Go to Post ... poets, novelists, songwriters, these people are word engineers. - MissInformation [more]
Unread 02-06-2005, 18:27
tux tux is offline
AKA: Lee Harr
FRC #3842 (Shock-a-Bots)
tux is an unknown quantity at this point
Re: using eclipse
> what utils one needs to program the robot in linux
start here:
http://adambots-live.sourceforge.net/
join the mailing list too:
http://lists.sourceforge.net/lists/l...s-live-support
Very low volume now, but hopefully will pick up as next
year's competition gets closer.
Unread 03-06-2005, 12:20
dasRatsel's Avatar
dasRatsel dasRatsel is offline
FRC #0811
dasRatsel is on a distinguished road
Re: using eclipse
yea -- bout that wiki site -- i c'n never figure out just how to actually find the download link f'r the graphical pic loader (gtk) / WINE wrapper 'n' all that jazz -- i also cant find em on sourceforge .. so .. uh...
and i said what about
breakfast at tiffany's
she said i think i
remember that film
i
said as i recall
i think
we both kinda liked it
and i said well that's one thing we got
Unread 04-06-2005, 17:31
tux tux is offline
AKA: Lee Harr
Re: using eclipse
I've never seen a graphical pic loader for linux.
> WINE wrapper
I've never seen a wrapper either. There is a gentoo ebuild that sets up mplab, and there is a Makefile.
I usually just keep a text console open in the directory and do:
make
make load
make read
Unread 04-06-2005, 20:03
dasRatsel's Avatar
FRC #0811
Re: using eclipse
uh -- ok -- so that adam bots thing is just a joke?
anyway -- i'm intreagued by the ebuild -- i'm guessin its not in portage by default -- where c'n i get it?
~xavier
she said i think i
remember that film
i
said as i recall
i think
Unread 05-06-2005, 09:09
tux tux is offline
AKA: Lee Harr
Re: using eclipse
You mean this one?
http://adambots-live.sourceforge.net...oaderFrontends
I don't think it is a joke... more like a plan.
Try their cvs repo. I believe that is where I got it:
http://sourceforge.net/cvs/?group_id=118894
First make a new directory, then go in there and ...
cvs -d:pserver:anonymous@cvs.sourceforge.net:/cvsroot/adambots-live login
When it asks for a password, press enter. Then ...
cvs -z3 -d:pserver:anonymous@cvs.sourceforge.net:/cvsroot/adambots-live co -P .
Yes, you need the dot at the end of the line.
Unread 05-06-2005, 18:11
dasRatsel's Avatar
FRC #0811
Re: using eclipse
ahhh -- so close -- so close
k -- i finally managed to emerge everything (after some doing since the digest files were corrupt or somethin like that) 'n' i got a hold of the make files that should make things work --- which leads to a rather curious problem:
i keep getting a make error on the line that says "include .conf/*" where it says no such file or directory
so i comment out the two lines that say that (one at the top / one at the bottom) and when i try to "make all" it says:
/bin/sh: line 1: .conf/00all_targets: No such file or directory
make: *** [update_targets] Error 1
make: Target `all' not remade because of errors.
again with that .conf directory -- what's up with that? -- i cant even begin to imagine what it might be...please help
~Xavier
PS: thanks for indulging my new found desire to get this working in linux
she said i think i
remember that film
i
said as i recall
i think
Unread 05-06-2005, 19:50
prograid's Avatar
prograid prograid is offline
AKA: Ben Cherian
prograid will become famous soon enough
Re: using eclipse
Are you using the managed make feature I else or are you using somthing else?
If you are using linux you probably should be downloading GNU Make instead of MinGW. Other than that things should work fine.
Unread 05-06-2005, 21:10
dasRatsel's Avatar
FRC #0811
Re: using eclipse
yea -- i'm just GNU make -- the problem is in that .conf/* thing -- did i forget to configure something ?
she said i think i
remember that film
i
said as i recall
i think
Unread 07-06-2005, 14:03
prograid's Avatar
AKA: Ben Cherian
Re: using eclipse
Oh I just realized something, try changing the make command from mingw32-make to make. Select your project. Go to project, properties, C/C++ Build and change your build command to make.
