Go to Post We also have a CNC mill and CNC lathe, but we're interested in doing this only if we can do it quickly. Milling anything takes too long for my MTV-generation attention span. :) - Madison [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 07-06-2005, 11:15
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Cross-browser drop down menu problems
I'm currently working on a PHP project, but got bored (), so I decided to spruce up the interface some. (You've seen it before at this thread.) The problem I'm having right now is with CSS drop down menus, as described at Stu Nicholls' website.
The problem I'm having right now is with IE (of course ). The menus drop down correctly, but don't stay open when you move down to click something. You can view an example page using my layout (just ripped the output from a page) at http://jfy.homeunix.net/misc/example.html. (The main CSS is at http://jfy.homeunix.net/includes/stylesheets/normal.css and the drop down menu part is at http://jfy.homeunix.net/includes/sty...sing_menus.css
There's also the fact that the first menu doesn't open unless you go all the way to the left, but that's a whole different story. There is a div (empty in that example page) which would cover it. I may have to change the z-index on the menu. Feel free to suggest on that, but I'll work on it.
Unread 07-06-2005, 11:28
MrToast's Avatar
MrToast MrToast is offline
I named Greg Needel's cat!
AKA: Dave DeLong
no team (Rhode Warriors)
MrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud of
Send a message via AIM to MrToast
Re: Cross-browser drop down menu problems
I also noticed that on Safari 2 (Tiger), there's a problem with the left option menu when scrolling down. It's under the bold "Users:" and the "Additional Stylesheets" captions on the left.
I've taken a screenshot and posted it at my site:
http://www.davedelong.com/gallery/mi...n_morehart.png
Dave
(#121, 2004) Archimedes semi-finalists with 237 and 386! I had an awesome time guys, and thanks for the hat!
(#121, 2004) BC5 semi-finalists with 190 and 1027! Awesome time! We went further than I thought we could! Thanks for all your help w/ our transmission!
(#121, 2005) Galileo quarter-finalists with 47 and 203! Thanks for all your support through the stress!
If it moves and it shouldn't, use duct tape.
If it doesn't move and it should, use WD-40
"It'll all work out in the end, and if it doesn't, it's not the end." - Jeff Bullock
Unread 07-06-2005, 11:30
Programming User
Dave
Hm... muy special. Thanks. :/ I guess.
Java Drop Down Menu Help KTorak Website Design/Showcase 4 06-02-2005 20:59
Why did the chicken cross the road? Billfred Chit-Chat 10 29-05-2004 16:11
