminous Luminous is offline
Luminous is an unknown quantity at this point
Exclamation Download code from robot
Is it possible to download the code from the robot? We lost the original code and don't want to start from scratch.
Thanks
Unread 21-05-2005, 13:15
rees2001 rees2001 is offline
AKA: Rees
FRC #0340 (Greater Rochester Robotics)
rees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond repute
Re: Download code from robot
Thanks
There is a program that enables you to download from the Robot controller. We had to use it on our robot from last year due to a computer problem. It is still a beta version but it worked fine for us I have a copy at school i can send you on monday if nobody else has a compy,
Unread 21-05-2005, 19:33
CyberWolf_22's Avatar
CyberWolf_22 CyberWolf_22 is offline
Programming and Electrical Mentor
AKA: Allen Gregory
FRC #2587 (Afrobots)
CyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really nice
Yes the program is on IFI's website under the Robot controller section.
One of the problems with this is that you can not actually read the code (at least that I know of) you can only have a copy to redownload in to your robot , not to modify.
Unread 22-05-2005, 00:00
RbtGal1351's Avatar
RbtGal1351 RbtGal1351 is offline
~La Reina de los Robots~
AKA: Stephanie
FRC #1351 (TKO)
RbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to behold
Send a message via AIM to RbtGal1351 Send a message via MSN to RbtGal1351
That's because you download the hex file, which is the machine language basically.
Good luck!
~Stephanie
Team 1351
2004 Founding member and Arm leader, 2005 Lead programmer, 2006 Controls leader, 2007 Project Manager/President
Thanks for making FIRST such a great experience for me. I'm no longer on 1351, and I'm not currently planning to mentor team 97, but FIRST has meant so much in getting me to where I am now, in life and at MIT, class of 2011.
I met Billfred! He recognized me!
SVR 04: 11th seed - Highest Rookie Seed - Semifinalists w/ 1120 and 568 - GM Industrial Design Award
SVR 05: Semifinalists w/ 8 and 766
SVR 06: 6th seed - Quarterfinalists w/ 368 and 1072
Davis 06: 1st seed - Quarterfinalists w/ 649 and 100 - KPCB Entrepreneurship Award
SVR 07: 36th seed
David 07: 4th seed - Semifinalists w/ 1280 and 692 - Johnson and Johnson Sportsmanship Award
Unread 25-05-2005, 13:32
steveg's Avatar
steveg steveg is offline
Livin' the Dream
AKA: Stephen Guerrera
steveg is a splendid one to beholdsteveg is a splendid one to beholdsteveg is a splendid one to beholdsteveg is a splendid one to beholdsteveg is a splendid one to beholdsteveg is a splendid one to beholdsteveg is a splendid one to beholdsteveg is a splendid one to behold
Send a message via AIM to steveg
If you're feeling ambitious, once you have the file back on your computer you can disassemble it using a program similar to this one
Just remember that once you disassemble it, it's in Assembly and a little bit harder to read. Chances are, most of it won't be very useful to you unless you are familiar with PIC18 ASM.
2005 default code kevin.fort Programming 33 20-01-2005 16:32
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
Updated Encoder Code Available Kevin Watson Programming 2 04-01-2005 01:00
Autonomous Code From Experience EbonySeraphim Programming 7 14-03-2003 21:56
Custom Dashboard code for LabVIEW ready for download. archiver 2001 3 24-06-2002 00:49
