Go to Post All tools are powered by magic angry noise. - artdutra04 [more]
Unread 13-06-2005, 14:00
dradius's Avatar
dradius dradius is offline
breakdancaz
AKA: ryan
FRC #0624 (CRyptonite)
dradius will become famous soon enough
Send a message via AIM to dradius Send a message via MSN to dradius
alternative to futaba?
hi guys,
though no longer in first (though i might start a team soon around here) i'm out for now--meaning im doing extra work around.
anybody have any alternatives to futaba servos for small motor control? i'm sorta sick of buying slightly expensive servos only to strip them out to make a normal motor. whats the best idea (like not using servos--meaning what for that same size category)?
thanks
pessimist: glass is half empty
optimist: glass is half full
engineer: glass is twice the size it needs to be
--bringing green spikes and fishnets back in to style, baby--
Unread 13-06-2005, 14:06
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: alternative to futaba?
Hey 624, I remember you guys. You stayed in our hotel in Phoenix in 2003.
Anyway, I'm not too clear on exactly what you are looking for. Do you want a cheap servo that has already been modified to continuously rotate? If so: http://www.parallax.com/detail.asp?product_id=900-00008
If you are just looking for a bunch of different servos, here's a lot of them: http://www2.towerhobbies.com/cgi-bin...7p?CATEGORY=MA
Unread 13-06-2005, 15:53
dradius's Avatar
breakdancaz
AKA: ryan
actually, i was thinking of alternatives to servos in general. something small and somewhat lower voltage, but higher in torque than servos, and continuously rotating (instead of modding them, because thats what we already do). any ideas? sorry for the vague question.
Unread 13-06-2005, 16:13
billbo911's Avatar
billbo911 billbo911 is online now
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Here's a quick thought. There are motors provided with, and sold separately from, the VEX kits that might meet your needs. They are the exact same size as a standard servo, but they continuously rotate in both directions. Take a look and see if they meet your needs. I believe they are priced in the $20 range.
Unread 13-06-2005, 17:59
dradius's Avatar
breakdancaz
AKA: ryan
but what about something stronger? i'd like to stay in the same size range, but jump up a bit in torque (hopefully). thanks.
Unread 13-06-2005, 18:14
Billfred's Avatar
Billfred Billfred is offline
Perhaps you'd be in the market for an R/C car motor? I've had good experiences with the Traxxas Stinger motor (which appears to be a standard RS-540 motor, but might not be--I don't know). I don't have the link, but I recall it going for $10-15 on Tower Hobbies. Good power on 7.2 volts, lasts forever, low maintenance, and is still pretty cheap.
Unread 13-06-2005, 20:38
billbo911's Avatar
That's an excellent suggestion!! I don't know why I didn't think of it.
There are more types R/C car motors than you can imagine!! Everything from "stock" to super modified that can suck a 2100mAh 7.2vdc dry in as little as a minute. All of these motors will require a speed control, and yes, a Victor will do just fine. The one thing to understand is that very few of these motors are designed to run on 12vdc. (Although, there is a "Boat" motor that is designed for 12vdc that I am aware of.) R/C car motors are physically larger than a servo, but you will find the torque is way better. This is due to many factors: much larger and stronger magnets, much higher current draw to name a few. They also can achieve an output shaft peek RPM in the 30K ballpark, not that you would ever need it. A motor that can do that will also cost +$50. The one that Billfred mentioned lists for $17.49 at Tower Hobbies http://www2.towerhobbies.com/cgi-bin...er&FVPROFIL=++
It is a very good, reliable, sturdy motor. But remember, you will need to use a speed control and it won't last long at all if you dump a full 12vdc on it. (But it will SCREAM... until it dies )
Hope that helps!
Unread 13-06-2005, 20:59
While RC car motors are relatively inexpensive, easily available, and very powerful, they are extremely fast. You will need a lot of gearing which may not be cheap or easy. I recommend getting a gearhead motor like this that already spins pretty slow.
I'm not sure how big or small you want your robot to be, or how fast or slow, but you might also take a look at these motors http://robotcombat.com/marketplace_ant_motors.html
Unread 14-06-2005, 03:35
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Check this site out.
http://www.lynxmotion.com/Category.aspx?CategoryID=50
They might have something you are looking for.
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Alternative Power Sources? plutonium83 Electrical 18 30-05-2005 15:09
using alternative compiler Leav Programming 2 18-01-2005 15:30
Alternative autonomous modes Jon Reese Programming 1 14-01-2004 13:17
Revisit: No. of Inventor Licenses - Great FREE alternative! Stu Bloom Inventor 1 15-10-2003 01:20
