Go to Post My wife is in advertising, and uses a scary amount of math. They have to know how to target you and beat down your defenses, so that you buy that hamburger while driving that car while wearing those designer jeans to your favorite store. - Not2B [more]
Thread Tools Rating: Thread Rating: 19 votes, 5.00 average. Display Modes
Unread 02-06-2005, 10:59
ImmortalAres ImmortalAres is offline
ImmortalAres is an unknown quantity at this point
Accelerometer code
I've been working on writing code for an accelerometer that outputs a PWM signal. I've been trying to adapt some of Kevin's code that dealt with an infrared sensor that output PWM signals.
the following is Kevin's with a few variable name changes
switch(RB5_State) // current state determines how the function behaves
case 0: // falling-edge detected (beginning of the pulse)
Int_4_Down_Edge_Count_High = Clock; // get a snapshot of the time
tbuf = TMR1L; // TMR1L must be read before TMR1H
Int_4_Down_Edge_Count_Low = TMR1H;
Int_4_Down_Edge_Count_Low <<= 8;
Int_4_Down_Edge_Count_Low += tbuf;
break; // now wait for the rising-edge interrupt to happen...
case 1: // rising-edge detected (end of the pulse)
Int_4_Up_Edge_Count_High = Clock; // get a snapshot of the time
tbuf = TMR1L;
Int_4_Up_Edge_Count_Low = TMR1H;
Int_4_Up_Edge_Count_Low <<= 8;
Int_4_Up_Edge_Count_Low += tbuf;
// determine the pulse-width period by determining the time
// difference between the falling-edge and rising-edge interrupts
if (Int_4_Up_Edge_Count_High == Int_4_Down_Edge_Count_High)
// this is quicker because the 16-bit system clock hasn't changed and therefore has no effect on the outcome
Int_4_Period = Int_4_Up_Edge_Count_Low - Int_4_Down_Edge_Count_Low;
else
//this works because the pulse-width will always be less than one clock tick(= 65536 timer ticks)
//(=0.0000001 seconds) 1 * 10^-7 sec (0.1 micro seconds)
Int_4_Period = 65536 - Int_4_Down_Edge_Count_Low + Int_4_Up_Edge_Count_Low;
break; // now wait for another falling-edge interrupt to happen...
now i have my accelerometer plugged into digital input 3 and 4 (x and y PWMs) as far as i can tell the RB5 pin never switches state because when i printf("data:%d",Int_4_Down_Edge_Count_High); or Int_4_Up_Edge_Count_High the value is always 0 so the clock value never gets assigned meaning it never entered the switch statement.
It does the same thing for the interrupt on digital input 3
Any words of advice or help would be greatly appreciated. Thanks.
Unread 02-06-2005, 13:27
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: Accelerometer code
(Use [code] brackets when applicable. )
Well... Could we see the rest of the code? One thing I can think of right now is the docs recommend putting a \r at the end of the printf... :shrug:
Unread 02-06-2005, 13:33
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Some questions:
1) Are you setting up and enabling the interrupts? If so, let's see the code.
2) Is your function getting called from InterruptHandlerLow()?
3) What platform are you using?
4) Which accelerometer are you using?
-Kevin
Kevin Watson
http://kevin.org
Unread 02-06-2005, 13:34
Joel J's Avatar
Joel J Joel J is offline
do you..
I wrote one for a 202/210 earlier this year.. I'll attach it. At first, I didn't know what I was doing, but then after I got out some paper and did the math/optimization it ended up exactly like Kevin Watson's gyro code. It was kinda weird. But anyway, because of the similarity, I just used his framework so everything would make sense more quickly to those who already used it.
If you look at the h file, you see the variables you have to setup. If you look at the clock, and the resolution it gives, then you quickly realize why the limitations of the PIC we use would make data from the accel useless once we start integrating, but I'll leave the deciding up to you.
ACCEL_SCALE_FACTOR is the same as the k in the manual. There is a defined value for it, but you have to test the accel inline with gravity to see where 1g is.
ACCEL_CLOCK_RATE / ACCEL_SAMPLES_PER_UPDATE should never really be less than 50, I guess. I don't remember my exact reason for setting it to three at the time (so maybe commenting isn't such a bad idea ).
accel.h
* FILE NAME: x_accel.h <FRC VERSION>
* DESCRIPTION:
*  This file contains all the header information for x_accel.c.
#ifndef _X_ACCEL_H_
#define _X_ACCEL_H_
/* Put long list of definitions here - ALA user_routines.h in 2004 */
#define FALSE 0
#define TRUE !FALSE
#define ACCEL_SCALE_FACTOR			85 / 1000		/* T1 width that represents 1g of acceleration */
#define ACCEL_SCALE_FACTOR_INVERSE	1000 / 85		/* T1 width that represents 1g of acceleration, inverted */
#define ACCEL_CLOCK_RATE			12800			/* Frequency of the clock used for timing t1 and t2 */
#define ACCEL_SAMPLES_PER_UPDATE	3				/* Number of samples to average for one acceleration output */
void Initialize_Accelerometer(void);
void Disable_Accelerometer(void);
long Get_Acceleration_X(void);
long Get_Acceleration_Y(void);
void Set_Velocity_X(long);
void Set_Velocity_Y(long);
long Get_Velocity_X(void);
long Get_Velocity_Y(void);
void Start_Accelerometer_Bias_Calc(void);
void Stop_Accelerometer_Bias_Calc(void);
void AccelTask_X(void);
void AccelTask_Y(void);
#endif
accel.c
* FILE NAME: x_accel.c <FRC VERSION>
* DESCRIPTION:
*  This file contains all that is needed to receive information from the
*  accelerometer.
