Go to Post Admiration is universal, it does not exclude those who have achieved past success. - hg273 [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 31-05-2005, 21:22
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Questions about magnets.
Hey all, I'm working on a little project and I was wondering if anyone in the CD community had any answers to the following questions.
Does every magnet have a north and south pole? I would assume so.
If you break a magnet, do those individual pieces now have a N&S pole each?
What is the strongest pole?
What is the most effective way to shield from magnetic fields?
Where can I buy magnets besides at the hardware store?
The stronger the better (but still relatively cheap, and also lightweight).
Unread 31-05-2005, 21:25
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Re: Questions about magnets.
I know some of these.
Yea, all magnets are N & S.
Yes, breaking magnet means N & S pole
Unread 31-05-2005, 21:31
Every magnet has a north and south pole no matter how large or small. (think really small on the surface of a magnetic floppy disk) When you break a magnet you get two magnets and they each have two poles. The poles are generally balanced so neither is stronger. Magnetic fields suscribe to the inverse square law so you can modify a little by putting non magnetic materials between the pole and magnet. Round magnets get a little complicated and some motor magnets have multiple NS pairs but are really individual pole pairs in the same material. Ferrous metals are good for magnetic shields especially those that have high nickel and carbon concentrations. They are more bending the field away than actually shielding. Check out science stores like "the American Science Center" or industrial supply houses like McMaster-Carr. The cheapest are those you salvage out of dead devices, like DC motors, VCRs, disk drives, etc.
Unread 31-05-2005, 21:39
RbtGal1351's Avatar
RbtGal1351 RbtGal1351 is offline
~La Reina de los Robots~
AKA: Stephanie
FRC #1351 (TKO)
RbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to behold
Send a message via AIM to RbtGal1351 Send a message via MSN to RbtGal1351
Why wouldn't the two poles be equal in strength?
2004 Founding member and Arm leader, 2005 Lead programmer, 2006 Controls leader, 2007 Project Manager/President
Thanks for making FIRST such a great experience for me. I'm no longer on 1351, and I'm not currently planning to mentor team 97, but FIRST has meant so much in getting me to where I am now, in life and at MIT, class of 2011.
I met Billfred! He recognized me!
SVR 04: 11th seed - Highest Rookie Seed - Semifinalists w/ 1120 and 568 - GM Industrial Design Award
SVR 05: Semifinalists w/ 8 and 766
SVR 06: 6th seed - Quarterfinalists w/ 368 and 1072
Davis 06: 1st seed - Quarterfinalists w/ 649 and 100 - KPCB Entrepreneurship Award
SVR 07: 36th seed
David 07: 4th seed - Semifinalists w/ 1280 and 692 - Johnson and Johnson Sportsmanship Award
Unread 31-05-2005, 21:41
jdiwnab's Avatar
jdiwnab jdiwnab is offline
Really the Inventor Guy
AKA: Bryan Hartley
FRC #0617
jdiwnab is a jewel in the roughjdiwnab is a jewel in the roughjdiwnab is a jewel in the rough
Neither is stronger. The strength of a magnet is based on the material, the size and somewhat the age. If you took a bar magnet and a Guassmeter (measures magnetic field intensity. 10,000 Gauss=1 Tesla=very strong magnet. 500 is fairly strong), you will see that the N end will have approx the same value as the S end (but one will be negative). Around the middle, you will have nearly 0. The sensor I was using for a science project regularly read about -1.7 Gauss (I guess Earth's magnetic field) and went up to about -+ 100 gauss with the really weak, old magnets the school had.
If you can find an old microwave, then you could find some very strong ring magnets in the "MAGNETRON" (that is really what they are called). I measured one and was getting about -+800 gauss
Proof that Macs will win the platform war: How did Scotty know how to use MacDraft in Star Trek IV?
// random()
I have 100 gmail invites. PM me if you want one.
If they want us to think outside of the box, why do they make us fit in a 38x28x60 inch box?
