Go to Post According to that logic, Engineers would say there will be twice as many spectators as needed, and we all know that's not the case! - Taylor [more]
Unread 01-06-2005, 21:08
Blacklight Blacklight is offline
Blacklight is an unknown quantity at this point
Exclamation Adding Bluetooth to Vex
I'm working on a personal project....I'm an Telecomm. engineering student @ Egypt.
I got the kit,still building it, and had the idea of interfacing VEX byPC via bluetooth....
I'm totally new to the robotics scene...
I've gone through loads of Bluetooth modules and am not sure how to program them and connect them to the microcontroller?!
Any help would be much obliged, I'm a bit lost in this...
thanx
Unread 01-06-2005, 21:51
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: Adding Bluetooth to Vex
thanx
I believe this is possible.
#1 You will have to get the programmer for the VEX kit or build your own.
#2 I would get a bluetooth module that you could hook up to the outputs of the VEX -- I am not sure but I think THIS RADIO from Sparkfun.com may be something like what you'd want to use (look here for pricing) . I like this radio made by Smart Modular and sold by ZBAUSA.com, but it used RS-232 voltage levels which would require a MAX232 chip or some such to get the VEX board to communicate with it (another possible down side is that the Smart Modular radio is BTClass 2.0 -- 10m range -- while the Sparkfun one is BT Class 1 -- 100m range).
#3 You will have to get Bluetooth on your PC somehow either built in or from a UBS-Bluetooth Dongle -- very cheap -- or some other way. Once you have that set up the remote BT looks like a standard PC comm port. You will not have to manage the BT stack or any of that non-sense. It is pretty straightforward actually. Sparkfun.com has a "Bluetooth Primer" that shows how easy the BT bit is.
#4 I would get the code from Kevin Watson Kevin.org HERE
where he publishes his code to make a serial port out a standard I/O pin of the PIC chip. From what I have gathered there are some differences between the FRC and the VEX boards so you will have to port the code somewhat but they use the same micro so you should be able to muddle through pretty easily.
#5 You will have to modify the VEX default code to get messages from the serial port rather than from the Rx radios. Not too complicated I would guess because the VEX machines are supposed to be easily used in autonomous mode. This would look just like an automonomous mode only with information coming in from the serial port.
Finally, one more thing. This document and the related discussion may help you (thanks to dez250 for sharing the paper and starting the thread).
Good luck.
Joe J.
Team #88, TJ2
Unread 02-06-2005, 16:26
Thank You So Much - Joe!!
The info supplied seem so useful already!
I can see I have alot to read, and alot to order too
Making the programming module would be a toughy though...
components are not easy to find here in Egypt, So I'm wondering what's the easiest way to make one ( easiest as in one would least components to look for)?
Unread 27-09-2005, 20:50
CyberTroniX CyberTroniX is offline
CyberTroniX is an unknown quantity at this point
Is it possible to conenct the bluetooth module to Rx1 instead of the serial of the microcontroller ??
Unread 27-09-2005, 21:09
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
Im not that familliar with VEX but maybe a gumstix (www.gumstix.com). They have built in bluetooth and I know they work fine with the IFI controller.
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
Unread 29-09-2005, 19:17
i sent a message to the manufacturers of the bluetooth module and they told me it can only be connected to any UART .
so i don't know if the Rx1 on Vex is UART or not ?
Unread 29-09-2005, 20:22
foobert foobert is offline
foobert is a jewel in the roughfoobert is a jewel in the roughfoobert is a jewel in the rough
yes, rx1 and tx1 are connected to rg1 and rg2 on the user processor. these are the receive and transmit pins respectively of usart2.
Unread 30-09-2005, 16:41
thanks for the info
do u know the pinout of Rx1 ?
i am also trying to get the schematic of the circuit that has the micrcontroller on in , because i want to know how is the microcontroller is connected to Rx1 or Serial .
Anyone knows how these are connected ??