#include "ifi_aliases.h"
#include "ifi_default.h"
#include "ifi_utilities.h"
#include "x_accel.h"
#include "x_timer.h"
volatile unsigned int accel_bias_x;
volatile unsigned int accel_bias_y;
volatile signed int accel_accel_x;
volatile signed int accel_accel_x_prev;
volatile signed int accel_accel_y;
volatile signed int accel_accel_y_prev;
volatile long accel_velocity_x;
volatile long accel_velocity_y;
volatile unsigned int accum_x;
volatile unsigned int accum_y;
volatile unsigned char samples_x;
volatile unsigned char samples_y;
volatile unsigned long bias_accum_x;
volatile unsigned long bias_accum_y;
volatile unsigned int bias_samples_x;
volatile unsigned int bias_samples_y;
volatile unsigned char accel_task_x_state;
volatile unsigned char accel_task_y_state;
volatile unsigned long accel_clock_x;
volatile unsigned long accel_clock_y;
volatile unsigned long accel_x_t1;
volatile unsigned long accel_y_t1;
volatile unsigned long accel_t2;
volatile unsigned long accel_t2_sum;
unsigned char calc_accel_bias;
	accum_x = 0;
	accum_y = 0;
	samples_x = 0;
	samples_y = 0;
	accel_accel_x_prev = 0;
	accel_accel_y_prev = 0;
	accel_velocity_x = 0;
	accel_velocity_y = 0;
	accel_task_x_state = 0;
	accel_task_y_state = 0;
	calc_accel_bias = FALSE;
	// initialize external interrupt 1 (INT2 on user 18F8520)
	TRISBbits.TRISB2 = 1;		// make sure the RB2/INT2 pin is configured as an input [108]
	INTCON3bits.INT2IP = 0;		// 0: interrupt 1 is low priority (leave at 0 for IFI controllers) [91]
	INTCON2bits.INTEDG2 = 1;	// 1: trigger on the rising-edge
	INTCON3bits.INT2IE = 1;		// 1: enable interrupt 1
	// initialize external interrupt 2 (INT3 on user 18F8520)
	TRISBbits.TRISB3 = 1;		// make sure the RB3/CCP2/INT3 pin is configured as an input [108]
	INTCON2bits.INT3IP = 0;		// 0: interrupt 2 is low priority (leave at 0 for IFI controllers) [90]
	INTCON2bits.INTEDG3 = 1;	// 1: trigger on the rising-edge
	INTCON3bits.INT3IE = 1;		// 1: enable interrupt 2
	INTCON3bits.INT2IE = 0;
	INTCON3bits.INT3IE = 0;
long Get_Acceleration_X(void) // returns in m/s/s multiplied by 10000
	long temp_accel_accel_x;
	temp_accel_accel_x = (long)accel_accel_x;
	return (temp_accel_accel_x * (long)98000 / (long)accel_t2 / (long)ACCEL_SAMPLES_PER_UPDATE * (long)ACCEL_SCALE_FACTOR_INVERSE);
long Get_Acceleration_Y(void) // returns in m/s/s multiplied by 10000
	long temp_accel_accel_y;
	temp_accel_accel_y = (long)accel_accel_y;
	return (temp_accel_accel_y * (long)98000 / (long)accel_t2 / (long)ACCEL_SAMPLES_PER_UPDATE * (long)ACCEL_SCALE_FACTOR_INVERSE);
long Get_Velocity_X(void) // returns in m/s multiplied by 10000
	long temp_accel_velocity_x;
	temp_accel_velocity_x = accel_velocity_x;
	return (temp_accel_velocity_x * 98000L / (long)ACCEL_CLOCK_RATE * (long)ACCEL_SCALE_FACTOR_INVERSE);
long Get_Velocity_Y(void) // returns in m/s multiplied by 10000
	long temp_accel_velocity_y;
	temp_accel_velocity_y = accel_velocity_y;
	return (temp_accel_velocity_y * 98000L / (long)ACCEL_CLOCK_RATE * (long)ACCEL_SCALE_FACTOR_INVERSE);
void Set_Velocity_X(long temp_accel_velocity_x) // input in m/s multiplied by 10000
	accel_velocity_x = temp_accel_velocity_x * (long)ACCEL_SCALE_FACTOR * (long)ACCEL_CLOCK_RATE / 98000L;
void Set_Velocity_Y(long temp_accel_velocity_y) // input in m/s multiplied by 10000
	accel_velocity_y = temp_accel_velocity_y * (long)ACCEL_SCALE_FACTOR * (long)ACCEL_CLOCK_RATE / 98000L;
	if(calc_accel_bias == FALSE)
		bias_accum_x = 0;
		bias_accum_y = 0;
		bias_samples_x = 0;
		bias_samples_y = 0;
		calc_accel_bias = TRUE;
		accum_x = 0;
		accum_y = 0;
		samples_x = 0;
		samples_y = 0;
		accel_t2 = 0;
		accel_t2_sum = 0;
	if(calc_accel_bias == TRUE)
		accel_bias_x = (unsigned int)(bias_accum_x / (long)bias_samples_x);
		accel_bias_y = (unsigned int)(bias_accum_y / (long)bias_samples_y);
		accel_t2 = accel_t2_sum / (((unsigned long)bias_samples_y * (unsigned long)ACCEL_SAMPLES_PER_UPDATE) + (unsigned long)samples_y - (unsigned long)1);
		accum_x = 0;
		accum_y = 0;
		samples_x = 0;
		samples_y = 0;
	accel_clock_x = Get_Clock_12800();
