Go to Post Whoooo, just got my wheels from AM! Sometimes it's cool to live in Indiana. - IndySam [more]
Unread 28-05-2005, 18:07
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Re: Hovercraft
I'm thinking that might work, just make sure your fan has the highest RPM you can give it. Watch your weight, that brings the end to a lot of homemade hovercrafts. Also what are your plans for steering the Hovercraft?
Unread 28-05-2005, 18:36
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Hovercraft
Wow, 11 hp. That is really big. I assume that is your propulsion engine? Do you have another engine for lift? Or are you going to somehow duct this one to give lift and propulsion?
Unread 29-05-2005, 11:00
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
Re: Hovercraft
okay here ya go this is how air should flow and lays out the concept
Unread 29-05-2005, 12:27
Vince lau's Avatar
Vince lau Vince lau is offline
Building robots since 1995
FRC #4914
Vince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond repute
Send a message via MSN to Vince lau
Re: Hovercraft
i was going to try this
http://amasci.com/amateur/hovercft.html
Unread 29-05-2005, 12:37
adamrp adamrp is offline
adamrp will become famous soon enough
Re: Hovercraft
Actually, the 11 HP is for lift. We have an 8HP engine for propulsion. I know, this is sort of backwards, but the 11HP has a vertical axle and the 8 has a horizonta axle, so we decided that rather than use differentials and belts we would do it this way. Off to work...
arp
Unread 29-05-2005, 21:53
edomus's Avatar
edomus edomus is offline
AKA: Evan
FLL #1218 (CHAbots)
Team Role: Driver
edomus is on a distinguished road
Send a message via AIM to edomus
Re: Hovercraft
[img]
2004 National Finalists with 469 and 868
2004 Gallileo champions and #1 seed
  • Delphi "Driving tommarows technology" -philly 2004
  • 8th seed philly 2004
  • 58/58 at annapolis 2004 (like the improvement?)
  • Philadelphia Alliance Regional Winner!-2003
  • 7th seed Philly 2003
  • Rookie all star philly 2003
  • semi finalist Pitt 2003
  • picked 3rd in pitt 2003
  • Seeded 17(curie) at nats 2003
Unread 30-05-2005, 15:54
Mike Bortfeldt Mike Bortfeldt is offline
FRC #1126 (& 1511)
Mike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud of
Re: Hovercraft
Edomus,
I recently built a 2-person hovercraft (Universal Hovercraft 12T4) from plans and can hopefully answer some of your questions. First, your 4'x8' platform should be able to lift one person as long as you can generate sufficient pressure from your lift fan (you don't mention what your fan blade was made out of or any of it's characteristics). Universal Hovercraft (UH) sells plans for a 3'x5' beginner hovercraft (UH-6F) that utilizes a 3 to 5 hp engine for both lift and thrust that can handle a 150 lb. payload so your engines are certainly large enough. You may want to think about buying these plans as they will have good general information on building a basic craft (skirt construction, operation, steering, etc.) that you can use when building yours. Larger engines are not necessarily a plus and can in some cases add weight for no useful purpose if your lift & thrust systems aren’t designed to utilize the engine’s capabilities. However, having existing engines available does negate a lot of the downsides.
One thing I would like to stress is to make sure you place guards around both your props. These blades will be going around 3000 RPM and could cause serious injury should they break or have some other failure. I say this from experience. After about 40 minutes of run time on the 12T4, I had a failure of the thrust system that resulted in a broken crankshaft on a 10 hp engine, and a prop split into two pieces. One of these pieces was thrown about 50' right through some lightweight steel mesh (luckily, no one was in the path.). Needless to say, there will be some changes when it’s repaired. You may want to think about making a real duct for the lift & thrust props as not only will you will get better performance, but it can also serve as guarding. You should wire in something like a lanyard kill switch to stop the engines in an emergency. Being homemade, safety should be a priority.
A few other thoughts based on your drawing and previous notes… 1) you may want to lower the hover height to about 6”, as with only a 4-foot width, it might be more stable. 2) I'm not sure if you really want a raised seat, as that will make your CG higher, again affecting stability. 3) I don't see any method to steer the craft. Typically 2 or 3 rudders are placed behind the thrust prop to direct the airflow and steer the craft.
Finally, make sure the props are designed to handle the stresses of running at the speed of the engines (possibly up to 3600 RPM). The props must also be well balanced. An unbalanced prop will cause significant forces and excessive vibration on the engine and craft as well as the prop itself.
Hope some of these comments help, and if you have any more questions, please ask and I will try to answer them. Just remember that the above comments are opinions only. My background is certainly not in hovercraft or prop design!
Mike
Hovercrafts Ian W. Chit-Chat 25 02-07-2002 16:06
