Is it possible to download the code from the robot? We lost the original code and don't want to start from scratch.
Thanks ![]() |
Re: Download code from robot
Yes the program is on IFI's website under the Robot controller section.
One of the problems with this is that you can not actually read the code (at least that I know of) you can only have a copy to redownload in to your robot , not to modify. |
Good luck! ~Stephanie Team 1351 |
If you're feeling ambitious, once you have the file back on your computer you can disassemble it using a program similar to this one
Just remember that once you disassemble it, it's in Assembly and a little bit harder to read. Chances are, most of it won't be very useful to you unless you are familiar with PIC18 ASM. |
| 2005 default code | kevin.fort | Programming | 33 | 20-01-2005 16:32 |
| CMUCam2 Camera Code - Are important parts commented out? | Mr. Lim | Programming | 4 | 14-01-2005 12:11 |
| Updated Encoder Code Available | Kevin Watson | Programming | 2 | 04-01-2005 01:00 |
| Autonomous Code From Experience | EbonySeraphim | Programming | 7 | 14-03-2003 21:56 |
| Custom Dashboard code for LabVIEW ready for download. | archiver | 2001 | 3 | 24-06-2002 00:49 |