	switch(accel_task_x_state)
		case 0:	// Very first time
				accel_x_t1 = accel_clock_x;
				accel_task_x_state = 1;
				INTCON2bits.INTEDG2 = 0;
				break;
		case 1:	// Has fallen from 1 to 0
				accel_x_t1 = accel_clock_x - accel_x_t1;
				accel_task_x_state = 2;
			break;
		case 2:	// Has risen from 0 to 1, and not first time
				accum_x = accum_x + (unsigned int)accel_x_t1;
				samples_x++;
				if(samples_x >= ACCEL_SAMPLES_PER_UPDATE)
						bias_accum_x = bias_accum_x + (unsigned long)accum_x;
						bias_samples_x++;
					else
						accel_accel_x = (signed int)(accum_x - accel_bias_x);
						accel_velocity_x = accel_velocity_x + (((long) accel_accel_x + (long) accel_accel_x_prev)>>1);
						accel_accel_x_prev = accel_accel_x;
					accum_x = 0;
					samples_x = 0;
				break;
		default:
	accel_clock_y = Get_Clock_12800();
	switch(accel_task_y_state)
				accel_y_t1 = accel_clock_y;
				accel_task_y_state = 1;
				INTCON2bits.INTEDG3 = 0;
				break;
				accel_y_t1 = accel_clock_y - accel_y_t1;
				accel_task_y_state = 2;
				break;
				accum_y = accum_y + (unsigned int)accel_y_t1;
				samples_y++;
				if ((accel_t2 == 0) && (calc_accel_bias == TRUE))
					accel_t2 = accel_clock_y;
				} else if (calc_accel_bias == TRUE)
					accel_t2_sum = accel_t2_sum + accel_clock_y - accel_t2;
					accel_t2 = 0;
				if(samples_y >= ACCEL_SAMPLES_PER_UPDATE)
						bias_accum_y = bias_accum_y + (unsigned long)accum_y;
						bias_samples_y++;
					else
						accel_accel_y = (signed int)(accum_y - accel_bias_y);
						accel_velocity_y = accel_velocity_y + (((long) accel_accel_y + (long) accel_accel_y_prev)>>1);
						accel_accel_y_prev = accel_accel_y;
					accum_y = 0;
					samples_y = 0;
				break;
		default:
put this in user_routines.c :: void User_Initialization (void), after including the accel.h file:
Initialize_Accelerometer();
and then put calls to AccelTask_X() and AccelTask_Y() in the respective interrupts (X is on 1, and Y is on 2, I believe -- if you change, then modify the Initialize function of the accelerometer also) in user_routines_fast.c :: void InterruptHandlerLow ()
x_timer.h
* FILE NAME: x_timer.h <FRC VERSION>
* DESCRIPTION:
*  This file contains all the header information for x_timer.c.
#ifndef _X_TIMER_H_
#define _X_TIMER_H_
/* Put variables here */
/* Put function prototypes here */
void Timer2Task(void);
unsigned long Get_Clock_12800(void);
void Set_Clock_12800(unsigned long);
void Initialize_Timer_2(void);
void Initialize_Timer_4(void);
#endif
x_timer.c
* FILE NAME: x_timer.c <FRC VERSION>
* DESCRIPTION:
*  This file contains all that is needed to have nice timers.
#include "x_gyro.h"
volatile unsigned long Clock_12800 = 0;
	static unsigned char divisor = 0;
	Clock_12800++; // increment the clock
	/* if (++divisor >= 8) // This is the 800Hz clock
		divisor = 0;
		GyroTask();		// Do gyro stuff..
	unsigned long temp_clock_12800;
	PIE1bits.TMR2IE = 0;
	temp_clock_12800 = Clock_12800;
	PIE1bits.TMR2IE = 1;
	// return the clock_25000 to caller
	return(temp_clock_12800);
void Set_Clock_12800(unsigned long temp_clock_12800)
	Clock_12800 = temp_clock_12800;
*	FUNCTION:		Initialize_Timer_2()
*	PURPOSE:		Initializes the timer 2 hardware.
*	CALLED FROM:	user_routines.c/User_Initialization()
*	PARAMETERS:		None
*	RETURNS:		Nothing
*	COMMENTS:		Timer 2 documentation starts on page 141 of the data sheet.
*					Timer 2 will be setup with these parameters to generate
*					a 1000Hz interrupt rate:
*					1) The prescaler is set to divide the 10MHz system clock
*					by 4 (i.e., 1:4) so that TMR2 will be clocked at 2.5MHz.
*					2) The PR2 register is set to 249 so that the TMR2
*					register will roll-over (i.e., transition from 249 -> 0)
*					at a 10,000Hz rate (2.5MHz/250).
*					3) The postscaler is set to generate an interrupt every
*					tenth time the TMR2 register rolls-over (10,000Hz/10=1000Hz).
*					4) The timer 2 interrupt enable bit (TMR2IE) is set to
*					1 to enable the timer 2 interrupt.
*					5) Finally, timer 2 is allowed to run by setting the TMR2ON
*					bit to 1.
