Go to Post Frisbees [as next year's game piece]. That is all. - Frenchie461 [more]
Unread 06-09-2005, 07:11 PM
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
Cheap Torque Measurement?
OK all you motorheads and gearbox designers, how do YOU measure torque? Not calculate a graph, I mean directly measure torque at the output shaft of the motor or gearbox. As in, I want something that works like a tachometer for RPM but for torque. I know that there are such things a torque sensors but what I find seem to be big heavy industrial stuff and/or VERY expensive. I would like to be able to take a motor of the size ranges we use in FIRST (FP, CIM, Globe, Drill, etc.) and apply a known voltage and current limit to it and clamp something on the output shaft and measure the torque. It could be a direct reading sort of like a torque wrench (i.e. ft-fbs, nM, etc.) or just some sort of analog output like a voltage range that is proportional to the torque that I read and convert. Do R/C hobby folks use anything like this? Even something that would output a 0-5V sensor type thing that could be read with the Robot Controller might be cool. Maybe even some sort of bar clamped to the output shaft with a linear strain gauge setup or something. It would, of course, need to be cheap! What am I looking for? I don't even know where to start. How about some search terms, maybe some direct links, or even just tell me that I am crazy and no such critter exists? Help! Educate me!
For example stuff like this: http://www.transducertechniques.com/...nt-Sensors.cfm is way too expensive for me!
Torque curves BionicAlumni Motors 4 04-29-2004 08:07 PM
Power, speed, and torque... AGH Gui Cavalcanti Technical Discussion 5 11-10-2002 07:02 PM
Friction, traction, torque - oh my... Gui Cavalcanti Technical Discussion 30 08-13-2002 06:01 PM
Gear Woes Simon G Technical Discussion 14 01-24-2002 04:31 PM
Traction Limited, rather than torque Simon G Technical Discussion 6 01-23-2002 07:08 AM