Unread 30-09-2005, 21:26
thanks for the info
i made a little chart. i was planning to add more info, but got sidetracked. the functions of the various pins on the 18f8520 can be determined from the datasheet. as i mentioned rx1 and tx1 are connected to rg1 and rg2 which are also known as rx2 and tx2. the transmit and receive lines on the serial port are connected to rx1 and tx1. very confusing, eh?
anyway, i got the information from the example code at vexlabs.
Unread 01-10-2005, 21:16
i'm a bit confused ..
if i can connect the bluetooth module ( which has 4 pins : TX , RX , PWR , GND ) to Rx1 , do i connect it to Rx1 which was used for the RF Module that came with the robot ? or do i connect it to RX & TX that are on the Analod/Digital section of the microcontroller ?
if it's the 1st option then i need to know the pinouts of the Rx1 input ,
if it's the 2nd option then i need to know where to connect the PWR & GND pins of the bluetooth module ?
Something else i'm thinking of doing it ... which is replacing the RF Module on the Remote Control Unit with a bluetooth module . Is it possible ??
Unread 19-06-2006, 13:35
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Let me re-emphasize this. You'll probably have a lot less trouble if you just buy the 400MHz Gumstix with Bluetooth, which will run you about $169. Connect one of the serial ports on the Gumstix to the Vex, and write a couple of lines of code on the Gumstix to redirect I/O from the wired serial port to the Bluetooth UART. Then you have your Bluetooth Vex, and you have a nifty off-board co-processor should you ever need it.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 01-10-2005, 21:24
Good luck.
Joe J.
Why use the serial input although i can use Rx1 ??
Unread 01-10-2005, 21:56
ok. i have been confused.
my controller is still sandwiched in the middle of my squarebot so i was unable to actually look at it and see the labels on anything. i was under the impression that you were referring to the i/o pins labelled rx and tx on the top side of the controller. connect your blue tooth module to them.
rx1 and rx2 on the back, (?), side of the controller are not serial ports. they are for connecting the vex radio receivers. they wouldn't know an rs232 protocol if it jumped up and bit them on the... well, you know. they expect six channels of pwm data which your bluetooth module will be unlikely to produce.
sorry for the confusion.
mea culpa.
Unread 02-10-2005, 00:10
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
mea culpa.
I wouldn't say they aren't serial - they are somehow modulated as there are only 4 conductors there and you have 6 chans of PWM there, so something has to happen to squeeze that onto 4 pins. I would guess, however, that it isn't RS232 but rather some proprietary protocol. If you knew the protocol that was sent there you could use another PIC to convert RS232 to that protocol, but that would be pretty pointless and a lot more work, unless you didn't want to spend $100 on a Vex programming kit and already had a PIC programmer.
I think what foobert is referring to are the TX/RX TTL pins on the same header as the Analog In/Digital IO ports. Note that to do full RS232 you likely need a level converter as well, as I'm pretty sure they are only TTL level.
Unread 02-10-2005, 22:19
ok, last things first. the bluetooth modules these guys are considering are ttl, so no level converter is required.
that was pretty easy, so on to the first thing. the inputs to rx1 and rx2 are ppm which is a sort of multiplexed pwm signal.
the way i understand it is this. for the six channels on the vex radio, you get seven short pulses. the time from the beginning of the first pulse to the beginning of the second pulse is the duty cycle for the 1st channel pwm, the time from the beginning of the second pulse to the beginning of the third pulse is the duty cycle for the 2nd channel pwm, etc.
so the data for the six channels take anywhere from 6 to 12 ms depending on the sum of their duty cycles. these are followed by the seventh pulse and a lengthy pause of say six to twelve ms before the next data frame is sent. the long pause allows the receiver to synchronize the data frames.
hope that makes sense.
how to build a VEX programming module bblack7489 FIRST Tech Challenge 78 09-06-2011 16:03
Useful VEX Tools Joe Johnson FIRST Tech Challenge 4 26-04-2005 18:48
Vex Robotics Vex FIRST Tech Challenge 0 14-04-2005 13:48
VEX Robotics vexrobotics FIRST Tech Challenge 8 30-03-2005 23:25
VEX Kits ARRIVED!!! Joe Johnson FIRST Tech Challenge 14 28-03-2005 19:28