{	// This timer running at 12800Hz
	// 6400:	1:4, 1:15, 24
	// 12800:	1:4, 1:15, 11
	// 25600:	1:16, 1:6, 2
	// 51200:	1:4, 1:12, 2
	TMR2 = 0x00;				// 8-bit timer 2 register (this is readable and writable)
	PR2	= 24;				// 13.0208 - 2 timer 2 period register - timer 2 increments to this
							// value then resets to zero on the next clock and starts
							// all over again
	T2CONbits.T2OUTPS0 = 0;	// T2OUTPS3 T2OUTPS2 T2OUTPS1 T2OUTPS0
	T2CONbits.T2OUTPS1 = 1;	//    0        0        0        0		1:1 postscaler
	T2CONbits.T2OUTPS2 = 1;	//    0        0        0        1		1:2 postscaler
	T2CONbits.T2OUTPS3 = 1;	//    0        0        1        0		1:3 postscaler
							//    0        0        1        1		1:4 postscaler
							//    0        1        0        0		1:5 postscaler
							//    0        1        0        1		1:6 postscaler
							//    0        1        1        0		1:7 postscaler
							//    0        1        1        1		1:8 postscaler
							//    1        0        0        0		1:9 postscaler
							//    1        0        0        1		1:10 postscaler
							//    1        0        1        0		1:11 postscaler
							//    1        0        1        1		1:12 postscaler
							//    1        1        0        0		1:13 postscaler
							//    1        1        0        1		1:14 postscaler
							//    1        1        1        0		1:15 postscaler
							//    1        1        1        1		1:16 postscaler
	T2CONbits.T2CKPS0 = 1;	// T2CKPS1  T2CKPS0
	T2CONbits.T2CKPS1 = 0;	//    0        0	1:1 prescaler (clock = 10MHz/each tick=100ns)
							//    0        1	1:4 prescaler (clock = 2.5MHz/each tick=400ns)
							//    1        x	1:16 prescaler (clock = 625KHz/each tick=1.6us) (T2CKPS0 doesn't matter)
	PIE1bits.TMR2IE = 1;	// 0: disable timer 2 interrupt on PR2 match
							// 1: enable timer 2 interrupt on PR2 match
							//    if the prescaler is enabled (i.e., greater than 1:1), this
							//    match will occur n times (where n is the postscaler value)
							//    before an interrupt will be generated
	IPR1bits.TMR2IP = 0;	// 0: timer 2 overflow interrupt is low priority (leave at 0 for IFI controllers)
							// 1: timer 2 overflow interrupt is high priority
	T2CONbits.TMR2ON = 1;	// 0: timer 2 is disabled
							// 1: timer 2 is enabled (running)
{	// This timer set to 800Hz
	TMR4 = 0x00;			// 8-bit timer 4 register (this is readable and writable)
	PR4	= 69;				// timer 4 period register - timer 4 increments to this
							// all over again
	T4CONbits.T4OUTPS0 = 0;	// T4OUTPS3 T4OUTPS2 T4OUTPS1 T4OUTPS0
	T4CONbits.T4OUTPS1 = 1;	//    0        0        0        0		1:1 postscaler
	T4CONbits.T4OUTPS2 = 0;	//    0        0        0        1		1:2 postscaler
	T4CONbits.T4OUTPS3 = 1;	//    0        0        1        0		1:3 postscaler
	T4CONbits.T4CKPS0 = 0;	// T4CKPS1  T4CKPS0
	T4CONbits.T4CKPS1 = 1;	//    0        0	1:1 prescaler (clock = 10MHz/each tick=100ns)
	PIE3bits.TMR4IE = 1;	// 0: disable timer 4 interrupt on PR4 match
							// 1: enable timer 4 interrupt on PR4 match
	IPR3bits.TMR4IP = 0;	// 0: timer 4 interrupt is low priority (leave at 0 for IFI controllers)
							// 1: timer 4 interrupt is high priority
	T4CONbits.TMR4ON = 1;	// 0: timer 4 is disabled
							// 1: timer 4 is enabled (running)
You can give that a shot, and see if it works for you.
Joel Johnson
RAGE (173) Alumni, 1999-2003
Last edited by Joel J : 02-06-2005 at 13:43. Reason: including timer files, so the thing will run.. heh.
Unread 02-06-2005, 13:54
ok, based on kevin's response i'm clearly missing something with the interrupts
being called. here's the code
i'm using htis accelerometer
http://www.analog.com/UploadedFiles/...DXL202EB_a.pdf
*Alpha 1 for accelerometer
*	//accelerometer has pwm frequencies of 263.158 Hz (3.8 ms) (we thought)
#include "myaccelerometer.h"
#include "ifi_picdefs.h"
volatile int xacceleration;
volatile int yacceleration;
unsigned int Clock = 0;	// upper 16 bits of the 32 bit system clock
						// timer 1 contains the lower 16 bits
						// each clock tick is worth 26.21 milliseconds
	// initialize and start timer 1
	Initialize_Timer_1();
	// initialize external interrupts 3-6 (KBI0 - KBI3 on user 18F8520)
	TRISBbits.TRISB4 = 1;		// make sure RB4/KBI0 is setup as an input [108]
	TRISBbits.TRISB5 = 1;		// make sure RB5/KBI1 is setup as an input [108]
	INTCON2bits.RBIP = 0;		// interrupts 3 through 6 will use the low priority interrupt [90]
	INTCONbits.RBIE = 1;		// enable interrupts 3 through 6 [89]
int Get_xAcceleration(void)//called from user level to get current calculated x acceleration value
	int temp_xacceleration;
	//disable timer 1 interrupt
	PIE1bits.TMR1IE = 0;
	temp_xacceleration = xacceleration;
	//timer 1 interrupt back on
	PIE1bits.TMR1IE = 1;
	// Return the x acceleration to the caller.
	return(temp_xacceleration);
int Get_yAcceleration(void)//called from user level to get current calculated y acceleration value
	int temp_yacceleration;
	temp_yacceleration = yacceleration;
	// Return the y acceleration to the caller.
