Go to Post I even liked the Bieber commercial. - Andy Baker [more]
Unread 12-06-2005, 15:53
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
Question advancing my knowledge
i have taken the project lead the way coure on digital electronics and passed that easy, now i am studying eletrical systems and math, and all that, i dont know what to call it, i am looking at type of memory, busses, building blocks of computers and inputs and outputs of computers, that is all the information i have readily availible to me right now. i was hoping that someone in the cheif delphi community could help me out in either mentoring me to help me learn more and get rlly advanded or point me in the right direction to get really advanced, my goal is to major in mechanical engineering technology and minor in electrical engineering at hopefully RIT
i am currently a sophmore iun high school advancing to a junior and am 15 years old so there is plenty of time for me to learn as much as i can before college
i need help learning things more indepth and getting thinking of project i could do to actually apply my knowledge so i can rememeber it and make some use of it
if your interested,(hopefully a electrical engineer) please post or pm me, other wise just post any usful info
ps - if anyone looking to learn more or get started i could help you or any one who may need my help for a project i am also availible for that
Unread 12-06-2005, 15:56
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Re: advancing my knowledge
i know only ttl and i could use help learning cmos, also if anyone know of some helpful tools that would be nice
Unread 12-06-2005, 23:50
Kevin Watson's Avatar
La Caņada High School
FRC #2429
You should just post your questions here. There are several EEs around (including myself) that can answer your questions.
-Kevin
Kevin Watson
http://kevin.org
Unread 13-06-2005, 10:19
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
i dont really have just questions, i mostly just need like lessons or idea on project i can do to apply what i have learned
Unread 14-06-2005, 10:50
Sparks333's Avatar
Sparks333 Sparks333 is offline
Robotics Engineer
AKA: Dane B.
FRC #1425 (Wilsonville Robotics)
Sparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of light
Send a message via AIM to Sparks333
This really doesn't help with the problem, but it's part of the problem I can help.
CMOS and TTL are just two different methods of doing the same boolean logic. TTL uses a bipolar transistor, which is faster and hardier, but more power consuming. CMOS (Complementary Metal Oxide Semiconductor) uses a different type of switching, NMOS and PMOS, to get roughly the same effect as TTL, though slower and more shock-sensitive. The largest difference is the power draw: TTL draws much more power than CMOS, making CMOS good for battery-critical applications. The other thing you have to worry about is logic voltage thresholds. Check this page to see what I mean. If you do plan to mix and match CMOS and TTL, do it with a level converter. NEVER drive a CMOS chip with a TTL chip - it will blow it out.
Other than those differences, the logic itself is still good 'ol boolean, so learning CMOS after TTL should be a snap.
Sparks
ICs do weird things when voltage is run out of spec.
I love to take things apart. The fact that they work better when I put them back together it just a bonus.
http://www.ravenblack.net/random/surreal.html
pic: FIRST veterans knowledge needed. What kind of motors are these? CD47-Bot Extra Discussion 12 24-07-2004 13:25
Variable Speed Transmission Knowledge (Search Tried!) Jeff D. Technical Discussion 4 14-01-2004 22:00
Dual Moniters - Anyone done it or has knowledge about it? DanL Computer Graphics 23 19-11-2002 16:01
Putting FIRST knowledge to good thought) archiver 1999 14 23-06-2002 22:33
