Go to Post Welcome to a Chief Delphi poll, where the responses are made up and the numbers don't matter. - JohnSchneider [more]
Unread 30-05-2005, 00:03
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Re: Most Impressive/Advanced/Unique/Cool drivetrain you've ever seen
Originally Posted by santosh
About how much extra time did that take compared to building just a regular holonomic drivetrain? Also, how many feet/second did you get?
The particular design we developed was very easy to build. There are only three machined parts in each drive module (the modified gear, the structural support strut, and a small bracket that holds the load bearing in place). The drive modules can be used in either the cambered holonomic drive configuration (our version) or the traditional orthogonal holonomic drive configuration. In fact, we used the modules in the traditional configuration on our test robot for software development. So the answer is that it didn't take any longer to make this version vs. a traditional version. With regard to linear speed of the robot, it was designed for 10 ft/second. But it was never actually timed to determine real performance, so we can't attest to the actual speed.
-dave
Unread 30-05-2005, 21:16
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
http://www.invisiblerobot.com/roboti.../p1010464.html
http://www.invisiblerobot.com/roboti.../p1010469.html
Those two pictures show some of the design shots of the drive system, hopefully giving a bit better idea of what we did. In simple terms, its a normal holonomic drive tilted on it's side.
*edit*
http://www.firstrobotics.uwaterloo....vetrains022.jpg
Although it's only an external view, 33's 4 speed, shift on the fly, automatic transmission last year kicked butt.*edit*
Unread 31-05-2005, 00:43
CRAZYMADI CRAZYMADI is offline
CRAZYMADI can only hope to improve
Not far away from team 116, Team 612 worked on their Aukerman Steering Drive System.
Unfortunatly, only 2 days beofre the ship date, Team 612 end up breaking some of the major parts of the drive system during the DC scrimmage clash. Its kind of sad story. Team 612 worked all six weeks wokring on this drive system, and then they have to switch back to tank drive within 48 hours of time span.
Unread 31-05-2005, 12:05
Dave.Norton Dave.Norton is offline
FRC #1157
Dave.Norton is an unknown quantity at this point
Hi;
Couple of questions for you; why the 82 degrees (I have some ideas, by why speculate)? The second is how did you control it? We went with an orthogonal holonomic drive this year, but discovered the unfortunate fact that 3 points define a plane, but 4 are over-constrained. Which is to say every time we hit an uneven spot in the floor whoever had the traction won and the robot went in that direction. We solved it in two ways, first added a yaw sensor so at least it knew what a straight line was, and then added a suspension so that all wheels maintained traction. This design looks even more interesting because it is inscribing arcs; at least ours was in a vector.
Thanks.
Unread 31-05-2005, 12:26
Holtzman's Avatar
Holtzman Holtzman is offline
Sometimes...
AKA: Tyler Holtzman
FRC #2056 (OP Robotics)
Holtzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond repute
Send a message via MSN to Holtzman
I'm very surprised that no one has mentioned 47's swerve drive from the year 2000. It was, at the time, revolutionary. By todays standards, it may not seem all that cool, but 5 years ago, when it was one of the first strafing robots in FIRST, it was really something else. It gave 47 a clear advantage that year and served as the inspiration to many future swerve drives. It was well before my time coming to FIRST but I'm still inspired.
My thanks for FIRST Mechanism library for the pics
ID:	3438  Click image for larger version
ID:	3439  Click image for larger version
"making the simple complicated is commonplace; making the complicated simple, awesomely simple, that's creativity." - Charles Mingus
Unread 31-05-2005, 15:51
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Originally Posted by Dave.Norton
Hi;
Thanks.
As you can imagine, a completely flat omni-wheel wouldnt work properly, and because the surface isnt entirely flat, if you had your tilt too low, the same problems would occur. You don't want the wrong omni wheels to be toching the ground, or else you'd get unecisarry scrubbing of the wheels. So, we places the wheels at enough of an angle to eliminate that, but still greatly improve our stability.
We had some issues with wheels getting more traction than others, especially when we we're driving on and off the loading zones. But we solved it by "shimming" the wheels so all four we're completly co-planar with the floor, and by using the white neoprene wheels.
Unread 31-05-2005, 15:55
xzvrw2's Avatar
xzvrw2 xzvrw2 is offline
Its been a long time.
AKA: Stevie Alvarado
FRC #0065 (The Huskie Brigade)
xzvrw2 has a reputation beyond reputexzvrw2 has a reputation beyond reputexzvrw2 has a reputation beyond reputexzvrw2 has a reputation beyond reputexzvrw2 has a reputation beyond reputexzvrw2 has a reputation beyond reputexzvrw2 has a reputation beyond reputexzvrw2 has a reputation beyond reputexzvrw2 has a reputation beyond reputexzvrw2 has a reputation beyond reputexzvrw2 has a reputation beyond repute
Send a message via AIM to xzvrw2
I like 71 in 2002, 111, 25, 16, and 65 in 2003, 111, I forgot what team number it was (im saddend now) but at detroit that had three front wheels that spun at one point, 65, and 2005 i liked 79, 71, 111, and once again 65. I love our drivetrain.
2003
111: http://www.wildstang.org/gallery/view_photo.php?full=1&set_albumName=2003_electrica l&id=2003_02_01_Electrical_005
http://www.wildstang.org/gallery/view_photo.php?set_albumName=2003_electrical&id=20 03_02_01_Electrical_011
25: http://firstrobotics.net/03gallery/i...0025-1_jpg.jpg
16: http://firstrobotics.net/03gallery/i...0016-1_jpg.jpg
65: if you seen this years drive trainf, picture that but faster and cool wheels
2004
111: http://www.wildstang.org/main/video.php that video should explain it
???: urg what was that team number
65: I have noticed that we have no pictures of our robots it past years any where to be found. I want to change that.