	return(temp_yacceleration);
void Initialize_Timer_1(void)
	IPR1bits.TMR1IP = 0;		// timer 1 will use the low priority interrupt [98]
	PIE1bits.TMR1IE = 1;		// enable timer1 roll-over interrupt [95]
	T1CONbits.RD16 = 1;			// use 16-bit read/write operations with timer 1 [135]
	T1CONbits.T1CKPS0 = 0;		// timer 1 clock will use a 4:1 prescale value [135]
	T1CONbits.T1CKPS1 = 1;
	T1CONbits.T1OSCEN = 0;		// turn-off the timer 1 oscillator to save power [135]
	T1CONbits.TMR1CS = 0;		// timer 1 will use the internal 10MHz clock [135]
	T1CONbits.TMR1ON = 1;		// start timer 1 [135]
void Timer_1_Int_Handler(void)
	Clock++; // increment the upper 16-bits of the system clock
void Int_3_Handler(unsigned char RB4_State)	  //parts of this provided by K. Watson from JPL who helps out FIRST teams with code
												//it appeared as help for pwm input for an infrared tracking device
	unsigned char tempbuf; // temporary data buffer
	unsigned int Int_3_Period; // pulse-width period
	unsigned int Int_3_Up_Edge_Count_Low; // lower 16-bits of the rising-edge time snapshot
	unsigned int Int_3_Up_Edge_Count_High; // upper 16-bits of the rising-edge time snapshot
	static unsigned int Int_3_Down_Edge_Count_Low; // lower 16-bits of the falling-edge time snapshot
	static unsigned int Int_3_Down_Edge_Count_High; // upper 16-bits of the falling-edge time snapshot
	switch(RB4_State) // current state determines how the function behaves
		Int_3_Down_Edge_Count_High = Clock; // get a snapshot of the time
		tempbuf = TMR1L; // TMR1L must be read before TMR1H
		Int_3_Down_Edge_Count_Low = TMR1H;
		Int_3_Down_Edge_Count_Low <<= 8;
		Int_3_Down_Edge_Count_Low += tempbuf;
		Int_3_Up_Edge_Count_High = Clock; // get a snapshot of the time
		tempbuf = TMR1L;
		Int_3_Up_Edge_Count_Low = TMR1H;
		Int_3_Up_Edge_Count_Low <<= 8;
		Int_3_Up_Edge_Count_Low += tempbuf;
		if (Int_3_Up_Edge_Count_High == Int_3_Down_Edge_Count_High)
			Int_3_Period = Int_3_Up_Edge_Count_Low - Int_3_Down_Edge_Count_Low;
		else
			Int_3_Period = 65536 - Int_3_Down_Edge_Count_Low + Int_3_Up_Edge_Count_Low;
A(g)=(T1/T2 - 0.5)/0.0125
T2 is set by resistor (1.2 M Ohm resistor yields 9.6 ms T2)
at rest 0g=50% Duty cycle
(Int_3_Period/65536)/26.21 ----> yields Int_3_Period in ms
{[(Int_3_Period in ms)/(9.6 ms T2)]-0.5}/0.0125 -------> yields acceleration in g's
but from what i understand this thing doesn't like floating point numbers
so, plug it into a TI-89 with Int_3 as x, go to approx mode and hit expand
you get this:
	(x/206124) - 40
so we will use this instead as its both simpler and only deals with integers
for x's smaller than 500,000 there is essentially no error in using this approx (0.0002 percent)
//	xacceleration=(Int_3_Period/206124) - 40; THIS IS THE ONE WE WANT WHEN IT WORKS
//	xacceleration=(Int_3_Period); ---------> this doesn't even give me anything (seems that Int_3_Period always remains at 0)
	//xacceleration=Int_3_Down_Edge_Count_High; ------>never gets here or at least it says its always 0
	//xacceleration=Int_3_Up_Edge_Count_High;    ---------> never gets here either
void Int_4_Handler(unsigned char RB5_State)
	unsigned char tbuf; // temporary data buffer
	unsigned int Int_4_Period; // pulse-width period
	unsigned int Int_4_Up_Edge_Count_Low; // lower 16-bits of the rising-edge time snapshot
	unsigned int Int_4_Up_Edge_Count_High; // upper 16-bits of the rising-edge time snapshot
	static unsigned int Int_4_Down_Edge_Count_Low; // lower 16-bits of the falling-edge time snapshot
	static unsigned int Int_4_Down_Edge_Count_High; // upper 16-bits of the falling-edge time snapshot
		tbuf = TMR1L;
		else
(Int_4_Period/65536)*10000 ----> yields Int_4_Period in ms
{[(Int_4_Period in ms)/(9.6 ms T2)]-0.5}/0.0125 -------> yields acceleration in g's
you get this:
	(x/206124) - 40
	yacceleration=(Int_4_Period/206124) - 40;
*goal: get any sort of reading off the signal pins
*and print it to the screen so we can see what we are dealing with
#ifndef _accelerometer_h
#define _accelerometer_h
void Initialize_Accelerometer(void);	// initializes and starts the accelerometer code
int Get_xAcceleration(void);				// returns the current measured x acceleration
int Get_yAcceleration(void);				// returns the current measured y acceleration
void Initialize_Timer_1(void);			// initializes and starts timer 1
void Int_3_Handler(unsigned char);			// interrupt 3 routine (x axis) power yellow
void Int_4_Handler(unsigned char);			// interrupt 4 routine (y axis) red white
void Timer_1_Int_Handler(void);	//timer routine
// some handy macros
#define HIBYTE(value) ((unsigned char)(((unsigned int)(value)>>8)&0xFF))
#define LOBYTE(value) ((unsigned char)(value))
// state machine defines
#define WAITING_FOR_UP_EDGE 0
#define WAITING_FOR_DOWN_EDGE 1
extern unsigned int Clock;		//in myaccel.c
#endif
* FILE NAME: user_routines.c <FRC VERSION>
* DESCRIPTION:
*  This file contains the default mappings of inputs
*  (like switches, joysticks, and buttons) to outputs on the RC.
* USAGE:
*  You can either modify this file to fit your needs, or remove it from your
*  project and replace it with a modified copy.