Unread 07-06-2005, 16:57
tux tux is offline
AKA: Lee Harr
Re: using eclipse
You may need to create that directory, and create a blank file in there. Try the updated Makefile that I posted to the mailing list. It should be in the mailing list archives.
http://sourceforge.net/mailarchive/f...forum_id=44800
The update is a bit more involved, as it creates a python script to parse out the messages when you have an error during the compile.
This whole thread is really off-topic here. I do not believe he is trying to use eclipse at all. Sorry. You should probably take any adambots questions to their mailing list, or else start a new thread here.
Unread 07-06-2005, 17:49
prograid's Avatar
AKA: Ben Cherian
Re: using eclipse
I'm pretty sure that he is trying to use eclipse. I'm assuming he's using the plugin I wrote for eclipse. The plugin generates a makefile for you that's supposed to work with GNU Make.
Unread 07-06-2005, 21:30
dasRatsel's Avatar
FRC #0811
Re: using eclipse
yea -- sorry for not being very discriptive -- i wasnt actually using the plugin f'r that error -- i just added the .conf directory 'n' put all the files that the makefile wanted -- but now i get make errors when it tries to compile the .o files -- it simply says Error 1
so i tried the plugin and it compiles well enough -- problem is when it hits the linker -- it claims it cant find mplink -- i even tried adding wine to the command // adding the full path // doing both at the same time // even using _mplink.exe == nothing works -- what am i doing wrong now?
thanks
~xavier
she said i think i
remember that film
i
said as i recall
i think
Unread 07-06-2005, 22:22
dasRatsel's Avatar
FRC #0811
Re: using eclipse
blah -- ok --
Linking... -
Done!
Finished building: FRCfalcon.hex
Build complete for project falcon
so i got it working with the eclipse plugin - trick is the makefile for the wine-wrapper wasnt written right so it only installed mcc18 and not mplink --- it claims everything was successful -- the only thing it complained over was the lack of /etc/mcc-wrapper/mplink.conf file and i shoud run mcc-setup (which i couldn't find) but it seemed ok without it -- and i'm rather curious -- where did it put the hex? -- i've searched my entire disk 'n' i cant find it --[cant find a cod or cof files either]
~xavier
she said i think i
remember that film
i
said as i recall
i think
Unread 07-06-2005, 23:57
prograid's Avatar
AKA: Ben Cherian
Re: using eclipse
Check the FRC Debug or FRC Release, (you'll probably have FRC Debug) folder of you Eclipse project. It should be there along with a cof file. (Cod file generation is supressed by default in my plugin since you can't debug with MPSIM in Eclipse anyway). The *.o files and a map file should be there also.
Unread 08-06-2005, 19:11
dasRatsel's Avatar
FRC #0811
Re: using eclipse
yea -- nothin -- did i forget to set some variable to tell it to make the output file or something?
linker output:
Building target: FRCfalcon.hex
mplink /Files/FIRST/code/falcon/18f8520user.lkr /aINHX32 /o FRCfalcon.hex encoder.o gyro.o ifi_startup.o ifi_utilities.o main.o pid.o printf_lib.o robot.o user_routines.o user_routines_fast.o   /l/opt/mcc18/lib /Files/FIRST/code/falcon/FRC_alltimers.lib
WARNING: Cannot find /etc/mcc-wrapper/mplink.conf. Run mcc-setup
Microchip Linker
Linux WINE wrapper version CVS-HEAD
Copyright (c) 2004 Adambots-Live
(oh yea -- is there a way to supress those things that say compiling -- they're just junking up the output window to the point where i cant read the outputs from the compiler 'n' linker)
she said i think i
remember that film
i
said as i recall
i think
Using Eclipse IDE & makefile as MPLAB replacement RoboPhantom Programming 0 27-02-2005 19:05
Last total Lunar Eclipse TONIGHT miketwalker Chit-Chat 16 11-11-2003 22:00
Free Compiler/Linker for WinXP? IMDWalrus Programming 14 05-11-2003 15:45
Total Lunar Eclipse May 15/16 Night geo Chit-Chat 17 19-05-2003 22:02
