Go to Post Those teams with too much pride will hinder their alliance. Know your strengths and weaknesses and be honest about them. - Andy Brockway [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 29-05-2005, 17:02
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
IE PNG fix
I just found this a few days ago and my CSS question reminded me. Don't know if you've seen this before:
http://homepage.ntlworld.com/bobosola/
Javascript to fix IE's PNG alpha transparency problem. Even no-JS purists shouldn't complain.
Unread 29-05-2005, 19:01
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
Re: IE PNG fix
http://webfx.eae.net/dhtml/pngbehavior/pngbehavior.html - this is what I use a lot to get around the PNG problems w/ IE, but soon that won't be a problem since it will be fixed in IE7
Unread 29-05-2005, 20:30
Programming User
Re: IE PNG fix
Originally Posted by Stephen Kowski
[S]oon that won't be a problem since it will be fixed in IE7
Yep... but only XP SP2 will get IE7, so we could be waiting a while.
Looks like the two methods are pretty much the same. The nice thing about the one I liked to is you just have to put the JS in the head/link to it and it automatically finds and fixes all PNGs, whereas yours requires you to mark it in a special way.
Unread 29-05-2005, 22:16
jonathan lall's Avatar
jonathan lall jonathan lall is offline
FRC #2505 (The Electric Sheep; FRC #0188 alumnus)
jonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond repute
Send a message via MSN to jonathan lall
Re: IE PNG fix
Not that long. The beta for IE7 is coming very soon (so long as you have XP).
The next IE will be giving Firefox a run for its money, matching it pretty much feature for feature (tabs included). If it's finally better, I'll drop Firefox like it's hot... though I have my reservations about that prospect.
But. This doesn't mean you should stop coding for IE6 and lower anytime soon. If the time it took for IE6 to propogate was any indication, using alpha channel transparent PNGs now by themselves is a bad idea.
'Fix It Window' and Programming.... JMac Programming 19 25-01-2005 18:57
Need way to fix power feed on OI Shu Song Electrical 11 25-04-2004 15:03
Pneumatics Problem + possible fix Srkasner Pneumatics 4 24-02-2004 10:39
Software Speed Fix Matthew_H Programming 2 21-02-2004 10:30
Image Discuss: If done. Quick Fix is here CD47-Bot Robot Showcase 2 04-03-2003 20:07