#include <stdio.h>
#include "user_routines.h"
#include "user_Serialdrv.h"
/*** DEFINE USER VARIABLES AND INITIALIZE THEM HERE ***/
extern unsigned char aBreakerWasTripped;
* FUNCTION NAME: Limit_Switch_Max
* PURPOSE:       Sets a PWM value to neutral (127) if it exceeds 127 and the
*                limit switch is on.
* CALLED FROM:   this file
* ARGUMENTS:
*     Argument       Type             IO   Description
*     switch_state   unsigned char    I    limit switch state
*     *input_value   pointer           O   points to PWM byte value to be limited
* RETURNS:       void
void Limit_Switch_Max(unsigned char switch_state, unsigned char *input_value)
  if (switch_state == CLOSED)
    if(*input_value > 127)
      *input_value = 127;
* FUNCTION NAME: Limit_Switch_Min
* PURPOSE:       Sets a PWM value to neutral (127) if it's less than 127 and the
* ARGUMENTS:
* RETURNS:       void
void Limit_Switch_Min(unsigned char switch_state, unsigned char *input_value)
    if(*input_value < 127)
      *input_value = 127;
* FUNCTION NAME: Limit_Mix
* PURPOSE:       Limits the mixed value for one joystick drive.
* CALLED FROM:   Default_Routine, this file
* ARGUMENTS:
*     intermediate_value    int    I
* RETURNS:       unsigned char
unsigned char Limit_Mix (int intermediate_value)
  static int limited_value;
  if (intermediate_value < 2000)
    limited_value = 2000;
  else if (intermediate_value > 2254)
    limited_value = 2254;
  else
    limited_value = intermediate_value;
  return (unsigned char) (limited_value - 2000);
* FUNCTION NAME: User_Initialization
* PURPOSE:       This routine is called first (and only once) in the Main function.
*                You may modify and add to this function.
* CALLED FROM:   main.c
* ARGUMENTS:     none
* RETURNS:       void
  Set_Number_of_Analog_Channels(SIXTEEN_ANALOG);    /* DO NOT CHANGE! */
/* FIRST: Set up the I/O pins you want to use as digital INPUTS. */
  digital_io_01 = digital_io_02 = digital_io_03 = digital_io_04 = INPUT;
  digital_io_05 = digital_io_06 = digital_io_07 = digital_io_08 = INPUT;
  digital_io_09 = digital_io_10 = digital_io_11 = digital_io_12 = INPUT;
  digital_io_13 = digital_io_14 = digital_io_15 = digital_io_16 = INPUT;
  digital_io_18 = INPUT;  /* Used for pneumatic pressure switch. */
     Note: digital_io_01 = digital_io_02 = ... digital_io_04 = INPUT;
           is the same as the following:
           digital_io_01 = INPUT;
           digital_io_02 = INPUT;
/* SECOND: Set up the I/O pins you want to use as digital OUTPUTS. */
  digital_io_17 = OUTPUT;    /* Example - Not used in Default Code. */
/* THIRD: Initialize the values on the digital outputs. */
  rc_dig_out17 = 0;
/* FOURTH: Set your initial PWM values.  Neutral is 127. */
  pwm01 = pwm02 = pwm03 = pwm04 = pwm05 = pwm06 = pwm07 = pwm08 = 127;
  pwm09 = pwm10 = pwm11 = pwm12 = pwm13 = pwm14 = pwm15 = pwm16 = 127;
/* FIFTH: Set your PWM output types for PWM OUTPUTS 13-16.
  /*   Choose from these parameters for PWM 13-16 respectively:               */
  /*     IFI_PWM  - Standard IFI PWM output generated with Generate_Pwms(...) */
  /*     USER_CCP - User can use PWM pin as digital I/O or CCP pin.           */
  Setup_PWM_Output_Type(IFI_PWM,IFI_PWM,IFI_PWM,IFI_PWM);
     Example: The following would generate a 40KHz PWM with a 50% duty cycle on the CCP2 pin:
         CCP2CON = 0x3C;
         PR2 = 0xF9;
         CCPR2L = 0x7F;
         T2CON = 0;
         Setup_PWM_Output_Type(USER_CCP,IFI_PWM,IFI_PWM,IFI_PWM);
  /* Add any other initialization code here. */
  Putdata(&txdata);             /* DO NOT CHANGE! */
  Serial_Driver_Initialize();
  Initialize_Serial_Comms();
  //printf("IFI 2005 User Processor Initialized ...\r");  /* Optional - Print initialization message. */
  /* Note:  use a '\r' rather than a '\n' with the new compiler (v2.4) */
  User_Proc_Is_Ready();         /* DO NOT CHANGE! - last line of User_Initialization */
* FUNCTION NAME: Process_Data_From_Master_uP
* PURPOSE:       Executes every 26.2ms when it gets new data from the master
*                microprocessor.
* ARGUMENTS:     none
* RETURNS:       void
void Process_Data_From_Master_uP(void)
  static unsigned char i;
  static unsigned char delay;
	int xaccel;
	int yaccel;
  Getdata(&rxdata);   /* Get fresh data from the master microprocessor. */
  Default_Routine();  /* Optional.  See below. */
  Generate_Pwms(pwm13,pwm14,pwm15,pwm16);
  /* Eample code to check if a breaker was ever tripped. */
  if (aBreakerWasTripped)
    for (i=1;i<29;i++)
      if (Breaker_Tripped(i))
        User_Byte1 = i;  /* Update the last breaker tripped on User_Byte1 (to demonstrate the use of a user byte)
                           // Normally, you do something else if a breaker got tripped (ex: limit a PWM output)     */
	//get x and y accel and print them to the serial port
	xaccel=Get_xAcceleration();
	printf("The x accel: %d", xaccel);
	yaccel=Get_yAcceleration();
	printf("The y accel: %d", yaccel);
* FUNCTION NAME: Default_Routine
* PURPOSE:       Performs the default mappings of inputs to outputs for the
*                Robot Controller.
