Go to Post Thank you for Recycle Rush, the largest FLL game ever. - Dan Petrovic [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 29-05-2005, 15:24
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
CSS frames
Ok... so from looking at the CSS playground (which I discovered thanks to this thread), I've created a CSS frame based layout for a site I'm working on. It looks great on Firefox, and works in IE, but there's a small (well, two, but the one annoys me more than the other. ) problem. Here are two screenshots: (+the Firefox pic, so you know what it should look like.)
Firefox, the one that works:
IE, not scrolled: (see, it looks fine!)
IE, scrolled: (not the arrow and circle...)
I can't figure out why the select ends up on top. I've tried forcing the z-index below the header layer, but it doesn't help. Any ideas?
Unread 29-05-2005, 15:49
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Re: CSS frames
Try using the same exact code on that button class (id, whatever your using) as the code of a button that is working. If that works, keep on making minor changes until it doesn't work. Then post back here on when it broke.
http://www.mikesorrenti.com/
Unread 29-05-2005, 16:37
Programming User
Re: CSS frames
The difference is that it is a <select> form thing and not an <input>. The firefox screenshot is scrolled to the same spot and you can see that the select is hidden by the header as it should be. There's no special style information associated with any of the form elements.
Unread 29-05-2005, 16:41
Mike's Avatar
AKA: Mike Sorrenti
Re: CSS frames
Oh, thats odd then. Try setting the z-index on the header, instead of on the select.
Unread 29-05-2005, 16:42
Programming User
Re: CSS frames
It's set on both... 1 for select (cause I got mad at it) and 3 for the header. :cry:
Unread 29-05-2005, 16:45
Dan Zollman's Avatar
Dan Zollman Dan Zollman is offline
7
FRC #1712 (Dawgma)
Dan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond repute
Re: CSS frames
I've seen this occur before in various sites, i.e, a form select appears above another element. I don't think it's so much a problem with your CSS as a browser problem or glitch (and unfortunately, there isn't anything we can do about those but avoid them).
Unread 29-05-2005, 17:01
Programming User
Re: CSS frames
So... I poked around some more and made some clever changes and now IE displays the main content in a div in a div to allow me to still have the fixed property work, while Firefox/everything else ignores the extra div (avoiding the no scroll wheel bug you frequently encounter on CSS playground.)
Yeah for CSS!
Unread 29-05-2005, 23:01
Adam Richards's Avatar
Adam Richards Adam Richards is offline
I'm baaaaaaack.
FRC #1902 (Exploding Bacon)
Adam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond repute
Send a message via AIM to Adam Richards
Re: CSS frames
IE is evil. Firefox wouldn't give you that problem...
Unread 31-05-2005, 08:28
DarkJedi613's Avatar
DarkJedi613 DarkJedi613 is offline
Running Riot
AKA: Patrick Cloke
FRC #0358 (Hauppauge Robotic Eagles) FRC #1493 (RPI/Albany High School)
DarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to behold
Send a message via AIM to DarkJedi613 Send a message via MSN to DarkJedi613 Send a message via Yahoo to DarkJedi613
Re: CSS frames
That's a cool layout.
I don't suppose we can get the source?
I'm guessing its done the same way as bungie.net, which has two menus that are like frames...looks good though
2003 - 2006 President, Coach, Webmaster Team358.org
2008 Mentor, Team 1493
Team Search | (Updated: 1-16-08)
FIRSTsearch
Unread 31-05-2005, 10:14
Programming User
Re: CSS frames
I'm betting... no it's not the same. I'm at school right now, so it's blocked (under "Games" of all things... ), but I somehow doubt it.
I actually do have the code with me (always keep backups on your thumbdrive!). Normal.css is the stylesheet, header.php and footer.php are the top and bottom of the page. The actual page content gets thrown in between the include of those. I fixed both the problems in the screenshots.
Unread 31-05-2005, 14:45
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Re: CSS frames
I'm not going to lie, I really dislike Bungie's page. It takes a while to load, and then scrolling goes sooo slowly because of all the graphics on it.
Unread 03-06-2005, 16:51
robot180's Avatar
robot180 robot180 is offline
Webmaster, spamrobotics.com
AKA: Jon
FRC #0180 (S.P.A.M.)
robot180 is a name known to allrobot180 is a name known to allrobot180 is a name known to allrobot180 is a name known to allrobot180 is a name known to allrobot180 is a name known to all
Send a message via AIM to robot180
Re: CSS frames
This is a little unrelated, but the title of this thread reminds me of something.
I was looking up a CSS property that I forgot and I found two other things I didn't know. One is on this page, the clip property. Does that work in most browsers? I am not sure what I could use it for, but I never saw it before.
The other one is overflow property. I have used this before, but I didn't know it could be used almost to make what appears to be Iframes. Does this work in most browsers and if so, do people use it? I am asking about browsers because this tutorial only mentions whether things work in three different browsers.
-Jon
Computer Science Major
Georgia Tech
Former Team Leader
FRC Team 180
Unread 03-06-2005, 18:30
jonathan lall's Avatar
jonathan lall jonathan lall is offline
FRC #2505 (The Electric Sheep; FRC #0188 alumnus)
jonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond repute
Send a message via MSN to jonathan lall
Re: CSS frames
Both clip* and overflow work in all modern browsers. With overflow you'll find some minor presentational variations across the browser spectrum. But the "iframe" scroll type implemetation works with everything.
*With clip, I recall hearing that different doctypes tend to change browsers' handling of the property. If memory serves, IE's shoddy CSS2 handling is the culprit. Again. Luckily, I can't really think of many reasons to use clip.
The CSS Playground JohnBoucher IT / Communications 6 29-05-2005 16:41
CSS Based Design Brandon Martus Website Design/Showcase 13 07-05-2004 19:46
Arggg stupid css design..... Adam Y. Website Design/Showcase 16 22-04-2004 19:37
Reasons for not using frames Raven_Writer Website Design/Showcase 49 17-05-2003 20:24
# of frames Adam D 3D Animation and Competition 8 16-03-2002 22:45
