Go to Post Haters gonna hate, Cheesers gonna cake. - Ryan Dognaux [more]
Unread 05-06-2005, 10:31
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
Talking Lighting projects for robots
this year ohm bots mounted computer neon tubes under our robot and were able to control them from the control station (ironically this was the most reliable aspect on our robot). well this year I'm looking to go one step farther. since we also used nylon mesh tubing to organize all our wiring (highly recommended for neatness but find a way to mark wires first!) I'm going to run something called EL wire through all our tubing. imagine you flip a switch and all your beautiful wiring glows... very cool. Ive also found a LCD board that does the sequential flashing as seen on night rider or the cylons on battle star galactica. just some ideas. if anyone has any other cool ideas post them.
Unread 05-06-2005, 10:41
Billfred's Avatar
Billfred Billfred is online now
Re: oooh purty
I was considering suggesting making use of automotive clearance lights (roughly $2 at Auto Zone) for some approximately pimped-out decoration, but it became obvious that we were having trouble making weight as it was, so I kept my mouth shut. (You have no idea how many mounting panels we went through to make weight.)
Unread 05-06-2005, 12:22
Sparks333's Avatar
Sparks333 Sparks333 is offline
Robotics Engineer
AKA: Dane B.
FRC #1425 (Wilsonville Robotics)
Sparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of light
Send a message via AIM to Sparks333
Re: oooh purty
Well, how about this, mechanicalbrain: instead of just for looks, use it for some diagnostics, too. If you plan to use connectors, then hook the EL lights (people in case mod circles love that stuff!) into the same connectors as the wires. That way, if a connector fails, the light will fail at that point, and you can easily tell where the power ends.
Just a thought.
Sparks
ICs do weird things when voltage is run out of spec.
I love to take things apart. The fact that they work better when I put them back together it just a bonus.
http://www.ravenblack.net/random/surreal.html
Unread 05-06-2005, 14:59
Re: oooh purty
well i like that idea but dont you need converter to run them and that would mean i need one for every connector also i would hate to have one fail and spend hours searching a robot for problems just to find out its the lights.
Unread 05-06-2005, 16:25
jdiwnab's Avatar
jdiwnab jdiwnab is offline
Really the Inventor Guy
AKA: Bryan Hartley
FRC #0617
jdiwnab is a jewel in the roughjdiwnab is a jewel in the roughjdiwnab is a jewel in the rough
Re: oooh purty
Maybe, instead of having them go out with a problem, you could make them do something different if there is a problem. I don'e know much about EL wire, but if you can make it change color or blink or somthing, that might work
Proof that Macs will win the platform war: How did Scotty know how to use MacDraft in Star Trek IV?
// random()
I have 100 gmail invites. PM me if you want one.
If they want us to think outside of the box, why do they make us fit in a 38x28x60 inch box?
Beware of Geeks bearing GIFs
Help me test my server software
Unread 05-06-2005, 17:41
Sparks333's Avatar
Robotics Engineer
AKA: Dane B.
Re: oooh purty
Do they need converters? I didn't know that. It was just an idea, anyway, plus I think jdiwnab has a good one there. I was considering using LED's at the connector itself for the same purpose, but saw this idea, and thought: hey, why not give it some bling?
Sparks
Unread 05-06-2005, 19:04
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: oooh purty
Just an idea, but sometime ago I wrote some example code that showed how to vary the light output of an LED using the PIC18F8520's built-in PWM hardware. This code could be used with last year's IR beacon circuit to drive an array of tri-color high-brightness LEDs to create a pretty wide color spectrum. The filename is edu_led_pwm.zip and it's located here: http://kevin.org/frc.
-Kevin
Kevin Watson
http://kevin.org
Unread 05-06-2005, 21:43
Alexander McGee's Avatar
Alexander McGee Alexander McGee is offline
Hoonigan
AKA: Alexander S. McGee
no team (no team)
Alexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond repute
Send a message via AIM to Alexander McGee Send a message via Yahoo to Alexander McGee
Re: oooh purty
I made a simple one of these for my car's front end. I can send you a schematic if you want. It cost me around $10.00 from Radio-shack.
Knight-Rider all the way.
-Alexander S. McGee
Intellectual Property Attorney, Mechanical Engineer, Gear-head
Unread 06-06-2005, 00:46
MrToast's Avatar
MrToast MrToast is offline
I named Greg Needel's cat!
AKA: Dave DeLong
no team (Rhode Warriors)
MrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud of
Send a message via AIM to MrToast
Re: oooh purty
121 had some nifty colored wire on our bot this year. We spelled out "121" on the sides in red and blue glow wire, and then we would switch between turning the red or blue on and off depending on what alliance we were on.
It was pretty cool.
Dave
(#121, 2004) Archimedes semi-finalists with 237 and 386! I had an awesome time guys, and thanks for the hat!
(#121, 2004) BC5 semi-finalists with 190 and 1027! Awesome time! We went further than I thought we could! Thanks for all your help w/ our transmission!
(#121, 2005) Galileo quarter-finalists with 47 and 203! Thanks for all your support through the stress!
If it moves and it shouldn't, use duct tape.
If it doesn't move and it should, use WD-40
"It'll all work out in the end, and if it doesn't, it's not the end." - Jeff Bullock
Unread 06-06-2005, 13:03
Re: oooh purty
neon tubes require a high voltage to operate. I wonder if this was the source of your other control problems?
with any equipement that has a radio receiver, and analog inputs running on long wires, you need to be very carefull what type of other equipment you install, esp something that runs on high voltages.
I would not recommend running light tubes side by side with any control wires running through your robot chassis - the PWM wires for example - that would be begging for problems.
Unread 06-06-2005, 13:08
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
Re: oooh purty
That looks blue to me, and at least here in VA, if you drive around with that on it is a hefty ticket. Blue lights are reserved for the police and fire marshals.
Wetzel
Viva Olancho!
Unread 06-06-2005, 13:33
Hoonigan
no team (no team)
Re: oooh purty
Wetzel
Yes I know, I am a full-time firefighter. I use these (and my other lights) when responding to a call. We are free to mix blue, red, and amber as we feel free. Our restrictions on colour are a bit relaxed, because we are not a city department. Most of the time, blue is reserved strictly for police.
-Alexander S. McGee
Unread 06-06-2005, 17:52
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: oooh purty
You take your personal car to calls? You don't ride in the firetruck?
Unread 06-06-2005, 20:06
Re: Lighting projects for robots
in answer to some confusion el lights are just like neon tubes but extremely thin and flexible. mounting neon tubes to our robot had no adverse effects. we had a amazing underglow and we ran a homemade ropelight through our nylon tubing (the type found in computer stores. highly recomended for wire organizing especaily when you need a lot of cable to reach) and it looked amazing.
Unread 06-06-2005, 21:09
Hoonigan
no team (no team)
Re: oooh purty
Hah, yeah. I respond in my PT cruiser from home. I have it set up for rally suspension and tires, as it is hard to do 95 on dirt roads without it. I love having a legal excuse to drive fast .
Wow, this thread has gone astray...sorry Brandon.
Hah.
-Alexander S. McGee
CMUcam II and competition lighting environments dlavery Programming 5 16-02-2005 02:07
Off season projects JamesCH95 General Forum 17 13-12-2004 23:32
Sub Forum suggestion. (Non Robot) Team building projects. Elgin Clock CD Forum Support 3 03-12-2004 14:30
Night scene lighting Lev 3D Animation and Competition 14 30-01-2003 23:43