* CALLED FROM:   this file, Process_Data_From_Master_uP routine
* ARGUMENTS:     none
* RETURNS:       void
void Default_Routine(void)
 /*---------- Analog Inputs (Joysticks) to PWM Outputs-----------------------
  *   This maps the joystick axes to specific PWM outputs.
  pwm01 = p1_y;
  pwm02 = p2_y;
  pwm03 = p3_y;
  pwm04 = p4_y;
  pwm05 = p1_x;
  pwm06 = p2_x;
  pwm07 = p3_x;
  pwm08 = p4_x;
  pwm09 = p1_wheel;
  pwm10 = p2_wheel;
  pwm11 = p3_wheel;
  pwm12 = p4_wheel;
 /*---------- 1 Joystick Drive ----------------------------------------------
  *  This code mixes the Y and X axis on Port 1 to allow one joystick drive.
  *  Joystick forward  = Robot forward
  *  Joystick backward = Robot backward
  *  Joystick right    = Robot rotates right
  *  Joystick left     = Robot rotates left
  *  Connect the right drive motors to PWM13 and/or PWM14 on the RC.
  *  Connect the left  drive motors to PWM15 and/or PWM16 on the RC.
 /*---------- Buttons to Relays----------------------------------------------
  *  This default code maps the joystick buttons to specific relay outputs.
  *  Relays 1 and 2 use limit switches to stop the movement in one direction.
  *  The & used below is the C symbol for AND
  relay1_fwd = p1_sw_trig & rc_dig_in01;  /* FWD only if switch1 is not closed. */
  relay1_rev = p1_sw_top  & rc_dig_in02;  /* REV only if switch2 is not closed. */
  relay2_fwd = p2_sw_trig & rc_dig_in03;  /* FWD only if switch3 is not closed. */
  relay2_rev = p2_sw_top  & rc_dig_in04;  /* REV only if switch4 is not closed. */
  relay3_fwd = p3_sw_trig;
  relay3_rev = p3_sw_top;
  relay4_fwd = p4_sw_trig;
  relay4_rev = p4_sw_top;
  relay5_fwd = p1_sw_aux1;
  relay5_rev = p1_sw_aux2;
  relay6_fwd = p3_sw_aux1;
  relay6_rev = p3_sw_aux2;
  relay7_fwd = p4_sw_aux1;
  relay7_rev = p4_sw_aux2;
  relay8_fwd = !rc_dig_in18;  /* Power pump only if pressure switch is off. */
  relay8_rev = 0;
  /*---------- PWM outputs Limited by Limit Switches  ------------------------*/
  Limit_Switch_Max(rc_dig_in05, &pwm03);
  Limit_Switch_Min(rc_dig_in06, &pwm03);
  Limit_Switch_Max(rc_dig_in07, &pwm04);
  Limit_Switch_Min(rc_dig_in08, &pwm04);
  Limit_Switch_Max(rc_dig_in09, &pwm09);
  Limit_Switch_Min(rc_dig_in10, &pwm09);
  Limit_Switch_Max(rc_dig_in11, &pwm10);
  Limit_Switch_Min(rc_dig_in12, &pwm10);
  Limit_Switch_Max(rc_dig_in13, &pwm11);
  Limit_Switch_Min(rc_dig_in14, &pwm11);
  Limit_Switch_Max(rc_dig_in15, &pwm12);
  Limit_Switch_Min(rc_dig_in16, &pwm12);
 /*---------- ROBOT FEEDBACK LEDs------------------------------------------------
  *   This section drives the "ROBOT FEEDBACK" lights on the Operator Interface.
  *   The lights are green for joystick forward and red for joystick reverse.
  *   Both red and green are on when the joystick is centered.  Use the
  *   trim tabs on the joystick to adjust the center.
  *   These may be changed for any use that the user desires.
  if (user_display_mode == 0) /* User Mode is Off */
  { /* Check position of Port 1 Joystick */
    if (p1_y >= 0 && p1_y <= 56)
    {                     /* Joystick is in full reverse position */
      Pwm1_green  = 0;    /* Turn PWM1 green LED - OFF */
      Pwm1_red  = 1;      /* Turn PWM1 red LED   - ON  */
    else if (p1_y >= 125 && p1_y <= 129)
    {                     /* Joystick is in neutral position */
      Pwm1_green  = 1;    /* Turn PWM1 green LED - ON */
    else if (p1_y >= 216 && p1_y <= 255)
    {                     /* Joystick is in full forward position*/
      Pwm1_red  = 0;      /* Turn PWM1 red LED   - OFF */
    else
    {                     /* In either forward or reverse position */
    }  /*END Check position of Port 1 Joystick
    /* Check position of Port 2 Y Joystick
           (or Port 1 X in Single Joystick Drive Mode) */
    if (p2_y >= 0 && p2_y <= 56)
      Pwm2_green  = 0;    /* Turn pwm2 green LED - OFF */
      Pwm2_red  = 1;      /* Turn pwm2 red LED   - ON  */
    else if (p2_y >= 125 && p2_y <= 129)
      Pwm2_green  = 1;    /* Turn PWM2 green LED - ON */
      Pwm2_red  = 1;      /* Turn PWM2 red LED   - ON */
    else if (p2_y >= 216 && p2_y <= 255)
    {                     /* Joystick is in full forward position */
      Pwm2_red  = 0;      /* Turn PWM2 red LED   - OFF */
    else
      Pwm2_green  = 0;    /* Turn PWM2 green LED - OFF */
    }  /* END Check position of Port 2 Joystick */
    /* This drives the Relay 1 and Relay 2 "Robot Feedback" lights on the OI. */
    Relay1_green = relay1_fwd;    /* LED is ON when Relay 1 is FWD */
    Relay1_red = relay1_rev;      /* LED is ON when Relay 1 is REV */
    Relay2_green = relay2_fwd;    /* LED is ON when Relay 2 is FWD */
    Relay2_red = relay2_rev;      /* LED is ON when Relay 2 is REV */
    Switch1_LED = !(int)rc_dig_in01;
    Switch2_LED = !(int)rc_dig_in02;
    Switch3_LED = !(int)rc_dig_in03;
  } /* (user_display_mode = 0) (User Mode is Off) */
  else  /* User Mode is On - displays data in OI 4-digit display*/
    User_Mode_byte = backup_voltage*10; /* so that decimal doesn't get truncated. */
} /* END Default_Routine(); */
Unread 02-06-2005, 14:04
FRC #2429
You find it wierd that two code monkey demi-gods would end up writing the same code? Hmmm... A better understanding of the Tao of Programming is needed here, grasshopper <grin>.