2005
65: finally http://www.chiefdelphi.com/forums/pictures.php?s=&action=single&picid=11238&directio n=DESC&sort=date&perrow=4&trows=10&quiet=Verbose
79: http://krunch79.com/gallery/displayi...?album=7&pos=8
http://krunch79.com/gallery/displayi...?album=7&pos=7
71: i con't find any good pictures of them
111: http://www.wildstang.org/gallery/view_photo.php?full=1&set_albumName=2005_NBC_Demo& id=IMG_2493
my FIRST acomplishments: 2003:GLR Chairmans winner, MWR Finalist, Archimedes Division winner, National Champion (w/ 111 and 469) 2004:MWR Finalist 2005:GLR Chairmans winner, MWR Finalist, MWR Innovation in Controls award 2006:hmmm wow, umm we got picked 4th overall at Nats by 121
my FIRST resume: 65 (2003-2006)
Unread 31-05-2005, 23:39
ChrisCook's Avatar
ChrisCook ChrisCook is offline
We accelerate!
FRC #0670 (Mustang Robotics (HRT))
ChrisCook has a spectacular aura aboutChrisCook has a spectacular aura about
Send a message via AIM to ChrisCook Send a message via MSN to ChrisCook Send a message via Yahoo to ChrisCook
Hey We did something similar but i need to find the pictures for it, Do you have any sensor feed back on your robot to control its direction? contact me and we'll compare notes.
HRT Mentor --- We accelerate!
Unread 01-06-2005, 00:04
santosh's Avatar
santosh santosh is offline
AKA: 2415
FRC #2415
santosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond repute
Send a message via AIM to santosh
This year, what we did is we set all of our 4 omniwheels in the corner of our bot and set them at 45 degres. This allowed us to be able to strafe and spin in place and spin while moving forward. I think we had 8 ft per second.
We were the team that spun in circles for 2 matches on the Newton Field this year. We also had a piston in the middle of the robot that pushed down which cause all of our drive modules to expand. It gave us 4 inches on each side. This helped us with out stability.
We used field forward, and the fact that there were so many factors that affected our compass, we had to turn to robot forward, and this caused us to be bad at controlling our robot. But overall, it was cool
2004 - 2007 = 1002
2007 - 2011 = Founding Mentor of 2415
6 regional wins, 3 EIs, 3 Chairmans
kiddies kiddies kiddies
Unread 01-06-2005, 19:00
NeedMoreEngines's Avatar
NeedMoreEngines NeedMoreEngines is offline
AKA: Mike
FRC #1279 (Cold Fusion)
Team Role: Driver
NeedMoreEngines has a spectacular aura aboutNeedMoreEngines has a spectacular aura about
Send a message via AIM to NeedMoreEngines
Thumbs up Re: Most Impressive/Advanced/Unique/Cool drivetrain you've ever seen
Originally Posted by sanddrag
Post a pic/link of the most Impressive, Advanced, Unique, or Cool drive system you have ever seen. Also write a couple comments about why you think it is so good. Please nobody post their own, we all already know each of ours is the best.
At nationals there was the coolest drivetrain i have ever seen. I think it was teem 738 or 278 or 378, I don't remember. they were in Newton and their colors were yellow and purple. They made their own wheel system and they called it Jester Drive. It was really called Mechanum Drive, some brilliant swedish design. It allowed the robot to go in every direction depending upon how the wheels turned. It was the coolest thing i had ever seen...way cooler than omni wheels or tracks or 6wd or anything i had ever seen.
You guys know who you are...it was insane.
"There is only one solution to this problem- We need more engines."
The good thing about the YMCA is if you can spell, you can dance.
Proud Eagle Scout
Unread 01-06-2005, 22:05
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
That's team 357. While a mechanum drive is quite impressive, teams have done them before.
Holonomic drives, such as 1002's, and 116's. or kiwi drives like 857's also can drive in any direction instantly.
Unread 02-06-2005, 00:04
santosh's Avatar
AKA: 2415
FRC #2415
Can some one please explain Kiwi Drive?
2004 - 2007 = 1002
Unread 02-06-2005, 00:08
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Couple Videos:
http://stuweb.ee.mtu.edu/~alkrajew/FIRST/kiwi.mpg
http://www.team229.org/site/video/11...kiwiparody.wmv
Unread 02-06-2005, 00:10
santosh's Avatar
AKA: 2415
FRC #2415
56k+ Online Videos = No Solution lol Thanks though
2004 - 2007 = 1002
Unread 02-06-2005, 00:16
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
its similar to what your team (1002) did, except instead of 4 omni-wheels 90 degrees apart, it had 3 omniwheels 120 degrees apart.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
pic: Team 1293's Window Motor Drivetrain 2 Billfred Robot Showcase 18 03-02-2005 23:33
drivetrain mouts and gears Andrew Dahl Technical Discussion 3 22-01-2003 13:21
Best source for gears? Smallparts? drivetrain advice wanted! Frank(Aflak) Technical Discussion 11 10-01-2003 17:22
What motors power your drivetrain? Khalicl13 Motors 35 03-12-2002 16:33
Computer modeling of drivetrain and devices archiver 2000 1 23-06-2002 23:02
