Go to Post Wait, that's exactly how it's supposed to work, isn't it. Well played GDC, well played. - alopex_rex [more]
Thread Tools Rating: Thread Rating: 11 votes, 4.64 average. Display Modes
Unread 17-05-2005, 07:45
foobert foobert is offline
foobert is a jewel in the roughfoobert is a jewel in the roughfoobert is a jewel in the rough
Re: how to build a VEX programming module
i sent an email to info@ etc. the other day and the word was that the default code would be posted on vexlabs.com next week and that programming kit prototypes would be available as well at that time.
Unread 21-05-2005, 09:06
crazykid234's Avatar
crazykid234 crazykid234 is offline
Techincal assist
AKA: Brian Clegg
FRC #1646 (Precision Guessworks), Alumni FRC #234 (Cyber Blue)
crazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to behold
Talking Re: how to build a VEX programming module
the default code has been released!! You can find it here
This also contains the ifi loader you will need, but no luck on the prototype programming modules.......
Have fun!
Don't see the world as it is and ask why; see the world as it could be and ask, why not? - unknown author
Unread 23-05-2005, 00:36
curriedgoat curriedgoat is offline
curriedgoat is an unknown quantity at this point
Question Re: how to build a VEX programming module
What is the REV on your VEX board? I am not finding the pinouts like you described. I find that
1- RB1 (master)
2- RJ3 (master)
3- GND
4- C1OUT
5- +5v
6- can't find where it traces to yet
My VEX board has this printed on it:
RS-TALOS
REV NC3
This is on the serial port and not the RX1 or RX2 ports.
Thanks,
Bronson
Originally Posted by fowlerm
Pinout for the Vex serial port is as follows:
1 - Tx for UART 1 on the user uP - White
2 - Rx for UART 1 on the user uP - Black
3 - Gnd - Red
4 - RB0 on the master uP - Green
5 - +5v - Yellow
6 - RJ3 on the master uP - Blue
Unread 23-05-2005, 18:20
Dr.Bot
Posts: n/a
Does anyone know what the 'default' program module will contain? Does it come in both USB and rs232 port versions? Losts of laptops today don't have serial ports.
Unread 24-05-2005, 00:06
AKA: Brad
#0190 ( Gompei and the Herd)
The programming "cable" that will be shipped contains the level converter for serial ports. The idea of the extra hardware is to make it more immune to serial port and laptop performance differences. The original IFI controllers were very sensitive to laptop speeds and USB-serial adapters and would often fail loading the program.
Brad
Unread 24-05-2005, 08:36
fired up the ohm meter this morning and my results confirm fowlerm's.
my board is also labeled rs-talos rev nc3.
note that the master and user controllers are not oriented the same way on the board and that the c1out, (pin 18), is 90 degrees away orientation-wise, from tx2, (pin 38).
to test i plugged a straight through 6 pin cable into the programming port and a jack with wires hanging loose, then connected my ohm meter to the various wires at one end and to pins on the chips at the other. the wire colors i got are the same as reported by fowlerm.
furthermore, with the board powered up i read 4.9 volts on rb0, (green). this pin has an internal pullup, so i assume that that's appropriate, and that connecting a switch between rb0 and ground will generate and interrupt on the master controller.
haven't managed to get a cable working but, hey, i'm in way over my head.
good luck.
1- RB1 (master)
2- RJ3 (master)
3- GND
4- C1OUT
5- +5v
RS-TALOS
REV NC3
Thanks,
Bronson
Unread 24-05-2005, 15:49
fowlerm's Avatar
fowlerm fowlerm is offline
Bringing .NET to Robots
AKA: Matthew Fowler
FRC #0312 (Heatwave); FRC #1369 (Minotaur)
fowlerm has a spectacular aura aboutfowlerm has a spectacular aura aboutfowlerm has a spectacular aura about
Supposedly there will be two versions of the programming module, one that has a RS-232 to TTL converter and the other will have a USB to TTL converter, but I haven't been able to confirm this.
