Re: Adding Bluetooth to Vex
Thank You So Much - Joe!!
The info supplied seem so useful already! I can see I have alot to read, and alot to order too ![]() Making the programming module would be a toughy though... components are not easy to find here in Egypt, So I'm wondering what's the easiest way to make one ( easiest as in one would least components to look for)? |
Is it possible to conenct the bluetooth module to Rx1 instead of the serial of the microcontroller ??
Im not that familliar with VEX but maybe a gumstix (www.gumstix.com). They have built in bluetooth and I know they work fine with the IFI controller.
i sent a message to the manufacturers of the bluetooth module and they told me it can only be connected to any UART .
so i don't know if the Rx1 on Vex is UART or not ? |
thanks for the info
do u know the pinout of Rx1 ? i am also trying to get the schematic of the circuit that has the micrcontroller on in , because i want to know how is the microcontroller is connected to Rx1 or Serial . Anyone knows how these are connected ?? |
#7
anyway, i got the information from the example code at vexlabs. |
#8
i'm a bit confused ..
if i can connect the bluetooth module ( which has 4 pins : TX , RX , PWR , GND ) to Rx1 , do i connect it to Rx1 which was used for the RF Module that came with the robot ? or do i connect it to RX & TX that are on the Analod/Digital section of the microcontroller ? if it's the 1st option then i need to know the pinouts of the Rx1 input , if it's the 2nd option then i need to know where to connect the PWR & GND pins of the bluetooth module ? Something else i'm thinking of doing it ... which is replacing the RF Module on the Remote Control Unit with a bluetooth module . Is it possible ?? |
#9
| how to build a VEX programming module | bblack7489 | FIRST Tech Challenge | 78 | 09-06-2011 16:03 |
| Useful VEX Tools | Joe Johnson | FIRST Tech Challenge | 4 | 26-04-2005 18:48 |
| Vex Robotics | Vex | FIRST Tech Challenge | 0 | 14-04-2005 13:48 |
| VEX Robotics | vexrobotics | FIRST Tech Challenge | 8 | 30-03-2005 23:25 |
| VEX Kits ARRIVED!!! | Joe Johnson | FIRST Tech Challenge | 14 | 28-03-2005 19:28 |