Beware of Geeks bearing GIFs
Help me test my server software
Unread 31-05-2005, 22:15
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
You can get really strong magnets out of hard drives. I would recommend using old broken ones as working hard drives are expensive.
Unread 31-05-2005, 22:24
Try here for strong magnets: http://search-desc.ebay.com/Neodymiu...Z2QQsacatZ1266
Unread 31-05-2005, 22:32
JoeXIII'007's Avatar
JoeXIII'007 JoeXIII'007 is offline
Pragmatic Strategy, I try...
AKA: Joeseph Smith
FRC #0066
JoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond repute
Send a message via AIM to JoeXIII'007
You can make an electromagnet with some sort of magnetically attractable metal core and a coil of wire plus an electric current to boot. They're usually weaker though. For some really strong magnets, look in any bad trashed audio speaker (not internal to a TV set).
Oh yeah, they do have N&S poles as others have mentioned, when split in two they indeed make two separate magnets. There is no such thing as the strongest pole and the best shielding is space or some seriously magnetic resistant material. I could not name one for you though.
-Joe
Joeseph P. Smith
jpthesmithe.com
University of Michigan - Informatics (B. Sci. 2012)
General Purpose Programmer - Cooperative Institute for Limnology and Ecosystems Research (CILER) at NOAA-GLERL
Unread 31-05-2005, 22:35
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Originally Posted by Joe Ross
I second that. Neodymium magnets are as strong as they get, and eBay is always a fantastic place for good deals.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 31-05-2005, 22:50
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
*rubs hands together* Boy are you in for it....
http://www.amazingmagnets.com
http://www.engconcepts.net/
http://www.wondermagnet.com
The last one also has ferro-fluid.
Also, in response to to one pole of a magnet being "stronger" than another... If a magnet is symmetrical on a plane perpendicular to the poles, then they're the same strength. You can increase the surface gauss at one end by tapering it to a point, however. It doesn't matter if this end is a N or S pole, however.
For lots of info on magnets and stuff, see:
http://www.dansdata.com/magnets.htm
http://www.dansdata.com/magnets2.htm
Unread 31-05-2005, 23:48
That stuff is really cool. I saw on TV something sort of like that which they were developing to use as fluid in off-road racing shocks to essentially change the viscosity in a matter of miliseconds.
Unread 31-05-2005, 23:53
AKA: Dr. Brooks
no team (WRRF)
High permeability material, sold under the trade name "mu metal"
is used to shield magnetic fields.
Unread 01-06-2005, 07:19
Gene,
Do you have a source for mumetal, we are almost out of the sheet stock and I need to replenish but have only been half hearted about looking.
Ferro fluid is not a magnet it is ferrous metal particles suspended in a viscous liquid. It is most commonly used for speaker voice coil cooling. A few drops squirted into the gap between the voice coil and the magnet structure will do a great job of transferring heat to the magnet body and basket assy without changing the damping of the speaker.
Unread 01-06-2005, 11:53
Greg Young Greg Young is offline
Science Enabler
FRC #0587 (Hedgehogs)
Greg Young has a spectacular aura aboutGreg Young has a spectacular aura about
Lord Corporation (http://www.lord.com/Default.aspx?tabid=718) has been developing magnetorheological fluid applications for several years. The site has lots of interesting information and applications.
There must be a way to make a continuously variable transmission for a FIRST robot using this stuff, but I haven't come up with one yet.
Unread 24-02-2006, 10:53
ender7 ender7 is offline
ender7 is an unknown quantity at this point
NeoWorld Magnets is a good site for lots of different kinds of really strong magnets and magnetic jewelry.
47 Questions! Matt Krass Games/Trivia 52 19-04-2006 00:58
Q/A questions so far.. AmyPrib Rules/Strategy 49 28-01-2005 08:39
**FIRST EMAIL**/Autodesk Inventor Training and Technical Questions Information Rich Wong FIRST E-Mail Blast Archive 0 07-12-2004 17:22
3 Questions!!! (2/20/04) Andy Grady General Forum 20 20-02-2004 17:31