-Kevin
Kevin Watson
http://kevin.org
Unread 02-06-2005, 14:10
FRC #2429
Originally Posted by ImmortalAres
ok, based on kevin's response i'm clearly missing something with the interrupts being called. here's the code...
Where does Initialize_Accelerometer() get called?
-Kevin
Kevin Watson
http://kevin.org
Unread 02-06-2005, 14:18
that is a very good question, apparently i deleted the call by accident once. i'll see if it helps any. Thanks.
~Will
Unread 02-06-2005, 14:19
Mike Bortfeldt Mike Bortfeldt is offline
FRC #1126 (& 1511)
Mike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud of
I could be way off base, but I believe the accelerometer you are using outputs analog signals (0-5 V) and should be connect to an AI port, not a digital.
Mike
Unread 02-06-2005, 14:20
Joel J's Avatar
do you..
About interrupts:
Interrupt code here - http://www.kevin.org/frc
Interrupt white paper - http://www.chiefdelphi.com/forums/pa...le&paperid=272
And you can run a search on here to see what you find.
Joel Johnson
Unread 02-06-2005, 14:22
Joel J's Avatar
do you..
Mike
The 202 outputs PWM signals.. I, next fall, was going to use the newer accelerometer that outputs analog signals, as the resulting output would be more useful, because of this particular processor (I didn't realize this person is at Clarkson, heh). So maybe you should just go right to investigating that one? Also, you can look at the setups from http://www.sparkfun.com/shop/ , they could make your life a bit easier (unlike my headache this build).
edit: Actually, in hindsight, I do remember the 202's manual telling a way that the analog signal could be salvaged. I think it involved the use of a few capacitors. You can maybe read the manual, and see if that is a feasible option for you.
Also, the accelerometer I was mentioning is the 203: http://www.analog.com/en/prod/0%2C28...L203%2C00.html . It has about 2.5 times less error, and a more usable signal. Its the way to go.
Joel Johnson
Unread 02-06-2005, 14:25
FRC #2429
~Will
Are you using the EDU-RC? I ask because I have code that will work with your accelerometer, but is dependent on the EDU-RC.
-Kevin
Kevin Watson
http://kevin.org
FRC #1126 (& 1511)
Joel,
My apologies, your right. I've used the analog one in the past and thought this was the same.
Mike
Unread 02-06-2005, 14:35
TActually, in hindsight, I do remember the 202's manual telling a way that the analog signal could be salvaged. I think it involved the use of a few capacitors. You can maybe read the manual, and see if that is a feasible option for you.[/i]
yes, you can build an op amp to get the analog signal back but our research advisor (Carroll) wants us to just use another PIC that will solve the problem of processing power.
also:
http://people.clarkson.edu/~lanahamc/media/IMG_1546.jpg
i don't know what RC that is, maybe joel can help me out on that one
Unread 02-06-2005, 14:45
* DESCRIPTION:
* USAGE:
#include <stdio.h>
* ARGUMENTS:
* RETURNS:       void
      *input_value = 127;
* ARGUMENTS:
* RETURNS:       void
      *input_value = 127;
* ARGUMENTS:
  else
* ARGUMENTS:     none
* RETURNS:       void
  rc_dig_out17 = 0;
         CCP2CON = 0x3C;
         PR2 = 0xF9;
         CCPR2L = 0x7F;
         T2CON = 0;
*                microprocessor.
* ARGUMENTS:     none
* RETURNS:       void
	int xaccel;
	int yaccel;
    for (i=1;i<29;i++)
*                Robot Controller.
* ARGUMENTS:     none
* RETURNS:       void
  pwm01 = p1_y;
  pwm02 = p2_y;
  pwm03 = p3_y;
  pwm04 = p4_y;
  pwm05 = p1_x;
  pwm06 = p2_x;
  pwm07 = p3_x;
  pwm08 = p4_x;
  pwm09 = p1_wheel;
  pwm10 = p2_wheel;
  pwm11 = p3_wheel;
  pwm12 = p4_wheel;
  relay8_rev = 0;
    else
    else
i added the initialization of the acceleromter. so now i'm left with the solid red led telling me i have a code error
Out of the Box Camera Code russell Programming 9 21-10-2009 05:28
Some things i'm trying to understand on Kevin's Accelerometer Code Squall Programming 2 03-02-2005 12:01
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
Example accelerometer code released. Kevin Watson Programming 0 20-01-2005 03:45