Unread 24-05-2005, 22:17
shm267 shm267 is offline
shm267 is an unknown quantity at this point
I spoke with someone at vexlabs today, the prototype boards are available and so far, no one has purchased one. They are around $100 for the prototype board. He indicated that the program kit at radio Shack will be around $130. I asked if it was just a level converter and he indicated that is has an actual pic processor on it. He also indicated that the two chips have a boot loader for loading code. Both chips will be update-able via the loader. I was thinking about returning my system, but after finding out that the controller is PIC based and that I would update the code on the chips, I plan on keeping the system. BTW... The processors on the board are PIC 18F8520. Has anyone researched if the In circuit programming pins are available on the connectors. This may be a quick way to update the code on the controller.
Unread 24-05-2005, 22:22
Elgin Clock's Avatar
FRC #0237 (Black Magic)
All in due time folks.. All in due time.
Looks promising though, and easy to use.
Unread 25-05-2005, 14:42
fowlerm's Avatar
AKA: Matthew Fowler
The PIC's ICSP pins are not available through the 6-pin connector. The bootloader that's on the chips is a serial bootloader that uses the PIC's USART to download code and write to the program memory. If you use the ICSP pins to download code you have to have a hardware programmer like the ICD2, but if you download the code using the bootloader all you need to have is serial port on a PC and an RS-232 to TTL converter.
Unread 01-06-2005, 17:43
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
Were you able to actually program the module, if so,
did you use the same compiler for FIRST,
Do you have any example programs that you wrote,
Also, has anyone found a schematic of the vex kit,
thanks
~Andrew Lynch
Unread 06-06-2005, 16:02
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
I got the VEX kit for my birthday, and as the programmer on my team, I badly want to program it.
I bought a couple of MAX232 chips, and I have some RJ11 and DB9 cables.
The datasheet for the MAX232 says that it inverts the logic, so do I need to invert it back to normal?
Thanks,
Steven
Unread 07-06-2005, 00:20
lynca's Avatar
Andrew Lynch
The programming module has a PIC and does not include just a converter interface. Contact vex labs to obtain a programming module.
~Andrew
Unread 10-06-2005, 20:39
after spending last weekend fruitlessly trying to put together a programmer with a max232, a handful of capacitors and a momentary switch i gave up and ordered a prototype programmer from vexlabs on monday.
it arrived today and in addition to a level shifting ic there is a microchip 12f629 on board. boy do i feel like a dope...
Unread 11-06-2005, 00:45
John Wanninger's Avatar
John Wanninger John Wanninger is offline
FRC #1732 (Hilltoppers)
John Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond repute
Ok, so maybe there's more to it than you thought. but my hat's off to you. Those efforts which seemed futile will someday pay off in other ways, although you may not see it now. Even if only 1 out of 4 things you try work,that's better than most folks' 0 for 0, not to mention what you would learn in the 3 "failures." Yours is the path to accomplishment.
(BTW, my programmer module arrived Thursday, but I haven't had the chance to try it out yet!)
"A hundred times every day I remind myself that my inner and outer life are based on the labors of other men, living and dead, and that I must exert myself in order to give in the same measure as I have received and am still receiving..."
--Albert Einstein
2001: FLL852 |2002: FLL20/FLL21 |2003: FLL23/FLL25 |2004: FLL14/FLL16 |2005: FVC22/FLL124 |2006: FLL3/FLL2986/FVC22/FRC1732 |2007:FLL3/FLL34/FLL56/FRC1732
2008: FLL3/FLL18/FRC1732 |2009: FLL101/FLL8963/FRC1732 ...(etc.!)
Programming - Getting Started Mark McLeod Programming 80 16-04-2008 23:37
Programming for Vex robots Jeff K. Programming 4 13-11-2005 16:40
VEX Robotics vexrobotics FIRST Tech Challenge 8 30-03-2005 23:25
OCCRA Teams - where do you build? Phil 33 OCCRA 7 28-10-2004 21:41
build new programming (st.louis regional) nick_champ_2 Programming 21 23-02-2004 20:55
