I'll pick you up anytime. (with a claw)
Unread 30-05-2005, 21:44
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
C#
Well I downloaded Microsoft Visual C# 2005 Beta 2 today (for those interested, it's a free version and I definitely recommend you try it out) and so far the learning curve has been minimal. Now I'm stuck on a problem, and searched Google and everywhere else but theres really no good sized, active C# forums. Does anybody know of any? In the meanwhile, I might as well post my question here.
I am trying to enable a timer by pushing the left button on the keyboard. I used MSVC#'s Method Creating tool, so I know the method declarations are right... but it's not working. Here's my code:
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Text;
using System.Windows.Forms;
namespace Simulator
    public partial class frmMain : Form
        public frmMain()
            InitializeComponent();
        private void tmrRobot_Tick(object sender, EventArgs e)
            pictBot.Location = new System.Drawing.Point(100, 100);
        private void frmMain_KeyPress(object sender, KeyPressEventArgs e)
            tmrRobot.Enabled = true;
http://www.mikesorrenti.com/
Unread 01-06-2005, 00:38
TimCraig TimCraig is offline
AKA: Tim Craig
TimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to behold
Re: C#
I find www.codeproject.com is a valuable programming resource. Although I don't pay any attention to the toy language C#, I know they have a lot of code samples for it and there's probably a forum.
Unread 01-06-2005, 09:40
Mike's Avatar
AKA: Mike Sorrenti
Re: C#
Thanks, for anyone interested I found the problem. I also had a button on my form, which was taking focus away from it. On frmMain I had to set KeyPreview to true, so that way the keypresses are sent to the form first, not the button.
